Now I'm one turn before the trimming of the ratlines and I'm thinking already what to do next...
...continue with the other/upper thirds of the fore, main and mizzen masts or fix the bowstrip and its relative fittings?
If you have any experienced idea on this, please show me "the way"...
Thanks
Stergios
Edited by Stergios
Futtock positioning looks much better Stergios, nice work.  My suggestion would be to get the bowsprit installed before you go any further.  Looking great!
Cheers,
Jason
In the shipyard:
Thank you Jason.
My only cause for concern is that i've already assembled all the wooden parts (even the minor) of the bowsprit and i fear of accidental crackings...
Looks good Stergios.  How firmly built is the the jib-boom?  It may be much easier/less risky in the long run to remove it and replace later.  My experience was that bowsprit can take a few of the inevitable knocks but the jib boom is a bit more susceptible.  I think Jim managed just fine though.
Cheers,
Jason
In the shipyard:
Unfortunatelly Jason, the jib-boom is firmly fixed, from the beginning...
I'll try to take my protecting measures for it. Thanks
For example, I think to use this "bumper" protection...
...now, to be on the safe side and to avoid such bowsprit possible injuries, I'm thinking to continue with the fitting and rigging of the upper thirds of the fore and main masts....
Now, ready ro glue and fix the middle thirds of the fore and main masts...
I don't take the risk to have exposed the whole bowsprit-unit for so long time, so I prefer to continue "upwards"...
Edited by Stergios
The plans really can't help me to understand the way I have to fix those "H" blocks in place...
Using eyelets, like I did with the sisters or simply tie them using black rope?
Thank you mates.
I attached those particular blocks with rope to the mast above the shrouds (looping it around it), the block was then lashed to the shroud to keep it in position.
If you look at post #703 in my Snake log, 7th photo down that may help you visualize.
Cheers,
Jason
In the shipyard:
I also attached mine with rope.
Mortr
Current Build - Caldercraft Diana
Completed - Artesiana Latina Swift, Harvey, MGS Prince de Neufchatel, Imai USS Susquehanna, Mamoli Constitution, Rattlesnake per Hunt Practium, Caldercraft Snake, Diana, Caldercraft Victory, Kammerlander Duke William
Waiting to be Launched -  Bluejacket Constitution
Proud member of The New Jersey Ship Model Society, Model Shipwrights of Niagara, Model Shipwrights of Western New York and Offshore member of the Society of Model Shipwrights
Jason, Mort, thank you mates.
From #703 pics can't realize enough the technique, but I can undestand that it's better to deal with the shrouds first and attach those blocks later, in situ.
Right?
I also attached with rope. Definitely a situation where caldicraft could have improved their plans and shown the blocks to be attached to the masts on the mast plans not just the rigging plans. Had to do it in situ with all the shrouds in place. Not easy.
Edited by jim_smits
Jim
Current builds:
HMS Snake
HMS Hood
Mechanical Solar System
Completed builds:
HMS Ballahoo
Finally I've found a way to attach the 3mm blocks [symmetrically and in advance] on the masts, by two knots of capstan.
Pics to follow... :dancetl6:
Edited by Stergios
Hi I am building HMS Cruiser and your help and that of Beef Wellington has been invaluable, thank you.  I have built the masts and am ready to start the rigging but I have found the instructions not at all helpful, where should I start, I guess from the stern?  Should I fit the stunsail boom first?
Thanks
I thought I would be able to add an image to show my progress so far but not successful, I have also completed the Ratlines, and yards, but not added the yards yet
Dave
To answer my own question, and thanks Mort for your input. :)
I started with the lower fore yards working up and worked towards the stern, I had already positioned the Stays, if I was doing it again I would leave the stays until the yards were positioned.  Once that Gaff and driver booms were completed and rigged I went back to the bow and completed the bowsprit and spiritsail yard.
Apart from a few adjustments and positioning of anchors I believe I will have completed the model.
Next job will be to add a captain and perhaps a few crew and a ships boat. :dancetl6:
Thanks to all who have helped with their pictures etc :D
Thanks
Hi Davemc
Sorry for the delay, I was away from home...
Any pics to provide from your log?
Have you completed the model?
How longtime have you been engaging with her construction Davemc?
Cheers
Stergios
Edited by Stergios
hi, I have been working on the Cruiser model on and off for nearly three years! Yes it is now complete and installed on its base.
I tried to post an image but not successful, I will try to put one in the Gallery area.
best wishes
Dave
