Everything posted by TBlack
Yes, but you didn't need to do that, did you! You nailed it again! Confidence, my friend, confidence. TB
Keith says: That was a bit too close for comfort - about 3/8" I say: Looks like you nailed it! BTW, I don't understand why eccentric rings rather than smaller "centric" ones? Tom
Actually, Steve, the photo makes the new color lighter than in reality. As you say, beauty is in the eyes of the beholder! Tom
- 341 replies
- Sophie
- Vanguard Models
Steve, Thanks for your research and diligence. I think, however, that I need to make the red darker, rather than lighter. I've added some brown to the red and gotten a shade that I can accept. Tom
- 341 replies
- Sophie
- Vanguard Models
Thank you all for your thoughts. I've mixed a little brown into the red and come up with this that I think will work:
- 341 replies
- Sophie
- Vanguard Models
So now I'm rethinking the red. Perhaps a little too bright. It's splotchy and needs a second coat anyway, so maybe tone it down a little. If I were Chuck P., I'd know just the right mix of paint to make it happen, but I'm not so stay tuned!
- 341 replies
- Sophie
- Vanguard Models
OK, so you're threading the ratline thru a shroud at 1:96. The shroud is, therefore, mighty thin. How do you keep from sticking your finger with the needle? TB
Keith, Nicely explained. And do I understand that you thread the ratline thru the shroud, not just touching it? Tom
Thanks, Keith, bro, and all you others who are taking your precious time to follow my modest attempts. I do think that I've figured out how to accommodate an aft cabin and quarterdeck without altering the brig's lines too much. There are still a couple of issues that I need to sort out. Not the least of these is here: The joint with the stem is disturbing, and I can't get it any closer than what you see. The waterline will come just at the notch, so not to worry below that. Above I'll have to fill with pear paste. And then not look too closely!
- 341 replies
- Sophie
- Vanguard Models
A little more progress. I've gotten the rest of the siding on both port and starboard plus molding strip along the top: As I mentioned in my previous comment, the gun ports on the kit are higher than the painting. Also, you'll note that I finally attached the keel. She sits in the cradle much better now. Tom
- 341 replies
- Sophie
- Vanguard Models
Keith, bro, You're setting a standard for family modelers that I'm having difficulty meeting. Can't you make a mistake once in awhile? Tom PS I don't care what you think; mom clearly loved you the best!
Keith, yes, she’s coming along OK now. I keep thinking I’m at the point when I can start following the kit instructions, but then remember some other detail. If you go back and look at the book cover photo in post 128, you’ll see that the hull planking is different than the kit which is straight pear. Also, the spacing between the tops of the gun ports and the top rail is smaller in the kit than in the photo. So, I’ll have to make some adjustments.
- 341 replies
- Sophie
- Vanguard Models
Stern gunports installed. I kept knocking off the top rail, so I removed it until I'm finished with the quarterdeck detail:
- 341 replies
- Sophie
- Vanguard Models
Of course, my first idea was to donate the books to the NRG library only to discover that we had dissolved the library several years ago (I'm not really up on current events). In terms of an heir; it's actually my mom's dad who has given me the ability to do this. Also, I need to thank "anima" (Jeff Wall) who actually made all of this happen. Tom
Amen to that (see HMS Sophie)! Tom
- 200 replies
- Whaling Bark
- Charles W Morgan
So, the final resting place is your family room? You need to have a lot of "open houses" so a broader audience can appreciate your art/craftsmanship. Tom
