I am building wooden model houses. In my current project i need a number of planks of width 0.02". For this tiny dimension i am using boxwood. To rip the planks i have a proxxon ks 230 mini table saw. I am struggling to achieve the exact width. It starts out correctly but gets thinner or thicker along the length. I have tried both to saw the thin plank between the blade and the fence and to have the plank "open" on the outside of the blade.
Is this saw suitable for the task (i have a challenge) or is this a tool problem?
What sort of blades are you using?
Michael
Peaksol,
I don't have a Proxxen but a Micromark which is similar.  Here's my method:  http://modelshipworld.com/index.php/topic/9312-need-advice-with-byrnes-saw/?p=274646   It's repeatable and consistent.  Just make sure that the blade doesn't get hot since it will distort.
Thanks all for feedback!
I am using a slitting blade.
My fingers are my featherboards, maybe a bit dangerous but it works......
When I read the instructions, I see that I may have done the error of pressing sideways towards the blade rather than only pressing sideways before the wood piece reaches the blade.
The methods I have tried are both the Bill Sorenson method and the other one.
What remains to try is the tape or similar to make more space for the ripped plank between the blade and the fence.
An update will come when I have tried that with the correct pressure.
I tried a thin piece of wood glued to the fence.
See pic no 1. Here I rip a 1" X 0,2" boxwood down to 0,2" X 0,02"
Then I made a small and right size block to apply the pressure correctly.
I also changed the blade. It was dull.
After this it is quite accurate and consistent, although it becomes slightly thinner along the length.
I also made a mini-mini construction to rip further from 0.2" X 0.02" down to 0.02" X 0.02".
See pic no 2. The "featherboards" are boxwood, the rest of the construction is scandinavian pine.
Sounds like uneven pressure on the piece being cut plus using a slitting blade you have to be consistent with the feed rate so the blade does not warp or shift on you.  I am using a Preac all the time and this is what I found out with slotting blades.  They were designed for cutting metal and are very thin. David Warner of Warner Woods gave a demo on sharpening his slotting blades and this helped keep everything running smooh also helped with the accuracy of the cut as well.
David B
I agree with what David said.   Also, your block on the fence is too far back. It should end just past the front edge of the blade.  I reset my block depending on how high the blade is out of the saw.  The blade should be about 1/16" above the top of the wood.  What seems to be happening is the back of the blade is causing the plank to rise up and be thinned down after the cut.  It's a trial and error process to find out what works best for you.  Just make sure to keep your fingers away from the blade.. getting cut by them tosses blood everywhere and they hurt a lot.  I found out the hard way during a moment's inattention.
Try using a thicker blade. If you are using a very thin slitting blade, it gets hot very quickly and soft - subsequently it bends and you get uneven cuts.
Thicker blade won't heat up quickly, will stay cooler and will cut evenly, even though you'll waste a bit more material due to thickness of blade.
Edited by Dziadeczek
On the Preac the blade is thin. As result I was careless and cut my finger. A fine slice and I learned about using a push stick or block even on something as small as a 3 inch blade. You can do some damage to yourself. End result on both the Preac and the Byrnes saw I tend to use push blocks.
David B
Edited by dgbot
