HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 69 donations so far out of 49,000 members - Can we at least get 100? C'mon guys!) ×
Hi Dave
Thanks for the info.
Yes similar, I am basing the rope size on 7" rope for preventer and 10" forestay
My Endeavour is 1:51 scale so the preventer should be:
7" circumference x 25.4 = 177.8mm divided by Pi (3.1416) = 56.6mm diam. divided by 51 = 1.11mm
10" circumference should be 1.58mm
Cheers
Steve
Edited by shipaholic
Current Build: HMB Endeavour 1:51 (Eaglemoss part work)
Previous Builds: USS Constitution (Revell plastic) HMS Victory 1:96 (Corel) HMB Endeavour 1:60 (AL)
Sorry Steve, I missed the scale of your build which is indicated at the bottom of your posts.
You're on top of it.
Dave R
Dave R
Measure twice, cut once.
Current Build: HMB Sirius 1786 - Flagship of the First Fleet to Australia (Scratch Build in the Shipyard)
Finished Build: HMB Endeavour 1768
hello, ref the pliers for making rings with wire, micro mark US, also Wubbers tools,but price may be better in hobby/craft stores in the jewelry making section,as shipping is very high from the US even to Canada,Edwin
Awesome! I have already sourced my elastoplast!
Thanks for the hreat tip.
Yesterday I received the new rope I ordered from Chuck and its the right size for my stay.
I spent the afternoon making the fore stay. I have put the details in a new post in the masting and rigging section for those interested in how I did the mouse.
I am happy with the result and using the correct size rope means it doesn't look too bulky at the mast head.
Cheers
Steve
Looks absolutely brilliant. What size rope for the forstay and pendants please?
Mouse looks great to me.
Edited by mikec
Thanks Mike
There's some conversation between Dave Row and I in previous posts about the rope sizes. If you are using Syren rope the forestay is 1.37mm and the preventer stay is 1.14mm. The pendants are a bit smaller than the shrouds, about 1mm
Steve
You are doing an amazing job with the rigging. I am starting work on this stage too.
Can you please tell me what size rope for the futtock shrouds and catherpins are you using?
Thanks for the info. I will post some pics of my progress soon. i am a little bit behind you.
She is looking fantastic. How are you going to rigg the mainstay? To an eyebolt in the deck? Or as per the freemantle replica?
Thanks Mike
I am still deciding which way to go with the mainstay, I could be wrong but I think the replica vessel is the correct way, so I will probably do it like that, a collar around the bowsprit. I was going to do it like the AOTS and have even fitted a large eyebolt, but have changed my mind as I cannot find any reference other than the AOTS describing mainstay collars secured to eye bolts in the deck
Cheers
Steve
I reckon you're right, it doesn't make sense to have it where the AOTS says it goes, it was a bugger to rig and gets in the road.
Greg
Yep thats what I have discovered too. I will do The same. i will go and have a look what Lester did and Pat
Fantastic work. Your shrouds look brilliant! I am roughly at the same stage as you. I find it fasinating watching your progress, and then seeing mine, using two completely different approaches- trying to achieve the same result.
Mine is totally expeimental (using composit materials) so far it seems to be working.
I will post soon.
Thanks Mike yes its interesting how each of us develop our own methods to achieve something.
Whilst on the subject of the shrouds;
Another one where I believe the AOTS is completely wrong. Marquardt states in his commentary that Endeavour had two topmast backstays because Cook wrote in his Journal that both backstays broken - hello! I think Cook might have meant both the starboard and port one. He has changed the size of the main mast deadeyes in his drawings to suit his argument. If you look at both of the original draughts there is only one small deadeye for the topmast backstay whereas AOTS shows two small deadeyes.
Also (correct me if I'm wrong anyone) AOTS shows the wrong arrangement for the topgallant shrouds. The topgallant shrouds are led through holes in the trestle trees down around the futtock staves and down to the top where they are lashed to an eye secured around the lower topmast deadeyes.
I think you guys must hate me for pointing out faults with AOTS, sorry
Cheers
Steve
