Yes, 10 more to go but they should go quicker. I'll let you know how the MS tumbler works. I have it assembled and ready for a trial run.
Current Build - U.S. Syren
2nd Build - HMS Bounty Launch
When organizing your thoughts, never use the Dewey Decimal system.
I tried mine out and put a pic on my Confederacy log.  It actually does improve the appearance of kit-supplied blocks to some extent.
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Whew, the carronade assembly is done! They're dry fitted for now because I'm thinking about assembling the gratings & hatches then taping a piece of fine grit sand paper on to the deck in order to get the right camber. Then I can permanently install the caronades and break out the rigging thread!  :)  :)
Richard
Beautifully done, Richard. Your Syren is looking very good!
Thomas
Current Built:   Model Shipways  Syren  (US Brig 1803)
Last Built:        Anfora (kit bashed)  Ictineo II  (1st steam powered submarine 1864)
Very nice.  thanks for all the pictures.  It gives me ideas concerning carronades on my next build the Niagra.
John
Current Current Builds:
US Brig Niagara on my website
FINISHED BUILD LOGS:
New Bedford Whaleboat - page on my Morgan Website:  http://www.charleswmorganmodel.com/whaleboat-build-log-by-john-fleming.html
C.W. Morgan - Model Shipways 1:64 http://modelshipworld.com/index.php?/topic/1785-cw-morgan-by-texxn5-johnf-ms-164-kit/
USS Constitution - Revell 1:96 http://modelshipworld.com/index.php?/topic/1796-uss-constitution-by-texxn5-johnf-revell-196-kit/
website US Brig Niagara Model http://www.niagaramodel.com
website Charles W Morgan Model http://www.charleswmorganmodel.com
website PROXXON DISCOUNT TOOL STORE http://proxxontoolsdiscount.com
Thanks John, I'm glad to help out. I almost went with the Niagara but I found a better deal on my Syren. Once you start your Niagara I'll definitely be sitting in the front row on that build.
I also went into the forums and found some good posts on carronades and from what I read I might go ahead and put in the breeching rings. But my first hurdle is to figure out which thread is the .028. I tried using my micrometer but the thickest tan thread I have measures at .023.
Is the breaching thread the thickest of the tan threads?
Anyway, here's some pics of my slow yet steady progress
I have all my carronades finished and dry fitted and a couple of the hatch & grate assemblies complete. I Still need to drill the holes for the masts. It looks like the plans show the foremast perpendicular to the deck. I'm I correct?
Also, on the main hatch just foreward of the mainmast is the grating supposed to be in two sections and what is the purpose of the two square holes on either side? I've never seen that and I cant seem to find out why. (Unless, of course, it was to keep the sailors on their toes  :P
Richard
Edited by kscadman
Richard-  wrap your thread around a dowel 10 times and then measure that.  It will be a more accurate reading.
Augie
Previous Builds :
OK, just wanted to check on mine.
Yes, the foremast is at 90 degrees to the deck.  Only the main mast is raked (aft).
The holes in that hatch are where the anchor lines will end as that is where they disappeared to go below deck.
Edited by Augie
Augie
Previous Builds :
Your Syren looks great! Having gratings and completed guns on a deck always makes a big difference in the appearance of a ship model. Can't wait until I get to this point myself!   :)
Thomas
Thomas, I totally agree with you. It can get a little disheartening staring at an empty deck. I cant wait to see how you do on yours!
Richard
Hatches & grates are finished. Companionway ledge & shot racks are installed. Mast holes are drilled (tricky) but I think I have the mainmast rake correct. Just need to glue the cannon balls in. (Already lost one - I'll have to add it to "Whats on your floor" post)
Now its time to quit procrastinating and rig my carronades.
Richard
Looking great.
Can't see if you've actually drilled the holes in the black painted portion of that one hatch.  Check to make sure the specified rope fits nicely in there as you'll need to bend it 90 degrees into the hole to make it sit right.  By the time you need to do that the deck will be very busy and the rigging will be busy as well.
Augie
Previous Builds :
Beautifully done, Richard! It is a pleasure to watch your progress!
Thomas
Thank you Thomas for the compliments, they are always appreciated. Especially considering the BIG mistake I just found and need to correct.
Augie, THANK YOU, THANK YOU, THANK YOU!! If you hadn't mentioned the anchor lines I never would of realized my mistake till it was too late. Once I re-read about the anchor cable I discovered that my grates were backwards!!
Ok, momentary delay on the carronade rigging whilst I fix "ye olde" mistake
Richard
Edited by kscadman
Ok, hatch grate mistake has been fixed, cannonballs have been installed and I've got the companionway walls glued together. But mainly I've been able to rig my first carronade.  :)
Here's some pics and I need a little feedback on how they look before I glue the tackle and make the coils. I read a post by dirk on breeching rings on carronades and after a little reasearch I decided to go ahead and add the breech rings."They really are there, just a little hard to see them in the photos.
Any thoughts?? First time rigging so I'm kinda tiptoeing thru this.
Richard
Well, I have not rigged any carronades either yet, so I may not be the best reference, but it looks to me like you did a very nice job!
Thomas
Outstanding carronades as well as the build.  Love the details.
John
Thank you, Augie John & Thomas for your comments.Their just what the doctor ordered as I continue to make another 70+ hooks.
Richard
the details are what counts, unfortunately when it comes to cannons and carronades it is so repititious you never think you'll get through it...keep it up
John
Very true John, very true. But I do have deck furniture to work on when it becomes too repetitious.
Hope your enjoying your trip.
Richard
Very nice.  And that's a good view of your fine work on the margin plank and treenails.  I'm smiling!
Augie
Previous Builds :
Well, that looks like a lot of tedious work  :) . . . but the result is well worth it! I really love your coils!
Thomas
Thank you Augie Thomas, Charley, & Joe. Slow and steady seems to be the order of the day. But I think I might want to take more pictures as I go. I get to see the mistakes. I tried to make sure the "hold down rings?" were directly behind each carronade, but to me they seem a little off center, both on the carronade and its partner across the deck. I'll just have to be more attentive as I go.
Augie, glad to see your smiling, but are you sure its just from my work? its been rumored by another member "realworkingsailor" that your training some paper cannonballs from your Conferderacy on others in the fleet.
Charley, Ive attached some pictures to help explain how I made my coils.It probably isn't the best way, or the easiest but its what I came up with.
First thing was to cut a piece of 1/4" dowel. then I made 2 discs out of clear plastic. I used some "Midwest clear plastic that I had at hand. (I took 2 pieces and tried to glue them together with my carpenters glue and it didnt stick after letting it cure for an hour so it was good to use)
I glued 1 disc to the dowel and drilled about a 1/8" deep hole in it that is the same diameter as the post I used (scrap length of the supplied eyebolts) I layed the other disc on top, center punched it then drilled a hole in it.
To make the coils I just soaked a length of thread (2-5/8") in diluted glue leaving about an 1/8", 3/16" out of the glue then I put the dry end into the hole in the dowel. I inserted the post into it holding the thread by friction. Then I put the second disc on top and put it in the pin vice. Then I put the pin vice in my "third hand" and twisted the dowel section to wind it, keeping a steady pressure on it. I let it dry then removed the pin vice and top disc carefully (if not then you get a really nice spiral) I remove the coil from the center with a pair of tweezers and cut the excess from the underside and end and then voila! a coil is made.
Sorry the explanation is so long but I hope this helps.
Richard
