Hi guys, I'm wondering about that almost vertical strip-like plank indicated by the arrows on the plan at the most aft edge of the outer bulwarks.
Have you realized, what exactly it is? It is a walnut profile strip, I can;t understand by looking the plans/manual....
Thank you.
Hi
On my Snake I have installed it as 4mm walnut plank. It is sitting flush to the transom and between the wale and the bulwark rail. Haven't really got a decent image as I'm out at the mo.
Thank you Jim.
I've additionaly fixed (and secured, I think) the stropped deadeyes into the channels slots using epoxy glue....
Finally the slots are closed using custom made walnut 1,5X1,5 strips, next step black-painting of the channles using my favourite Vallejo's matt black..
Finally all the aftermarket 32's carronade kits arrived, so I prepare myshelf to deal with the weaponry.
In the mean time I have received the aftermarket 2mm double blocks for the rigging of the guns.
I hope those blocks of 2mm to be an interesting alternative option.
Edited by Stergios
In the mean time I have received aftermarket 2mm double blocks for the rigging of the guns.
They'll probably look slightly better to scale than the 3mm blocks I used.
Good luck with the new carronades...!
Jim
Current builds:
HMS Snake
HMS Hood
Mechanical Solar System
Completed builds:
HMS Ballahoo
Hi, I try to fit the side fenders but no "room" to place the single, most anterior of them cause the the posterior edge of the foremast channel ends in a point which intersects the small rectangular opening of the bulwark (can't remember its name...). The plan of the kit is definitely so different...
I'll leave the single fenders/chesstrees(?)  unmounted for the mo and I'll see later what to do about
Have you positioned the channels correctly, I seem to remember on by Snake they fitted ok?
Norman
Norman
Current build Trumpeter Arizona 1:200 with White Ensign PE and a Nautilus Wooden Deck.
Built Caldercraft Convulsion, HM Brig Badger and HMS Snake.
Awaiting - Zvelda HMS Dreadnought planning to get the Pontos Deck and PE Upgrades, Panart 1:23 Gun deck model and couple of the cannon kits Manatu - French siege mortar, and American coastal cannon.
Norman
Oh yes Norman, I've chequed their position a lot of times...
I'll try to upload a couple of pics to see better the misalignment....
Thanks
This is the point of concern.
As you see the only way (to have the fender at least flush with the vertical border of the small opening) is to place it underneath the posterior edge of the foremast channel.
As I'm still in a preliminar stage of the build I don't know what's the functional use of that fender/chesstree....What do u think, to fix it under the posterior edge of the channel or leave it for a next phase of the consrtuction?
Thanks.
Stergios, I think you want the chesstree to extend between the wale and the capping rail to be authentic.  There is a hole for a piece of rigging that goes through the top of it, and you should check to make sure that this hole is clear of the channel to avoid problems later.  My initial quick thought would be to suggest filing down the end of the channel a little so you can accommodate the chesstree between the channel and the sweep port.
Cheers,
Jason
In the shipyard:
Thank you Jason
I feel that the hole is important for a kind of support for the rigging of the main tackle. I think I'll leave the chesstree unmounted till that stage of rigging to accomodate better its position and the possible sanding of the channel....
Cheers
Today, I plan to sand down the channel and attach the chesstree in place without open the hole on it.
I'll drill the hole later on just to realize first the appropriate point/height to pass the rigging of the main tackle.
I have attached a picture of my Snake showing where I fitted my fenders. Hope it helps?
Norman
Norman
Same here to all.
Mort
Current Build - Caldercraft Diana
Completed - Artesiana Latina Swift, Harvey, MGS Prince de Neufchatel, Imai USS Susquehanna, Mamoli Constitution, Rattlesnake per Hunt Practium, Caldercraft Snake, Diana, Caldercraft Victory, Kammerlander Duke William
Waiting to be Launched -  Bluejacket Constitution
Proud member of The New Jersey Ship Model Society, Model Shipwrights of Niagara, Model Shipwrights of Western New York and Offshore member of the Society of Model Shipwrights
Started to unpack the fittings of the kits of the aftermarket 32's carronades...
The quality of the 2 mm walnut is so poor, that I can;t stand it, and I paid a lot of money for all of them !!  :angry:  B)
The JoTiKa office is back open today after New Year as I spoke to them earlier. You could try calling them and getting replacement walnut parts?
I'll try to talk to them Jim, even I'm not so hopeful....
I have to say I have always found Caldercraft/Jotika more that helpful on any quality issues and very responsive in replacing parts.
Norman
Norman
I can't wait for another 15-20 days to have back the [in question] replacing walnut parts. I had to wait 25 days to receive all the seven kits in two posting periods...
I'll try to fix the problem by my own to a couple of the kits. The other five left, are fine.
Edited by Stergios
I'm about to create the hole for the rope on the cannons using the 0,8 mm wire.
May I ask you Jason, how have you bend and cut/shape those wire hole-curvatures for all the barrels?
Thanks!!
Thanks!!
I used some round nosed pliers and bend the wire around by hand, it could work just as well with something else, just make sure there is room for the rope you'll use for the breeching rope to move through easily.  Wire was bent into a hoop and then I cut out about 1/3 with wire cutters. Each was done somewhat by hand and trimming after each was test fitted.  Some are better than others, but I would say that the exact shape is hard to see when everything is done so don't obsess over it.
Cheers,
Jason
In the shipyard:
Thank you Jason, I think you told me to use cyano glue to fix them on the barrels, is thsi correct?
Correct Stergios, CA worked well.  I had another look at them last night, it probably closer to 2/3 that i cut away, but I'm sure you'll figure it out pretty quickly after a few attempts.  Its fiddly, but I did try to file the cut wire to the right angle so it had the maximum area touching the barrel.
Cheers,
Jason
In the shipyard:
Thanks again Jason!
Another one question: how have you fixed the deck blocks (walnut part No 1 ) on the deck of the model, using PVA or any kind of glue or drilling the deck for every kit to pass the 1,5 mm rod through each deck block and fixing them in place?
Sorry to ask you so many questions :( but to my knowledge you;re the first and the only one who purchased those after market kits.
Cheers.
Stergios
Thanks again Jason!
Cheers.
Stergios
Please ask anything, hope I can help.  The blocks were glued to the deck using CA glue.  I prefer to use PVA when I can, but CA was simplest option because the deck had been varnished and PVA will not work.  When you fix them, you'll want to try to get them as centered as possible otherwise the carronades will be at odd angles when you come to mount them.  Look forward to seeing your results.  All the best.
Cheers,
Jason
In the shipyard:
Hi mates, a question in brief...:
how can I measure the width of a rope/line of the market, I mean how can I make clear its width/diameter?
Thanks
