Sincere thanks for your warm comments. This is my very first experience in the shipmodelling. Chuck Passaro did the great job. All I need is to follow his instructions. Posting more pictures and preparing myself for the deck construction.
Treenails were made of brown fishing line 0.55 in diameter.
Then the wales were fixed.
Thank you Mr. Helmsman.
I think preparation work makes the difference. Will always recomend using balsa on POB models. Dust is the only problem with this sort of tree. I've learned many new words when my wife found the dust even in the soup. He-he.
Making the cap rail is a serious problem as it needs edge bending. My solution was to create cap rail in the bow part from separate planks.
When glued and sanded they look like one solid wood. Black paint will finish the process.
Transom cap rail made of special wood which bends easily. I'm not sure what kind of wood it is. Just bought it in a hobby shop.
It would be wise to install the sheaves before planking the hull. Now I have to think how to show them without spoiling the planks.
Edited by VasaRodin
I'm starting to buy into the balsa technique.
Jeff
Ready with paintings and think there will be more coats of black. Different details are finnished such as ladders, simulated sheaves and so on. The 0,6 mm plywood list was installed on to the deck. Also testing how the deck should look like. Next steps are the deck and copper plates so it'll take muuuuch time. Perhaps I'll leave the hull without copper plates cause the wood looks fine for me. But I didn't decide yet.
Edited by VasaRodin
Your Syren looks great! Very well done!
Thomas
Current Built:   Model Shipways  Syren  (US Brig 1803)
Last Built:        Anfora (kit bashed)  Ictineo II  (1st steam powered submarine 1864)
I have a first big question. According to the plans the first row of the copper plates starts from the keel and goes up to the waterline. But I've studied different sources and saw that the first row started from the waterline and went down to the keel everywhere. Does our Syren has her own way of coppering?
