I painted my masts ochre and the yards black. I think if I were to do it again I might paint the mast bands black instead of the ochre for a bit of contrast but this was not a fancy boat. She was a working "girl".
Mort
Current Build - Caldercraft Diana
Completed - Artesiana Latina Swift, Harvey, MGS Prince de Neufchatel, Imai USS Susquehanna, Mamoli Constitution, Rattlesnake per Hunt Practium, Caldercraft Snake, Diana, Caldercraft Victory, Kammerlander Duke William
Waiting to be Launched -  Bluejacket Constitution
Proud member of The New Jersey Ship Model Society, Model Shipwrights of Niagara, Model Shipwrights of Western New York and Offshore member of the Society of Model Shipwrights
Sorry I forgot to add that I think I would have used the kit supplied dowels were I to have not painted the masts and yards.
Mort
Thank you Mort, I've covered her outer bulwarks with a walnut-like varnish and I'm thinking to use walnut dowel for the unpainted parts of the rest of the masts to match the bulwarks outer color.
I'm seeing that Jason has used walnut parts too, but I'm not so sure which option is more historically suitable...
Thanks.
Edited by Stergios
Vasileios has posted me a couple of photos illustrating the in black and yellow ochre of all the parts of the masts of Victory.
Jim has painted this way his model.
I still have the tendency to leave the upper parts unpainted just for better matching with the bulwarks, but I'm debating myshelf between the dowels of the kit and the aftermarket's walnut...
Edited by Stergios
Thanks.
I think you are safe doing what you think looks best - check out the pictures of the HMS Vanguard kit from Amati - it shows the unpainted topmasts as well.  http://www.historicships.com/TALLSHIPS/Amati/HMS%20Vanguard%20AM130004/HMS_Vanguard.htm
As far as historical accuracy - I'm sure painted and non-painted are equally appropriate.  The reason for painting I think is more to mask the lighter colour of the dowels which don't really match the walnut.
Your Snake is looking great!
Cheers,
Jason
In the shipyard:
Thehe a slight deviation of the mainmast (I think...) to the right.
Any idea on how to fix it?
I've already fixed the mast-base rings on the deck...
Hi Jason, glad to see you back and thank you!
As far as your model, have you use walnut aftermarket dowels for the middle and upper stems of the fore and mainmast?
Thanks again.
Thanks again.
 Yes I did - as well as the jib-boom on the bowsprit.
Cheers,
Jason
In the shipyard:
...waiting for the aftermarket walnut dowels for the middle and upper 1/3 of the masts (and why not, for the yards too...).
Edited by Stergios
Finally the walnut dowels arrived at home...
I'm trying to establish the best orientation especially to have both rectangular edges at the same planes.
Those custom made pencil markers are so helpfull...
Hi guys.
I'mo about to drill the 1,5 mm holes at the base of the topmast and topgallant mast to pass at a later stage the 1,5x1,5 walnut strip fid dowel.
The instructions call for drilling the hole at a height of 10 mm from the bottom of each dowel but when i'm looking the plan i'm measuring the height at 6 mm....
Do you consider that difference as a basic/critical for the next steps and what's the "right height" for that hole?
Thank you.
Stergios
Edited by Stergios
The 1.5mm dowel that is passed through the hole will rest on the trestletree assembly of the mast below and is in essense what 'holds' the mast in place. What you will want to do is ensure that the hole is at the correct hight so that the transition from square profile to round profile of the mast sits within the wooden brace that holds the two masts parallel.
Thats probably about as badly explained is it could be but my brain seems to have gone on holiday today.....
Jim
Current builds:
HMS Snake
HMS Hood
Mechanical Solar System
Completed builds:
HMS Ballahoo
I agree with Jim -  Its better to get the mast positioned correctly and determine the position of the hole than rely on the 10mm indicated.  The plans are not accurate enough to blindly rely on them.
Cheers,
Jason
In the shipyard:
Jim, Jason and Mort
thank you, again for your support!
Wanted to pre-shape all the yards of the ship. Giving a rectangular shape to the mid-section of each dowel and planking it with walnut thin planks was so easy. I liked Jason's technique so I decided to follow that way even with 4mm dowels...
It took me a while to manage the respective "height" for the hole form the base of the topmast.
After all everything was fine.
That;s for the foremast
Edited by Stergios
Week-ends, when I'm at home I find time to make progress...
Today is time to align and test foremast and mainmast parts respectively.
These are the top mast and topgallant mast of the fore and main masts respectively... post-944-0-59109800-1410695978_thumb.jpg
and the mainmast  post-944-0-66148100-1410695991_thumb.jpgboth dry-fitted...
Those parts came out of the box with some holes in need of reinforcement...
I'll place a thin layer of glue or something to withstand the later tension of the ropes...
That's another testing of the lowermasts post-944-0-29211600-1410696651_thumb.jpg
And for first time this is a dry-fitted placement of all the masts (except the bowsprit) of the model. post-944-0-56174700-1410696658_thumb.jpg
I think I'm ok as far as the posterior tilting/inclination of the masts is concerned...
Edited by Stergios
Well, there is a slight inclination of the mainmast to the right or of the foremast to the left....
Any additional idea (except Jim's opinion to file the base of the dowel) to handle this "little" problem?
I think Jim's suggestion should work just fine...is the difference noticeable to the eye?  Bubble levels can have a tendency to induce panic and call out problems that at not that noticeable.  When raining masts on my Snake, I tried to look at the whole mast together (main, top, and topgallant) as there were likely small bowing of the down not noticeable individually, it also helps ensure that you don't fix a problem that creates a larger one down the road.  Just my experience!
Cheers,
Jason
In the shipyard:
Thank you Jason
I've tried to demonstrate the visual feeling of the difference (see post #510).
It's a slight difference but I'd like to reduce that problem... post-944-0-28359600-1410716687_thumb.jpg
That's a posterior view of the modelpost-944-0-01122900-1410716690_thumb.jpg
To tell the truth, I'm thinking again to change and paint in yellow ochre the topmast and topgallant mast...
Before my final decision I'll apply a layer of mat varnish, hoping to reach a more warm-like walnut appearance....
