Everything posted by TBlack
Well, I'm getting there. This is not as good as Alan O'Neil's (which is the same scale), but as close as I'm going to get (I think this is the 8th attempt!).
- 341 replies
- Sophie
- Vanguard Models
Rich, I figured that a wheel is about 2-3" thick, which in my scale is about 1 mm. I can't get that small and have room for spokes. My spoke grooves are 1/32" square, so the total thickness will come out to something like what you are suggesting (2.5mm), depending on how fine I can sand the rim. BTW, I had been trying to get to the thin size, using my end mill. Too brutal. Your suggestion of sanding to final shape is the way to go. Tom P.S. Do you have a brand of cigar you can recommend? Mine don't have the cedar separator.
- 341 replies
- Sophie
- Vanguard Models
Rich, Your wheel looks spectacular @ 1:48. Mine is 1:64, 75% of your size which means the rim of the wheel has to be 1/32" square, and I can't get the wood down that fine on either the lathe or the milling machine without it tearing up.
- 341 replies
- Sophie
- Vanguard Models
Brief up-date: still working on the wheel, following Ed Tosti's instructions from Naiad. I can get to this step, no problem: Then he has me cutting off a cap and setting it aside, so I can make slits for the spokes; again, no problem: Then I cement the cap back on and hollow out between the wheel's rim and the center hub. And here is where lies the problem which is the same as with the previous (4th) attempt: As you can see, the rim (1.5mm wide) keeps getting torn up. The 4th attempt, above was in the mill, while this one was in the lathe. Unless someone has a brilliant idea, I'm giving up and buying a wheel. I've spent too much time on this and I need to move on.
- 341 replies
- Sophie
- Vanguard Models
Fabulous find. Thanks for the reference, Bruce.
- 341 replies
- Sophie
- Vanguard Models
Bruce, the pages on my edition don't match yours. I have found the "man overboard" incident on page 285, but I cannot find the reference to the launch and cutter. Additionally, a jolly boat is about the same size as a cutter; could they be one and the same?
- 341 replies
- Sophie
- Vanguard Models
Just an up-date. I'm on my 4th attempt at the ship's wheel. No point in showing you my failures. But the issue is using the right wood (I tried cherry; no good). I'm reluctant to use boxwood because the color is not what I want to see, so I'll try pear next (Ed Tosti recommends it as a substitute). And it also turns out that the glue is critical; not only its application, but also the type. Here's a photo of my last effort:
- 341 replies
- Sophie
- Vanguard Models
Tom, I have two daughters; and it is true there will be more, but it will be fun for you. Remember that she will have a husband, but you will always be THE DAD!
- 200 replies
- Whaling Bark
- Charles W Morgan
Tom, You aren't the only one who can't say no to daughters. Besides, your work on those items is spot on; now all you have to do is walk her down the aisle! Tom
- 200 replies
- Whaling Bark
- Charles W Morgan
Brass Strip Stock
TBlack replied to Chariots of Fire's topic in Metal Work, Soldering and Metal Fittings
Roger, I'm understanding that when you feed the brass/plywood through the saw blade that the brass is on the bottom? Tom -
Nothing in the book mentions the number of boats, so I’ll go with 2. Tom
- 341 replies
- Sophie
- Vanguard Models
Bruce, I've looked at all the photos you've provided and I can't see any gaps in the cabin assembly. Aren't you being a little hard on yourself? And are you telling me that to get chrome it's better to use Testor's spray rather than the 2 step process? Tom
- 296 replies
