The building berth is developed for construction of type-setting hull in length to 1 metre (for example, kits of type Montanes, Victory, Superb, Vangard, Astrolabe, etc.). The design allows to fix reliably and precisely keel and bulkheads in the course of assemblage of the hull, its covering and installation on the hull of details. The building berth consists of the basis (the laminated parquet board 1000х380х14mm) on which are established:
- Directing for fixing keel (an aluminium corner 40х20х2 mm) with cuts for bulkheads (cuts are made under concrete model, in this hull Montanes-OcCre);
- Figured directing on which in the course of installation of bulkheads the carriage (plywood of 10 mm, figured laths) with a dural plate regulated on height , located at right angle to keel (for installation and fixing of bulkheads moves lengthways keel);
- Lateral racks (a board 20mm) with moving possibility lengthways keel and it is perpendicular to it (for hull fixing);
- Parallel clips (an oak 20mm).
Depending on a stage of construction of the hull those or other details of a building berth are applied.
Best regards,
Garward
Is under construction Montanes
Ready models Golden Star Corsair San Francisco II
Bronze 24-pdr canone Le Fleuron
Bronze 24-pdr canone Le Fleuron (second version)
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Nice ideal. Way better than that stupid flare a frame piece of junk that you see at time. Glad I never bought one, thought about it way back when but at least that is not one of the dumb things that sit in a box in the corner LOL.
Wacko
Joe :D
Go MSW :) :)
Hi, Wacko Joethanks for an assessment! The building berth really turned out quite convenient, I use it with pleasure and is happy that in due time didn't buy the ready design which is available on sale :) .
Best regards,
Garward
Nicely done and thank you for sharing it with us, Garward.  A lot of people, I'm sure, will be glad to see this.
Nice design Garward.
Michael
Hi, Mark, thanks for the comment!
Best regards,
Garward
Very nice build board.  Looks like it's very accurate which is so importand when squaring frames.  Thanks for posting your pictures.
Hi, Bob, many thanks for an assessment!
Best regards,
Garward
Michael
Thanks, Michael!
Edited by Garward
Best regards,
Garward
A good, clever design that mate, thanks for posting it,
Phil,
Hi, Phil, thanks for the comment!
Best regards,
Garward
looks like im stopping by the hardware store tonight. love your idea
Eric
Current build(s) ;
AL San Francisco II
http://modelshipworld.com/index.php?/topic/862-san-francisco-2-by-eric-al-190-sport29652/
MS Rattlesnake
http://modelshipworld.com/index.php?/topic/868-rattlesnake-by-eric-model-shipways-164-sport29652/page-2
Sitting on the shelf : MS Constitution, MS Sultana,
Wish List : MS Essex, Confederacy, and Syren, and a Victory kit by someone ?
"80% of the time it works every time."
Garward,
 I certainly like your build berth, and look so much more professional than the commercial items.
I like to suggest you to post plans for us to build such, if possible.
Looking good!
Respectfully
Thanks for the comment!
Best regards,
Garward
Garward,
Looking good!
Hi, Per, thanks for build berth assessment! I didn't do for build berth of the present drawings as a design quite simple and I managed at construction by several pencil sketches. For orientation the main sizes are specified in the description, but it isn't obligatory to adhere to them, each modeller can make build berth under the model.
Best regards,
Garward
I did buy a "Fair a Frame" and u can start a fire with it, if u have matches.  Garward my next kit build will start with your build board.
Dave
No problem can be solved from the level of consciousness that created it.  Albert Einstein
And you won't regret because it isn't necessary to keep mind how to fix model.
Best regards,
Garward
