Everything posted by Chuck Seiler
Charlie, Great work so far. When I started my SULTANA several years ago, I ran into similar issues. I determined that all the stuff you are doing was too much like work and opted to trash the solid hull and make it using the bread and butter method. Having learned a lot since then, I would do SOME things different, but not the overall plan. SULTANA makes a beautiful model and in my mind is a great starter (except for some of the solid hull issues). I need to pull mine out of storage and finish it up. Keep up the good work. I will look in from time to time.
Steve, They come down to the top tree trestles ( I think that's what they are called. Since army guys built it, they are call "those thingies that stick out at the top of the fat pole".) I notched the ends and let them run free. From there, they are secured to the main shrouds at the futtock stave. On the starboard side, it is the top rung. On the port side it would be directly across....the only rung (watch out for that next step!!!) Gotta go. Dr. Who is on!
- 308 replies
- finished
- model shipways
Aw maaaaaaaan. The model is at work. I'm going to have to look at the map...er, ah plans. I'll be right back.
- 308 replies
- finished
- model shipways
Steve, I'm not sure I understand the question. From your picture in post 235 it looks like your shrouds are already attached. The model is looking great!!! Next step....the awning assembly. Remember, it's not symmetric. It looks kind of cock-eyed...but that's what happens when army guys build boats...er, ahh...I mean....
- 308 replies
- finished
- model shipways
Mast and Spar replacements
Chuck Seiler replied to thomaslambo's topic in Masting, rigging and sails
Crown has masting sets? Wow....ya learn something new every day. -
Carl, To expand what Mick said, the full frames consist of up to 9 different pieces; 5 on one face and 4 on the other. Those little short nibs at the end of the forward halves are killers! Kurt, C'mon. You move into management and suddenly you can't build a fully framed model? Pfffff!!!! What else are you doing?
- 504 replies
- washington
- galley
Thanks Mick. The one you are showing is transom piece 1. I was more interested in piece(s) 5. ...or are you still getting to that? Chuck
- 504 replies
- washington
- galley
Mick, I was looking at your previous posts and the part where you are working on piece 5 (wing transoms) caught my eye. At first it appeared you were going to alot of trouble to make a simple piece. As I looked closer, I noticed it was a compound curve...significantly so, it would seem. Hoping the plans and/or the monograph went into more detail, I consulted those. No luck. Am I just being thick, or is this a difficult piece? Could you go into a little more detail as to how you made it? Does anyone else have any input?.
- 504 replies
- washington
- galley
Mick, Doesn't the liver of sulfer discolour the wood?
- 504 replies
- washington
- galley
Steve, I would say the lift lines for the upper yard is smaller than the lower yard. This is based on the fact that the associated blocks for the lower yard is 7mm while the upper yard is only 5mm. I pegged my yards into place using small wooden (bamboo) pegs, about 1mm in diameter. Since your model is twice as big, you have a bit more leeway.
- 308 replies
- finished
- model shipways
When you say 'spar' do you mean 'yard'? I am looking at my PHILLY 1 right now and I cannot tell if the lifts for the upper yard are smaller than the lower. It appears so, but I need to wait until I check the plans to be sure. HOWEVER..... I would recommend you move the blocks for the upper lift lines further up the mast. From what I recall from the plans (and what I see from PHILLY 1) these blocks were too close to the yard. The whole set up didn't look right and in my opinion (as well as others) would not have allowed for proper lift of the yard. I think it should be 3/4" to an inch above where the yard is. Again, I will check my plans when I get home.
- 308 replies
- finished
- model shipways
Mick, What did you use to bolt your keel pieces together? Is that copper?
- 504 replies
- washington
- galley
- 308 replies
- finished
- model shipways
Have you been practicing your rope coils? One thing you will have to think about is at some point you will be building the canopy. Make sure your blocks, etc are either above or below the canopy line (as appropriate).
- 308 replies
- finished
- model shipways
Thanks Mick. I noticed the earlier post, but for some reason thought you had abandoned it for the Saw method. I have used the saw method before with success. I even 'milled' my PHILADELPHIA gun carriages using it. I look forward to your work on the frames.
- 504 replies
- washington
- galley
That's what it's all about. I see you cut the slots for the frames in the keel, but I didn't see that mentioned. Did you cut them the same way as the slots in the deadwood?
- 504 replies
- washington
- galley
The situation I find myself in is that when I had more $$$ than experience, I purchased the Acra Plus mill along with the drill press option. Never used it. It has a wheel each for X and Y axis but a little crank knob for Z. This can be upgraded for a few dozen bucks. Now I am in a position where milling some joints and other things I cannot seem to do well with my other tools is looking like a viable option. Nothing fancy/nothing large. Going thru some of the old posts, I saw some comments from JPett. I was just curious if anyone else has experience with it. If I get good with it and find a need to go bigger (and live long enough), I will consider one of the larger ones,
Chuck, Thanks. It sounds like an easy modification. Mick, I'm looking forward to your build. I'm a month or two behind you. (But a year ahead of you building the companion PHILADELPHIA
- 504 replies
- washington
- galley
