Looks great Markku!
Cheers
GEORGE
Great update, Markku !!
Your gun-deck looks fantastic .. you are making me re-think my decision to not to do the internal decks.
CaptainSteve
                        Apostol Felipe (OcCre)
                        HMS Victory (Constructo)
Sure it's a good idea to make at least part of the gun deck there. Mine will be mostly covered with the main hatch, but I like the fact that there still is a deck under it. It kind of makes the ship more realistic.
Markku
Current build:
MS - USS Constitution 1:76
Previous builds:
Corel - Flattie 1:25
AL - Mare Nostrum 1:35
Revell - Dom Fernando II e Gloria 1:200
Revell - USS Enterprise 1:720
Trumpeter - USS California 1:700
Thank you Tom.
No, there will be no cannons. Just stairs down and maybe a capstan if it will be visible, don't know yet.  ;)
I'm adding outboard planksheers now and next will be the cannon boxes.
Markku
Current build:
Previous builds:
Looks like all the frame-work that's left is the gun-ports Markku! She looks great!
Cheers
GEORGE
Thank you George. Yes, the gun boxes will be soon in my working table. Some small strips also need to add, and I thought maybe couple planks of bulwark planking to make the bulwarks stronger.
Markku
Current build:
Previous builds:
So I found out the bulwark planks are supposed to be 3/64" x 1/8" based on directions, but in reality they are too wide to fill the height of gun ports, where should be 4 planks:
So to get the real dimensions, those planks need to be tapered thinner, like this, original ones on the left:
Now my 4 planks fill the height of gun ports. And here we go, first planks:
End result in bow:
Markku
Edited by M. Pajulahti
Current build:
Previous builds:
Nice job figuring out those plank widths Markku!  You're off and running. :)
GEORGE
  • 7 months later...
It's been a while from my last post, so it's time to continue this build again.
I've added the outside planksheer and 2 ceiling planks above it.
And now it's time to start making the gunboxes! Here we go...
After adding the outside planksheer strip, it's very easy to find out the right position for gunboxes. I used one strip to transfer the marks:
And same here. This is how I know the distance of gunports goes right:
Nice row of gunboxes there already. Not glued yet.
Markku
Current build:
Previous builds:
Lookin' good, Markku. Good to see you back at it.
CaptainSteve
Markku,
Your build is looking great and I will be following in your footsteps with my build. Keep up the great work you are doing!
Ken
Current build: Maersk Detroit"
Future builds:  Mamoli HMS Victory 1:90
Completed builds: US Brig Niagara, Dirty Dozen, USS Constitution, 18th Century Armed Longboat
https://modelshipworld.com/index.php?/topic/11935-uss-constitution-by-xken-model-shipways-scale-1768/
  • 11 months later...
Wow, is it really been almost one year since my last post? I need to post something new :D
So... the planking has started. Here are some photos :)
There should be 4 planks in row between gun ports, so I've sanded the planks to get perfect fit:
...And so the planking continues.
Markku
Current build:
Previous builds:
  • 10 months later...
Thank you Steve.
Well, there should be more curved on the stern. On the plans it's pretty curved under the main rail. And comparing to lasercut topgallant rail -part, which is a lot more curved, but nothing I can do about it anymore.
Other thing what i've been thinking is those bulwarks in the midship. On plans they are solid, but in the real ship they are removed, which seems to be common way to do it in models. As i am building this in current (after 1870) version, maybe i should remove those also?
Markku
Current build:
Previous builds:
I've been doing wales now. And added one hatch to gun deck. It might be visible thru the companion ways, or not, but it's there now. :)
Markku
Current build:
Previous builds:
Wales are done! :) Now i can start the actual hull planks on the bottom. For me, trickiest part was the stern where wales has very extreme twist and tight angle, but sanding them very thin they did twist better.
Markku
Current build:
Previous builds:
