HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 69 donations so far out of 49,000 members - Can we at least get 100? C'mon guys!) ×
Great work on planking that keel Floyd, I'm impressed!
I saw Floyd mentioning a darker king plank. I did exactly that and it came out great (imho). And just like Floyd I also painted the hull first and when done mounted the deck.
Yves, I believe there is a retractable keel on bigger models, but not this kit. BUt I see what you mean.
Thanks Erik!
Dave I think he has you confused with me. Yes there is a retractable keel on my build but I decided to plank it over. I like the lines better this way.
Current Builds - 18th Century Longboat, MS Syren
Completed Builds - MS Bluenose, Panart BatteStation Cross section, Endevour J Boat Half Hull, Windego Half Hull, R/C T37 Breezing Along, R/C Victoria 32, SolCat 18
On the shelf - Panart San Felipe, Euromodel Ajax, C.Mamoli America,
Its a sailor's Life for me! :10_1_10:
Here's some more updates on the planking. I glued the rudder on also which was planked separately. This will probably be my last planking update until the 2nd planking is finished.
Nice work Dave, She looks beautiful
Best Regards,
Pete
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Herreshoff Buzzards Bay 14
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
Moving right along...further along than I thought I would be, but hey, I enjoy working on it. I finished the second planking. This is a shot right before finished. After meeting in the upper middle with as many whole planks I could, I only had to make 4 steeler planks for each side.
And here is the finished pic. I sanded smooth, and added some sanding sealer, and lightly sanded a little more. Also, added the upper rim. I'm getting close to paint. But that has to be planned out well before starting the steps.
Hi Dave, she looks great , Nice work
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Thanks Pete.
I also changed my mind and realized I should lay the deck before paint, since the blue will overlap the top, the finish will get dulled while sanding the deck. So, it'll be easier the tape off the deck and paint afterwards.
Edited by LMDAVE
Good Call Dave, She is looking Sweet
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
I started on the decking. I'm duplicating what I saw on another build, I'm using left over walnut planking as the center deck strip, and using the supplied clear for the rest. I had to doublestack the 0.5mm walnut strips so they would be level with the 1mm deck planks. Once all sanded smooth and a coat of sealer is applied over it, it should have a real nice appearance. The outermost plank  around the whole perimeter of the deck will be blue, once the hull is painted.
Edited by LMDAVE
So here is the finished deck. I applied one coat of sanding sealer, and sanded/smoothed it out afterwards. I like the results, but may sand down more for a more uniform finish and tighter walnut line. But, like it like this also.
That look really sharp Dave, great job on the planking the deck is great.
Michael
OK, so here is the scariest part of a build for me. Paint. I feel this is where you can screw up all the work done up to this point.
I first had to mark the waterline, and this was giving me some trouble since I was holding the boat in the supplied holder and it wasn't staying level...but I got a mark and taped off the bottom.
From there I had to tape off the deck I just finish but leaving the outer plank exposed as part of the hull cap.
I decide to handle the white lines (water line and upper trim line) by painting white, then back masking off the two lines. 1/8" for the waterline, and 1/16" for the upper trim.
But, When I painted the white primer it shown me all my imperfections, so there was filling and sanding again, and reapplying the white.
Masking off the lines, the water line look twice as wide, I applied a second layer over the bottom over the first layer so blue couldnt leak through below the white line.
and finally the upper hull blue. I was so nervous getting to this point already, but fortunately the blue covered smoothly and evenly .
I may have some touch up to make on the blue, which is what is preventing me from removing the tape and finding out how good my lines came out. If I have to spray any more blue, then these need to stay on.
I've been practicing with different poly clear coat and see how I will finish up the whole body. That part still scares me also since I'm not sure on which clear I'm going with and if I'll spray or foam brush apply it.
Stay Tuned.
Edited by LMDAVE
Looks Good Dave, Water lines can be trickey . I understand wnat you are saying (Painting is still difficult for me )
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Dave - What paint did you use? I have been trying to decide on what shade of blue I will use. Looks real clean.
Thanks Pete....I'll be taking the tape off this evening when I get home.
Hey Floyd....I manage to get good finishes from basic rattle cans. This blue is a VALSPAR Paint + Primer (Royal Blue) from LOWE's. As long as you have a smooth foundation, you can get a good finish. I'm just hoping the clear coat covers well...I'm test that on a spare piece of wood first
Edited by LMDAVE
Well, here's the finished product of paint. I probably do some more polishing once the clear coat finishes curing. The upper trim line looks more wavy in the picture than in person, maybe the pixels of the picture. But I like the contrast of the gloss body and the matt finish deck. Time to start reading ahead and moving on with this fun build.
Hi Dave , The paint job looks great , nice work
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Wow...what a beauty. It definitely looks very professional and certainly like the real boat. The clear coat will make the hull resistant to all kind of abuses, and minor scratches. It really brings out the beauty of these timeless shapes and curves.
Truly stunning.
Yves
Edited by yvesvidal
Thanks guys, I want to get some better pictures in better light to show the colors better.
The clearcoat used was Polycrylic, a water based polyurethane, in the hopes that it wouldn't yellow the white lines, and it's held up so far. But, I probably should have let the basecoat blue cure fully before going over it, and by fully cure, I mean like 3 days to a week, I waited a day and a half, and a few of the spots cracked a little when the poly was dry, but I was able to sand it out inbetween poly coats.
10497146_10152607492754610_3477680450767
Edited by LMDAVE
Started with the deck furniture now, here's the main deck house. A used an HO scale (1:80) figure to be cute. I did have the sitting area white cloth, but it got dirty so fast I painted is brown leather.
Man I started before you and look how far ahead of me you are. I want to paint my hull so bad.
Looks Great Dave, she's coming together quikly . Nice work
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Thanks guys, and Floyd, yeah I've been moving right along with this one. I could say because it's more than half the size of yours, but its probably because Ive been into the build.
I added another hatch that has the instrument gauge on it. This time put a dime in the background to show the scale of this and how small, which is a struggle with detail. OF course I had to use a paper decal, which I then coated with some flat lacquer to see if it would blend in and look real. You can always spot something like that. But I'll leave it.
