Thanks for your detailed build log Glenn. Your descriptions of the problems and possible solutions will be very handy when I reach that stage in my build. Cheers.
Richard
Associated build, Chris Coyle's SBLim-2A build
Current builds: Harpy Vanguard 1:64, SBLim-2A, MiG 15 variant, WAK card
Completed builds:
AL's Endeavour,  Corel's BellonaAmati's Xebec,  Billing's Roar Ege, Panart's Armed Launch
Ships' Boats - Vanguard 1:64 and Master Korabel 1:72
 Alexander Arbuthnot,  Christiaan Brunings,  Pevenseall by World of Paperships, card
HMS Pegasus by Victory
Captain John Smith's Shallop by Pavel Nitikin
Rumpler "Taube" 1911 by HMV, card
You're welcome
Glenn (UK)
Tricky area that stern arrangement, I haven't got around to looking at it yet.
It is a good idea to use a card template to work out the angles for the side panels to the Pantry and the quaintly named 'Necessary' structures. Don't want to mess the actual pieces up.
I will be adding a margin strip where the deck planking at the stern meets the lower counter.  The  existing set-up would allow water to run down the counter and work its way between deck and the frames below.
B.E.
B.E.
Thanks Maurice. The template side pieces were fashioned from spare 0.8mm thick plywood. If, when fettling the side panels, I am not happy then I will just use 4mm planks. I am also thinking of planking the roof section.
Much to ponder. I wish I had your skill and patience to plank the upper deck.
Glenn (UK)
I have not been able to spend much time in the shipyard today and will have very little or no time in the shipyard over the next couple of days as we are looking after our youngest granddaughter (1 year old). I am hoping I can glue the upper deck pattern in place when she has an afternoon nap (fingers crossed she will have a nap)
One more dry fit test was my first task today. This time the inner bulwark patterns were aligned using the gunport jigs. As can be seen below everything lined up perfectly.
001.thumb.JPG.aac429dad684759b705a2ca656e88357.JPG002.thumb.JPG.b7fce2929616458700e0f2a5693f9437.JPG003.thumb.JPG.64b018dc6d6ea2735e8e32131e5e0037.JPG004.thumb.JPG.0ea7eb2390ee1ecf34ccdb5cedf21d82.JPG
Next I applied some sanding sealer to the various bulwark, rear cabins, stern counter and stern board patterns. Once the sealer had dried the various patterns were painted.
005.thumb.JPG.5b526a30024da0af5ce00a7a5034a0e7.JPG006.thumb.JPG.a22bbcb7b63e32b4e15d42b2e0ec7b2d.JPG
The stern board and counter patterns were then glued in place. The stern counter was positioned and clamped before the stern board. I am reasonable happy with how this looks.
007.thumb.JPG.f3e242ef442143fd418c8a2b0bdc2335.JPG008.thumb.JPG.a8108b6c759f36d517d43d1faf7b72d8.JPG
I then decided to paint the outer frame work of the cabin sides patterns black.
In the final photo you get an idea of how the different colour parts interact, noting I still have much work to do with the stern cabin fittings.
Glenn (UK)
I have returned to the shipyard after a busy two days looking after our youngest 1 year old granddaughter.
The upper, laser etched, deck pattern has now been glued in place and was left for 24 hours to give the glue plenty of time to cure.  I then decided to dry fit some the upper deck items and patterns. I am very happy that these items seem to fit perfectly as can be seen in the next two photos. My next task will be to glue the inner bulwark patterns in place.
001.thumb.JPG.a6376c38fe80fa631496956bcf9698f1.JPG002.thumb.JPG.242e9be9028cd4be49700587df9b5c86.JPG
The next photo shows the stern area, noting I still have to shape the rear cabin side patterns.
The next three photos shows  the midship section(s).
004.thumb.JPG.21788636199cc42ac29384a44faf1ec9.JPG005.thumb.JPG.067e3852537a9320a931e08f7f85ad03.JPG006.thumb.JPG.1c42e825be57a6bd3b3e980042288afb.JPG
The next photo shows the bow area, the front grating assembly will require a little bit of fettling to get a good tight fit.
I might add a little shaped deck infill so it follows the line of the lower partition, as can be seen in the photo below
I can either paint the inner face of the visible partition shown in the photo below or I could add a filler piece so the inner face of the partition is not visible. I will probably try to paint the partition.
Edited by Glenn-UK
Glenn (UK)
The inner bulwark patterns have now been glued and they were left overnight to allow plenty of time for the glue to fully cure. I did use the gun port jigs to ensure the patterns were correctly aligned.
001.thumb.JPG.19105f0a5f5b9d3c841e594df9fb7a5e.JPG002.thumb.JPG.eacef922edc31ba8ff76bf7386dfa004.JPG
I then turned my attention to the rear cabin side panels. Having made a template which was a good fit I decided the kit supplied patterns could not be trimmed to get a nice looking fit. Therefore I opted to make some new side cabin pieces. I cut some lengths of 4mmW planking material which were then glued together. The template was then used to draw the required outline on the glued planks. To complete the process I added the outer framing strips and the assembly was then trimmed to match the template. I ended up rejecting my first one due to any error with the framing, as shown below.
I was much happier with my second attempt, albeit I did need to add an additional filler to the right hand side panel.
After sealing and painting the side panels black they were added to the Harpy along with the doors. In the photo below the door handle is missing in action.
The missing door handle has now been attached and I have also dry fitted the roof section. I need to make sure it is a good fit with the top edge of the side panel before gluing it in place.
006.thumb.JPG.cc6144e429701a5fa4a152d73264c0e8.JPG007.thumb.JPG.43ddec582bb57281eb532d6af9f989f5.JPG
Glenn (UK)
Sitting in there nice and snugly, Glenn. Nice job sir. Love the door handle mate!
The roof of the two rear cabins have now been added. I have just noted @Blue Ensign comment on his build log regarding the position of the roof with regards to the gunwales and I have the same issue with the rear section of the gunwale being above the level of the cabin roof. I do not plan to do anything with this for the time being. I also plan to add a margin plank between the deck and stern board joint.
My next task is to install the inner bulwark sheer rail and spirketting patterns. Experience has taught me that I need to check the position of the sheer rail with regards to the various belaying racks to ensure the racks can be installed without fouling with the bottom edge of the sheer rail. I plan glue the belaying rack in place before the sheer rail so that I can sure the racks are full engaged in the locating slots provided.
In the photos below I am test fitting the sheer rail and spirketting patterns, both of which required a little bit of trimming. In the final photo below I am also making sure the bowsprit will fit through the hole provided at the bow. Before fitting the racks and patterns I will coat the various parts with sanding sealer and then paint, red for the patterns and black for the racks.
002.thumb.JPG.965a85d227a66421b0330fca8d23cc7e.JPG003.thumb.JPG.43776d9329928fdc9b406237134367cc.JPG004.thumb.JPG.0e6fb6f4f7da5b0c95d70805fa441d50.JPG
Glenn (UK)
28 minutes ago, ECK said:
I replied to Blue Ensign about the issue. I sanded back the edge of the roof and lowered the angle a bit of bulwark a bit as the davits take up the whole width of the capping rail.
Thanks for the information. I plan test fit the gunwales and davits to see what needs doing on my Harpy.
Glenn (UK)
It has been one of those days were I have spent plenty of time in the shipyard but have not really made that much progress.
I started by fitting the bow spirketting patterns. This took some time as I need to make sure the holes provided for the eyebolts lined up with the holes on the bulwarks. Once I was happy with the overall fit the patterns were glued and clamped. I did insert a couple of eyebolts at each end of the spirketting, as can be seen in the photos below.
001.thumb.JPG.1a6e2f926446468137c79f52aabd1d76.JPG002.thumb.JPG.f70c22f950f46ddf605135dc5f275631.JPG
It was then a case of repeating the process for the rear spirketting patterns. When they were glued in place I used three eyebolts to assist with the alignment, one at the front one int he middle and one at the rear. Before fitting the patterns I did check that an eyebolt would locate in each of the bulwark openings. In some case it was necessary to run a micro drill in the hole to remove some of the glue deposits.
004.thumb.JPG.fc7802fcf3d249909706f62d578d23a1.JPG005.thumb.JPG.78c1ff398470fd49fd2452f5fca2d5bd.JPG006.thumb.JPG.78dc88c49021f4beaefa2f0977d8e956.JPG007.thumb.JPG.522b432591b3387b973459f389f57d16.JPG
Once the glue had been given time to cure the clamps were removed.
008.thumb.JPG.d9038f18839f0fe5f4b28cf644f3db89.JPG009.thumb.JPG.e6d6ef69e9f254ca05f0939cd2d2f0dd.JPG
I then made a start at cleaning up and painting the gun port openings.
010.thumb.JPG.6a0ccbb0a6e83e9b7b6dce3a963098e6.JPG011.thumb.JPG.6c6eed1ab84e1ea53e9cc87cc6a095f0.JPG
Following on from a previous post with regards to the rear cabin roof / gunwale I did a trial fit. The left hand side does not require any remedial work.
I will have to trim the top aft section of the right hand side bulwark however.
Finally I did make a start on a margin plank for the deck / stern board joint.  It still needs a little bit more work but so far so good.
Glenn (UK)
Yep, I know those only too well, Glenn. The whole thing looks great, such neat work. I'm a fan :)
This may be my last post for a week or two. Tomorrow we have grandparent child care duties looking after a 3 year. Then we have family staying with us over the weekend which means spending more time entertaining some other grandkids (1 year and 4 year). Then on Monday we are looking after our youngest 1 year granddaughter for 4 days whilst her parents have a mini break in Venice.
On a week on Friday my wife goes to hospital for an operation as her breast cancer has returned after a gap of 16 years. She is expected to make a full recovery after the operation but this will take a few weeks.
I have not made much progress today as I am waiting for an Amazon delivery for tackey wax and some more ca glue.
I have painted all the gun ports red.
001.thumb.JPG.e04a13bb178f9561beaa06d9610ddd6b.JPG002.thumb.JPG.6d30ff821b8347492508a0dfbdce2496.JPG
I have made and fitted the two margin planks between the deck and stern board. I am much happier with how this looks now.
003.thumb.JPG.256d7def49758651931ab69d4f22bace.JPG004.thumb.JPG.d1d58d9d25f77e06649eddb3a87b1ed0.JPG
As I wait for the Amazon delivery I have done some prep work for the coppering of the hull. The first task was to make a tool for picking up and placing the copper plates. This is the same type of tool that @Blue Ensign used, i.e. a cocktail stick secured to a piece of planking material that is slightly smaller then the copper tile.. The tackey wax will be used with the tool to pick up and position the copper plates, when they to be glued in place..
Next I released all the copper plates (299 off) from the first copper sheet.
I made a test fit of the first copper plate.
I then tried test fitting a few more copper plates to get an idea of how the hull will look.
Each copper plate is 18mmL so I cut 1 copper plate in half.
The half tile is then used is mark the position the first tile in the next row, as shown with the sequence of photos below. The stern post edge plate can then be trimmed to suit as necessary.
011.thumb.JPG.f773d47553478a344787a0637cff3478.JPG012.thumb.JPG.0039f7892ed661c610b0b9d8d9aef1a5.JPG013.thumb.JPG.8a58fd028997a1f3ff4b1d003aa89ab4.JPG
Edited by Glenn-UK
Glenn (UK)
Glenn, I truly wish you both all the very best in this and a speedy recovery back to healthy normality for your good lady sir.
Many thanks Mark.
Glenn (UK)
Damn, I'm so sorry to hear that. I hope all goes well for her and you both. Family is more important than anything else.
Ongoing:
I managed a quick and unplanned 40 minute visit to the shipyard this afternoon and made a start with adding the copper plates.
I started the process by printing out a plating template so that I could decide where to trim the stern post edge plates. As can be seen in the photo I covered the first 8 layers and I drew a few lines before deciding where to make the angles cut.
The copper plate was then cut to shape using the template as a guide. After a few trial fits I was happy to proceed and as can be seen I have added a few copper plates to both sides.
002.thumb.JPG.cb7eecf0f94b5f43fc379d2c2ba76a66.JPG003.thumb.JPG.0b34c91539608d469a5f3a44dec6bc26.JPG
I am using the same method detailed by @Blue Ensign in his excellent Harpy build log and so far it is working very well.
Using the pick-up tool each copper plate is picked up. Tackey wax is used to hold the copper plate to the tool, as can be seen in the photo below.
Using a cocktail stick a thin layer of ca glue is spread evenly over the base of the copper plate and it is then placed on the hull. A cotton bud dipped in acetone is then used to clean the copper plate.
Glenn (UK)
Should be done by, hmmmm let's say, Christmas, Glenn? 🤣 🤣
I have managed a couple of hours in the shipyard this morning. My first task was to copper plate the stern post areas up to the waterline.
As the copper plating continues I sometimes need to shape the copper plates, as shown below.
002.thumb.JPG.6acf4633208473b2ea4f58426bb3b3fc.JPG003.thumb.JPG.34ddbfa2631c2ef1810791bc924c6b17.JPG
More shaping is required for the copper plates which follow the waterline.
004.thumb.JPG.002a4b119968bfa3c9c8590b01df24e6.JPG005.thumb.JPG.ae920e48a6e5192ffd9bee2ef0c4796e.JPG
Progress is slow but steady. I am not sure when I will be able to get back in the shipyard. I might be able to sneak the odd few minutes during the week, but in all probability my next visit will sometime over the coming weekend or early next week. The following photo is the current build status.
Glenn (UK)
Dropped my wife off at the hospital this morning, we were told she was last on the list and I was not permitted to stay with her. This meant I was free to return to the shipyard.
I think my mind must have been elsewhere when I decided to be clever with shaping the copper plates and ended up making a right mess.
I ended up ripping off many of the plates and redoing again. Looks a bit better second time around.
Using the copper plate pick-up tool it is a relatively quick and easy task to fit each plate. The hard work will be when I have to shape the plates along the waterline, which will be my last task. My coppering skills are not great but they look alright to my naked eye. I am making some minor adjustments, when necessary, so each layer is offset by half a plate width.
003.thumb.JPG.32f144447005d0d609623cf1db573efa.JPG004.thumb.JPG.8d74da3b444c51a6be2b32a0aa6ef7c7.JPG005.thumb.JPG.221a30fbe4b036b463a40ec8163f5c4a.JPG
Edited by Glenn-UK
Glenn (UK)
I find the work in the shipyard soothes me and puts my mind at rest, Glenn but, in this situation, I can only imagine how you must be feeling. I hope and pray she will be well, sir. That is all that is important right now.
