Hello all. Let me introduce myself.  I have built a number of wood ship models over the years and have always wanted to build Calypso, a boat that helped mold my life. As a young man watching "The Undersea World of Jaques Cousteau I was led to a life of diving and sailing and great respect for the ocean.
I just opened the box and looking through the non-written pictorial directions am a bit overwhelmed. I was hoping for some form of written guide to go along with the instructions. I will be posting photos as I go and will be asking questions along the way. I have looked over a number of finished Calypso builds and am quite excited and inspired to begin.  I am considering planking the hull as I saw another member do to make the model appear more authentic.  Is there a glue other than super glue that would work better to bond wood planks to the ABS hull?  Lastly, I have not been able to figure out how to make comments or ask questions on others builds. Thanks in advance for any feedback going forward.
I am going through the kit and familiarizing and identifying parts the best I can. The instructions are entirely printed illustrations showings parts and where they should go.  No text.  It would be most helpful if there was an English PDF online guide.
There is a very impressive collection of beautiful brass parts.
I began cutting out the molded ABS plastic parts and will glue the pairs together.
Next step will be setting the keel and forward bulkhead.
I am awaiting a shipment of 1/4" x 1/16" basswood strips to plank the outer ABS hull.
This will be challenging and fun.
Patrick
Hi Patrick, welcome to MSW. Good luck with your Calypso. It looks like a very nice kit. If you want to comment on someone’s post, go to the bottom of their post and click on “Reply to this post “ .
Best Regards……..Paul
The hull of the Billing  Calypso is intentionally oversized for strength in shipping and requires  cutting through the ABS hull to get to the correct shape. The pictorial directions indicate the use of an exacto knife. With new blade in hand I tried and I tried but even after 6 passes could not cut through the ABS material.  It is said that "necessity is the mother of invention".  I left some material above the cut line and ended up using my box knife heated up on the gas range to make the cuts and it worked quite well. Eventually when my deck is installed, the rough-cut upper edge will be sanded down to the deck planking.
I received my shipment of basswood today to plank the outer hull of Calypso. These are 1/4" x 1/16" x 24".  I ordered 80 strips so there should be plenty. Excited to start this part of the build. Needless to say, I would not be doing this if I was going to use the Calypso as an R/C model on the water.
17 hours ago, yvesvidal said:
I am glad that you decided to plank the hull. Calypso is an old minesweeper and as such the hull was made of wood.
The bow is made of metal, so be careful to not plank it entirely.
Yves
Thank you for that wonderful photo Yves, I glued the first two planks on the stern last night with Tight bond wood glue. This morning when I removed the clamps the wood came off as if never glued. Have to do some research for wood to ABS bonding.  Superglue would work ,but I would like a little more working time to make minor adjustments. I saw a post where another member, Luekutus,  planked his Calypso and left the bow unplanked. Here is a copy paste of his Calypso. image.jpeg.20f89396f9364714225ea009c4509ba3.jpeg
Made some progress over the past few days. Installed the rudder hardware housing.
After adding wooden support strips running along the sides, forward bulkhead and stern, I installed the main deck. This really stiffened up the previously flexible ABS hull.
Fine sanding the ABS hull along with Gorilla super glue is working well for my wood to plastic joints. I then added the second forward bulkhead which required a little fitting.
With the hull stiffened and stable, I am looking forward to planking the hull.
I began the planking of Calypso a few days ago. I find this part of the build to be very satisfying. She is starting to look like a ship.
I picked up a few organizing trays to separate the various brass fittings into categories. I found it a bit overwhelming to see all of those brass parts mixed together in three plastic bags.
This should really help when it comes time to find various parts.
I am thoroughly happy building this historic ship with the exception of the lack of written instruction. I am also very grateful for all of the wonderful previous Calypso build posts on this site.
Your workmanship and organization look great.  Your model is going to turn out great.
Ryland
               - Nautical Research Guild
Thankyou Yves and Ryland.
It is cold, damp and foggy here in Daytona Beach this morning so it should be another good day to add more planking. I am thankful for many things, most recently acetone to get the super glue off of my fingers :0)
Like others that have built Calypso, I was inspired by Cousteau as a high school student in the 60's leading me to pursue a life of diving and ocean sailing. On my way sailing to the Florida Keys years ago, Iwas fortunate to see Calypso docked in Miami. Building this model will be a tribute to many fond memories. Here is an old photo of Calypso in Key West from a Google search.
Patrick, your planking looks great and I’m following your build with interest. One suggestion, I think that there was a passageway between the fore and aft main cabins that is closed if you follow the instructions, which is what I did. I think one of the other builds on here shows it opened up that may be more accurate.
Don
Edited by Nunnehi (Don)
Don
That is correct. Billing Boats decided to link the two main cabins since the kit was designed to be R/C and thus required a good access to the inside of the hull. For a more precise model, the two cabins should be separated with a passage in between.
Yves
Thank you Yves and Don for the passageway information. I looked at some other Calypso builds on this site and now see the planked passageway. . It makes sense.
I was able to finish up the planking of the hull today and began sanding and fairing.  I am very happy that I decided to plank the hull as I look at the result.  This will be a static model which made the wood planking
an option.  I will begin working on the forward observation bulbous bow next. I thought it best to leave it off during the planking stage to avoid damage.
I had some time over the last few days and spent it attaching the brass rudders in anticipation of painting the hull. Also added and faired the observation bow nose.  Now it looks like the Calypso I remember. To create the openings for the port holes, I marked where they would go and then heated up a pointed awl and created small dimples in the ABS rounded plastic nose where I would drill.  That prevented my drill from dancing around the curved surface.  I anticipated some separation in the two halves of the bow nose when drilling since the material is so thin and there is not much surface area to glue. Before I installed the nose, I glued some scrap ABS plastic strips across the seams on the inside which worked well. Also started with a small drill bit and worked my way up carefully. So far, so good.
Cheers from Florida
I was fortunate to have both time and desire the past few days to work on Calypso.  Added the propellor shaft struts and housing for the shaft.  Then carved and attached two horizontal stabilizer struts, one for each side of the hull.
To begin the planking, I experimented using black thread between the deck planks as others have done or using a black marker along the edge of the deck planks as others have done. The black marker won out.
Placing a centerline down the deck, I began the planking process with the first plank up against the centerline.  This will take a little while. I am having a tough time from the illustrated instructions making out how to transition from deck planking to the outer scupper board.  Any suggestions or photos would be helpful. I have looked at other build but cannot make out this detail.
I am hoping to post enough step by step information with this build to help future Calypso builders see the various steps since there are no printed instructions with this model.  The other Calypso builds on this site have been very helpful so far and inspiring!
More progress on the deck planking today.  She is starting to look like a wood ship.  Thanks to those that have gone before me for the tip about planking the passageways. Loving the process.  Does anybody know what the cut outs along the side of the deck are for?  I marked them in red. I see nothing in the plans that line up. If they are necessary, I will retain them before decking to the outer hull. Thanks. image.thumb.jpeg.4ef69fe36ea918ef374d8ec1820145c1.jpeg
Just came across your build log - I've not seen anyone build this one (though maybe there's a log or two in the archive here...) - very exciting to see!! The work looks good so far
hamilton
Coming along slowly. I worked on the gunwales today by adding the scuppers and the ribs.  Calipers were very helpful to get the spacing correct.
Next will be a handrail on top.
Before I attach the gunwales to the deck, I will have to commit to a shade of white to paint this feature which I will also use on the ship's sides and cabins.   There are a lot of whites out there. image.jpeg.fa66aadcc9556b552ebec3219cdcef46.jpeg
I have had good results in the past using Home Depot's acrylic sample paints. Lots of colors to choose from. The white choice was interesting. They have about 50 shades of white. I settled on one, believe it or not, just named "white". When held next to "Ultra Pure White", this tint is just enough off white to fit my taste. I went with a satin finish. Added a first coat to my rails, lower cabin sides, and upper hull.  Enjoying the process. Will add bottom paint to the hull next and finish off with the black..
