Hello everyone and welcome to this, my first scratch build project!
I have been playing around with my laser cutter for a little year and I am slowly getting to know how to adapt original plans from 18th-19th century into something I can cut out with the laser and assemble.
I have been documenting my tests so far here: https://modelshipworld.com/topic/37190-historical-plans-via-cad-to-laser-cut-parts-practicum/
Thanks to everyone who stopped by and who commented and liked the posts there, it is much appreciated.
I was doing another small ship plan, trying to push a few things (like laser engraving the decks, etc.) and since the project was small, I found myself with a whole mini-kit of designed cut files, including gratings, beams, decks, etc. And then I couldn't help but try to cut it all out...
So instead of continuing my previous practicum, I will start and actual build log here, my first scratch built project!
My main project is still Christiania, adapted from the fantastic Vanguard Models HMS Sphinx kit, and it is likely ill advised to start on a new (albeit small) side project, but I feel I have exhausted what I can get from just designing and making the frame of ships for 'scratch built training' - I have to actually try to assemble and plank something to continue to the fittings stage of the design process. Especially the plywood bulwark patterns need tweaking that I can't do off model, so I need a faired hull to work out how to best make those parts.
Christiania will continue as my main project but while I slowly get the planking finished on that, I will work on this project along side it.
The next few posts will be a presentation of the ship in question, a small schooner used as a guard ship on the river Elben - Elben also being the name of the ship itself - and then the initial assembly of the frames.
I hope many will stop by and give their input along the way - the conversations on this forum is a large part of the hobby to me, and I really appreciate all the great feedback I get here!
BR
TJM
Intro
I decided to do this small schooner for a number of reasons:
First, it is small. At 76 feet, it is one of the smallest vessels from the Danish archives (apart from ship boats). It does have a little brother named Delphinen that is only 56 foot long, but I found this one to be a nicer overall project.
Secondly, it is from a later period - a period that I have somewhat less of an interest in, but I wanted to try something that has a copper plated hull. Being small, I thought it was a good candidate as it won't be too big of a task to copper it.
Thirdly, I wanted to learn resin 3D printing and I will use this project to do that, as the armament will need to be customized (very short 12 pounders).
An inspiration was the model by Peter Maack at the Danish War Museum of the aforementioned Delphinen:
I will take quite a few visual cues from this model.
The following are the original drawings from the National Archive.
As you can see, this is a small schooner with 8 guns. The guns are short 12 pounders. These were much the same as carronades, but more often used by the Danish ships than actual carronades of the English model. I don't have any drawings of 12 pounders, but I have a few of short 18 pound guns. They were around 10 calibres long, translating into around 121 cm or 1.9 cm at 1:64 scale. Just like a carronade.
I really like the drawings of the details on the deck and bulwarks. It should make it relatively easy to make a lot of nice accurate details.
Here is an image of the 18 pounders showing both a long and a short one. I will just scale this down to a 12 pounder.
After the loss of almost the entire Danish navy in 1807 and the conclusion of the gun boat wars in 1814, the Danish navy had to be rebuilt almost from scratch. It never again became anything close to as large as before the Second Battle of Copenhagen. Inspiration was drawn from many other navies, as had been customary in the past century, but as a new thing, America was now also in scope for that. From there, the Danish naval architects brought back plans for East Coast schooners and a few ships were made withe these as inspiration. They were used for guard duty in ports or on rivers. This particular one was stationed on the river Elben, then still in Danish territory, and named after that river.
Adapting the plans via QCAD was quite easy and quick, but I was pushing the thickness (or rather thinness) of the bulkheads and this will probably cause some issues later. It is a bit silly really, as there is no real need for them to be this thin on this build - it is just roughly the correct thickness of the actual frames, but woking with MDF bullheads, I should have added another mm or 1.5 of thickness.
Here are the laser cut sheets, 7 in total. The 2 mm one was cut twice, as I had a mistake in the cut file and had one of the parts cut in two.
The bulwark patterns are WIP and will need tweaking on the model. This is why they are just cut out of cardboard for now.
Now, I will continue with the initial building of the frame of the ship and see how it goes together!
BR
TJM
Edited by TJM
Log entry 1 - building the skeleton
I am following roughly the same approach as I have experienced in the few Vanguard kits I have been working on.
So I start with attaching the bulkheads to the keel and adding the braces.
So far, so good.
When using the 4 mm MDF from Amati, I get a very nice tight fit, but with this 3 mm, it is a little on the loose side. I think the material may be a little under 3 mm thick, and I should account for that when designing i CAD, but I have not done so here.
It will work ok for this small projet and once the glue was dry, everything was set firmly, but care is needed to not have anything set in a slightly skewed position.
I then added the laser engraved lower deck parts and the first pear gratings, also laser cut and engraved.
I am very happy with how this looks!
It will be almost entirely covered by the upper deck - you may be able to catch a tiny glimpse through the upper deck gratings and the ladder hatch, but it is more about figuring out how to do these things for future projects.
I then added the beams to all the bulkheads:
I used pear, as I was not sure 3 mm MDF would not just snap when I glue on the upper deck. It looks very nice in pear at this point, but it will all be covered up immediately, as the next (and final for this post) step was to glue in the upper deck base pattern:
I had not accounted for the prow pieces, so I had to trim off a few mm at the front of the pattern, but no issues otherwise. So far things are working out.
But I can see that the top parts of the bulkheads are indeed too thin. They will not take the load of forming a 1 mm ply bulwark pattern, even if there are many of them!
My solution will be to cut out braces for the correct distance for all of them and glue these in. After fairing, I will then form and attach the plywood bulwark (that I first need to tailor) and then remove the upper part of the bulkheads as planned all along.
BR
TJM
Edited by TJM
Always glad to see another schooner model coming along.
Your design process for making the parts with the laser is an interesting twist to the time tested scroll saw and wood method. It seems you are finding ways to work around the "traditional" problems, but discovering new problems that are inherent to the new method and materials.
I assume you are using MDF instead of plywood because it cuts better with the laser?
One way you can solve the problem of forming the bulwark pieces without breaking the bulkhead extensions would be to cut a new set of pieces that had the outer curves and spacing of the frames and that fit transverse onto the upper deck between the bulkhead extensions. These would be long rectangular pieces with the curves of the bulkheads on the ends. Fasten them to the corresponding upper bulkheads. Because they would be solid material between the bulwark curves they would not break under the forces of forming the bulwarks. Then they and the upper frame parts could be removed.
Here is a sketch of the idea.
The red piece is the "bulkhead support" shaped to fit across the bulkhead extensions.
Phil
Current build: USS Cape MSI-2
Thank you all for your interest, likes and comments!
@Dr PR, that is more or less what I have been doing. Since I will be cutting off the top part of the bulkheads anyway, I dont need them in 'good shape', I just need their outer curvature to be precise while i form the plywood. I have therefore just made some braces with the correct length and inner curvature that I glue in and everything becomes stable.
With regards to material choice, MDF does cut a little easier, but that is not the main reason for choosing it. There are no warping on the MDF sheets and it sands very much easier than ply when fairing the hull - those are my main reasons for going with MDF.
Log entry 2 - bulwark patterns
Things are progressing quite fast at this point, at least faster than I thought!
I cut out the bulkhead braces mentioned in the previous posts:
These were then glued to their respective bulkheads:
I also added a strip of wood down the middle to give some more lateral strength. After this, fairing was done quickly; the hull only really tapers at the prow and stern and very little material actually needed to be removed.
Using the initial cardboard bulwark templates, I made some modifications at the prow to the patterns, cut another cardboard template and made the last small modification to the cut file. Here are the final 1 mm ply sheet:
It includes the 4 small cabin frames as well.
Instead of soaking in hot water and forming directly against the (braced) bulkheads, I just wetted the patterns an used a hot iron at the highest setting to shape the patterns off model. The fit came quite close and I could glue the patterns to at the bottom and then make final adjustments to their shape with the iron on the model.
In this way, I don't have a lot of clamping force needed to shape the patterns, which is good, as the frame is a bit too fragile.
You may notice two small notches in the patterns. These fit with registering 'pins' cut into two of the bulkheads. As no fairing is needed on these flat parts of the hull, it is a good way to ensure that the patters sit at the same height on both sides.
I also added the first two inner planking strips and to my relief, the hull frame is just strong enough to take the abuse of pinning, handling, etc. But I will use sturdier frame for future projects!
Lastly, I added the stern pattern. It looks askew in the stern photo, but it really isn't. I like to get this on to protect the stern frames from damage during planking.
Planking the first layer should be relatively straight forward from this point!
BR
TJM
Edited by TJM
Log entry 3 - learning 3D printing!
I got a small resin 3D printer for Christmas and have been spending the past month getting all the accessories needed and for moving both it and the laser into a new place. Most the setup concerns making sure there is adequate ventilation in place.
This the setup now and it seems to be working well!
The small very short 12 pounder canon needed for Elben was the first real test apart from a calibration print, mainly because it does not take too long to print.
I am a total novice when it comes to 3D modeling, so I had to find a base to start from. Luckily @thibaultron has made a masterclass in printing canon here: https://modelshipworld.com/topic/34442-3d-printing-cannons-in-resin
and he has also published a very comprehensive set of stl files of different patters and sizes of canon.
I have modified his Bloomfield design to match the dimentions of the short 12 pdrs I need.
In the first batch I printed, 2/3 came off their supports and I had to do a full vat clean - and messed up the pour, so I had a lot of cleaning to do!
The rest 1/3 came out mostly ok, but with a bit of the knob at the end missing.
I diagnosed the problem to be due to too little support area from the light supports I had used and therefore went with medium supports and more of them for my second try.
I was happy to see 30 out of 32 canon sitting on the build plate after 2.5 hours!
The last two probably got ripped off their supports due to a slight tilt on the build plate. But lots of supports are definitely needed!
I am using water water washable resin, so the initial wash is in water (all gathered in bottles for later safe disposal) and the a quick ethanol/isopropyl alcohol wash. Then a final 3 min alkohol wash in an ultrasound bath and drying.
Here are 30 canon being cured for a total of 5 min (probably too much, but I am being cautious here)
And the final result:
IMG20250126200619.thumb.jpg.870462074c26f9ad3d5840a276d9931d.jpgIMG20250126200612.thumb.jpg.67e35956d1ed395cce6dcdfd8d5245fd.jpgIMG20250126200653.thumb.jpg.cae4abca300f1be16b5a6c8c94d90a88.jpg
Here is the reference drawing of the short 18 pounder I used as a basis:
Now I just need to design the carriage...
I am very happy with how these came out! And a great success for my first efforts in the 3D printing department. I am looking forward to trying out different things.
BR
TJM
Edited by TJM
Great work!
The Elben is a nice choice for a model.
This ship from my hometown (Altona is now a district of Hamburg) also belonged to the (German) Schleswig-Holstein Navy between 1848-1851, which makes the schooner really interesting for me.
51 minutes ago, wvdhee said:
Wow, I shouldn't have followed you here, now I want those tools too! 😅
Hehe, I mean, the laser is a bit expensive, but the small 3D printer really isn't! It is just a bit of a learning curve to get it working and cleanup, safe disposal of everything that has been in contact with the resin is a bit of a hassle...
BR
TJM
Do you have a higher resolution or larger, picture of the above drawing? If, so I will draw you a 3D print file for that specific cannon.
Ron Thibault
Wow, thank you Ron! That is very kind of you! I am afraid it does not get much better than that, but the full version has a scale that will be useful. This is an image of a short 18 pounder from the Lougen-class brigs, and I will simply scale that down to a 12 pounder for Elben.
This is the full image:
The original file is here: https://api.rigsarkivet.dk/ao/v1/images/31915669
There is also this one with a top view:
https://api.rigsarkivet.dk/ao/v1/images/31915695
And this one with higher resolution but it has the standard and the short 18 pounders on top of each other:
https://api.rigsarkivet.dk/ao/v1/images/31915697
Will these together do?
Please note that a Danish foot ('fod') is 0.3139 m!
Again, thank you so much for offering to make 3D drawing of this!
BR
Thorbjørn
Oh, and I just remembered: I believe the canon had an 'eye' for the breach rope not shown on the drawings above!
Here are a drawing and a painting by the famous marine painter C. W. Eckersberg, showing (likely) this pattern of short 18 pounder canon on the deck of the corvette Najaden:
fb494c34k_KMS2060_tif.reconstructed_tif.thumb.jpg.e4496ef6c203c0fecdeae8dcd0f0c485.jpgfig.-1-Najaden.thumb.jpg.d3c0ef27e3393cce838f2d10038827e0.jpg
BR
TJM
Edited by TJM
It is interesting how the gun tackles appear to be tied round the cascable. I have seen that a few other places.
Also that cleat on the deck and that sideways pin rack like thing attached to the mast are both really interesting. What is the dating of this drawing do you know?
It is from 1833, https://open.smk.dk/artwork/image/KMS2060 . Eckersberg had full access to the wharfs at Holmen and often sailed with the navy to paint various scenes. His painting are likely very accurate, as he was very interested in the ins and outs of the sailing ships of the time and spend considerable time studying them here are a few more paintings from this trip aboard Najaden, of the ship itself:
Christoffer_Wilhelm_Eckersberg_-_The_corvette_Najaden_under_sail_-_Google_Art_Project.thumb.jpg.fbbd33fdc6e482bfc09d70c0f2cfc907.jpg
Eckersberg_CW_-_Korvetten_Najaden_under_sejl.thumb.jpg.f0b617d56b452623349dbec3830733f4.jpg
Christoffer_Wilhelm_Eckersberg_-_The_corvette_Najaden_in_rough_seas_-_Google_Art_Project.thumb.jpg.e361179fd48a7d2cebbe23997657f31f.jpg
He would take a ship boat and sketch the ship from that.
@Thukydides, I just went through the drawings I have of Najaden and it's sister Diana, and the vertical pin rack at the mizzen does not seem to appear on the drawings.
There are two more copies like these, but they show the same. But then again, the skylight above the cabin (cahytten) depicted in Eckersbergs paintings are also not in these drawings. These features were likely added between the 1820 launch of the ship and 1833 when the pictures were painted.
Very nice so far, but you might wish to look at how deck planking was actually laid before doing the weather deck.
Thank you for the feedback - I have tried to do the planks as realistic as I can with the information I have.
Apart from glancing at the Vanguard Models kits I have (Flirt and Sphinx) I have these contemporary drawings of deck planking, although for much larger ships than Elben:
They are from the frigate Rota 1822 and the 3rd rate Dronning Marie 1824.
I have used the drawing of Elben which shows the outer plank and one along the gratings:
And i have placed the plank ends above where the beams are shown on the plans.
The inaccuracy I know for sure I have in the current top deck is that I have not included the nails that are not at the plank ends. There should be two nails on all planks at all beam positions.
I actually made the drawing like that, but found it became to busy/crowded. The Vanguard Models laser etched decks are correct in that way, but they have a more subdued brown tone. Mine get very dark, almost black and I was afraid it would distract too much.
But I could just add those nails again and do another top deck. Perhaps I should try and then decide when I can make a direct comparison.
If there are any other obvious inaccuracies that could be addressed, please ket me know.
BR
TJM
Edited by TJM
Interesting project! Something that has been on my wishlist for decades. I actually looked at the original drawings nearly 30 years ago in the Rigsarkivet in Copenhagen, long before they became available as digital copies.
As @Chapman said, she has actually quite a history, starting off as a Danish customs cutter and border surveillance ship on the Elbe river. At that time the king of Denmark was also the Duke of Schleswig and of Holstein, so that ships from these Duchies that encompassed all the territories north of the Elbe river, with the exception of Hamburg, flew the Danish flag (until 1864). There have been several disputes over the status of these Duchies within the state and Danish nationalists had lobbied for their de facto annexion, although legally they were part of the German Association (Deutscher Bund). This culminated in several wars, most notably the Three-Year-War of 1848 to 1850 and then finally the war of 1864. But this is a complex story, with ethnic Danes and Germans on both respective sides, which was finally resolved by a plebiscit in 1919 that led to the modern borders. Anyway in the course of the conflicts ELBEN/ELBE changed hands a couple of times, being integrated into the shortlived Schleswig-Holstein Navy.
In the course of these conflicts also the armament changed. I haven't read about it recently, but I seem to remember that she was only lightly armed for peace-time duties on the Elbe river. When she became part of the SH Navy, they were scrambling to find guns for her. I wonder, whether there are not drawings for the guns in question in the Danish archive. There are drawings for barrels and for carriages.
Three publications may be also of interest in this context:
 STOLZ, G. (1986): Die Uniformierung der Schleswig-Holsteinischen Marine 1848-1852.- Z. für Heereskunde, 326/327: 100-103.
STOLZ, G. (1987): Die Schleswig-Holsteinische Marine 1848-1852.- 141 p., Heide/Holstein (Westholtein. Verlagsanst. Boyens & Co.).
STOLZ, G. (1990): Historische Stätten der Marine in Schleswig-Holstein.- 133 p., Heide (Westholsteinische Verlagsanstalt Boyens & Co.).
I am looking forward to more progress on this project!
I admit that I had never expected anyone else to have heard about this little Schooner, much less considered building it! That is amazing 😃.
Indeed, the loss of Schleswig-Holstein is probably the biggest trauma in recent history for Denmark. The effect cannot be overestimated. Every Dane hears about this period multiple times in school, but I think not too many appreciate the importance for the forming of the current nation.
Denmark's power had been declining for 2 centuries at this point, first with the loss of the southern Swedish provinces and then with the almost complete loss of the Navy in the Napoleonic wars which also led to the loss of Norway. Denmark was already at this point a small country with just a few oversees possessions. The loss of all of southern Jutland in 1864 was a massive blow to the national pride. Denmark lost 40 % of its land (non-overseas) and 38.5% of its population, going from 2.6 mio to 1.6 mio people.
It is also interesting that all of southern Jutland below Kongeåen was lost, as the northern part of Schleswig was a de jure part of the kingdom, unlike the southern part and Holstein, which were not part of the Kingdom proper, but owned by the king (it is a strange and complicated setup that went back many centuries).
Denmark became in effect one of Europe's smallest nation states after this, and we were close to bankruptcy too.
It informed the neutrality policies of Denmark during the Great War and the 'acceptance' policy during the occupation of WWII. In fact, Denmark did not engage in any active wars again until 1999.
I had not considered that the ship Elben would have been transferred to the SH navy after 1864, but that makes total sense.
Regarding armament, I only know that it was designed for 8 short 12 pounders - whether it was ever armed with that is not certain.
I have not been able to find any drawings of these guns in the archive - many others, but not these. That is not to say that they are not there! I just haven't found them 😃. However, their length in calibres seem to be the same as for the short 18 pounders above, which were widely used on many different kind of ships, so I am quite confident that it is just a question of scaling them down to 12 pounders.
Edited by TJM
Quote
It's been a few years since I researched the Elbe/Elbe. I haven't come to a final conclusion about the cannons either. Another possibility besides cannons might be 12 punds lug mounted carronades, system 1833.
There are surviving examples of these.
Quote
Disse 30 pd . kanoner var konstrueret af sotøjsmester Miehelsen
i 1833 , og de indgik i et skytssystem omfattende 60 , 30, 24 og 18 pd . støbejernskanoner samt 12 pd . karronader.
Quote
These 30-pounder cannons were designed by naval engineer Miehelsen in 1833, and they were part of a defensive system comprising 60, 30, 24 and 18-pounder cast-iron cannons as well as 12-pounder carronades.
source: http://marinehist.dk/MHT/1980-3-MHT.pdf
I just looked at my records on the Elben/Elbe.
I wasn't sure if the 1833 cannon system consistently produced all calibers only as cannons. From what I found, see above, the short 12 pounder must have been a carronade.
When the ship was taken over by the Schleswig-Holstein personnel in Altona, 8 "12-pounder ball cannons" were found stored there. This probably refers to the carronades of the 1833 system.
Thanks for looking ito this! I read that as well at some point 🙂. It is just that the text on the drawings usually distinguish between short canon and carronades. There were several foundries in Helsingør and Copenhagen at the tine, so even if they were trying to systematize, I am not sure it is possible to rule out other sizes being produced. I also think that Elben may be a bit too early for the 1833 system.
But it is of course possible that the short canon on Elben was actual carronades. Their use and powder charge would have been very similar, it is only a matter of the shape of the barrel and carriage.
At scale, the deck plank fastenings would be all but invisible. Nail ends were usually covered by wood plugs that matched the planking.
Thanks! That is a great input!
I can make two engraving runs, one for the nails at much lower intensity. Or I can of course forego the nails entirely. I will run a few tests 😁
Log entry 4 - more canon and carriages
It has been a little while and it is time for a few updates.
I have almost finished the first planking of the hull, but I am missing the last two planks - I will show some pictures in the next update.
In the meantime, I tried to create a carriage as best I could from the drawings and Eckersbergs paintings and drawings. There is a bit of guesswork, but I am quite happy with this look.
I considered making it from laser cut wood, but decided to try to 3D print it first.
However, in my excitement I forgot that I was actually modelling the short 18 pdr! So I didn't scale it down to 12 pdr size... But I decided to print some barrels at the same time, so I got a bunch of 18 prdr barrels and carriages that fit together:
I think it will work nicely with the 3D printed carriage when fitted out with eye bolts and painted, I just need to scale it down to 87 % size for it to be a 12 pdr instead!
Here is a comparison of the new 18 pdr and my previously printed 12 pdrs:
I will be back with another update on the hull planking soon.
BR
TJM
Log entry 5 - first planking layer done!
Alright, the first layer is done! Here is the current state, before any sanding:
It was a very easy hull to plank, with quite gentle curves and relatively little tapering needed. This is my third time planking a hull, and this was definitely the easiest yet. Also the smallest, which helps.
It looks a bit rough now, before any sanding, but looking down the hull, I think it will be easy to sand it and the lines are very nice as you turn the hull in your hand (if that makes sense, hard to explain...).
I also dry fitted the keel, made from 3 mm pear, which fit in very nicely:
After sanding, I will glue this in, and then it is on to the second planking!
BR
TJM
