Hi Brian,
Thanks I will be adding four cannons to the starboard side. I added a set of stairs where the fifth one should be that also messed up the location for the boarding stairs. I am moving them between the third and fourth cannons. One small change can affect a lot of other things.
Mike
I have been working on the head rails. The drawing showing the lower knee made a good pattern and fit nicely. The upper knee drawing did not make a very good pattern so I divided it into three pieces using the drawing for the end pieces and used some modeling clay to form the middle section. I carefully removed the clay and traced the outline on a paper pattern after some trimming the center section fit.
very nice build Mike,
the ship Looks great with the cutaways (deck and hull) on the port side
Nils
Current builds
-Lightship Elbe 1
Completed
