Posts posted by cobra1951
No doubt. But it does look like you are approaching things in a very well considered way. I haven't been too active in either my building or my log due to some medical issues, but I hope to get along with it shortly. Hope my pix and problems are helpful.
Yes the pics and text on all the builds i am following are a great help. some of the problems are silly mistakes on AL's side, like giving wrong part numbers on some things, but i find reading 5 or 6 steps ahead in the instructions saves a lot of work later. and of course the help from build logs is invaluable, like needing to put a couple of grooves in one of the crossbeams for the pumps before you assemble all the decks permanently, ( I would have missed that and been fiddling to get it done). Good luck with getting back to your shipyard matey.
Hi Captain AL
I am following your build along with the other AL Bounty builds on MSW. I suppose this does give me an advantage with my build because i get forewarned of any problems others have encountered before me, and no doubt i will find a few of my own along the way
Hi Antony
Yes the slipway will keep the keel nice and straight and if any of the frames are slightly out it will keep adjustments down to a minimum (hopefully )
Hi Nirvana
Thanks for your comment, I agree with you that keeping the keel as straight as possible is a basic fundamental of getting a good model and cutting down on any hassle later on. Enjoy your coffee, just got myself some too
Wow Frank that sure is coming along nicely mate (Big thumbs up)
- foxy, Old Collingwood and mtaylor
- 3
Hi
This will be my build log for the Artesania Latina HMAV Bounty. It will be my first plank on frame model so wish me luck
The first thing i decided to do was build myself a homemade slipway to stand the model in as it gets built.
I got a plank and cut it to the size i wanted and then i cut two lengths of smaller plank to the same length. I then glued the smaller planks to the base plank with the Keel in between them (taking care not to get any seepage of glue into the centre slot. This will not only act as a stand but it will help to make sure the keel remains straight as i build.
The next thing was to cut out some slots crossways along the length of the slipway to allow the frames to fit in their respective slots
To make sure that the frames sat all the way down in their slots i took a spare 1.5mm x 5mm plank and layed it in the central slot of the slipway then when the keel was put back in it raised it in the slot just enough to stop the frames touching the base plank when they are fitted.
That's as far as i have got for now i will post again as soon as i start to build the keel and frame parts
- AntonyUK, bryanc, zoly99sask and 1 other
- 4
Coming along nicely well done
Thanks for the info, it was things like the cross beams and planking i was thinking about. Looks like the same method for me
Cheers
Hi
You have a great build there . I am going to be starting a build of the Artesania Latina Bounty myself soon and i am thinking about whether to paint or not to paint the keel, beams and frames. The reason for this is i am thinking that wood glue does not work too well on painted surfaces. Could you tell me how you found it with your painted model
Thanks
Hi
You're doing a great job on your build IMHO. I am going to be starting a build of the AL Bounty myself soon and one of the questions i have before i start is having painted the keel and frames what type of glue did you use as i suspect that normal wood glue needs to be applied to bare wood to make a strong joint.
I am planing on using Titebond on most of it, but also normal pva where a bit more time is needed to adjust things, and CA on the brass parts.
cheers
Wow that is some project you have taken on
The position of the whale looks spot on to me, nicely done
Great job Tim, the more you did the better it got
Hi Tim, i think Daniel might be right. Looking at the photo's of the actual ship the entrance port does look wider than the one on the model. Another reference is in the actual ship photo's the entrance looks almost if not the same width as a gun port. Something for you to ponder over i think
Nice neat job on the linings Tim well done
Amazing how adding a few more strips of planking in the form of a whale gives a hull a whole new look and feel. And it will look better again once it's had a final tidy and a coat of paint or two. Well done mate
- mort stoll, Shipyard sid and mdkboggle
- 3
HMAV Bounty By cobra1951 - Artesania Latina - 1:48
Forward and Aft holds deck bases fitted ready for planking.
I have ordered some Boxwood for the planking as i don't want to use Basswood for planking, i once experimented with different woods for planking and i found that Maple and Lime gave a really bad finish, As Basswood and Lime are basicaly the same (just named differently in different countries) i do not fancy using it, so once my Boxwood order arrives i will commence the planking of the hold decks.
