Peta_V
Members-
Everything posted by Peta_V
Second bulwark rail in place, it needs the final sending still. I have started planking the deck furniture. First latrine under the planks.
- 315 replies
- master korabel
- avos
@DPK I completely got your point and agree. The complexity of the build is quite high and it is more and more dificult once I'm coming to the details. I have one more question.... It is on more placnes but now I'm about to finish latrine and they have knobs, if I rememder correctly the number it should be 44 and 45 from photo etched plate. Both are full circles. It is meant to cut one circle and solder again or how should I progress There? If I do solder I would use the rounded wire instead of that part. Thanks for the advice! Btw thanks a lot about compliment regarding the build. Much appreciated! PetaV
- 315 replies
- master korabel
- avos
Bowsprit. It is carved from square stock. Lot of sanding again. I had to enlarge the hole in the bow to meet the dimension of the bowsprit. It took me while to get the right dimension and also right direction as bow sprit has to go through 3 holes that needs to be aligned. Once all is aligned the bowsprit can go through the bitt - > to the hole in the bow - > to the bowsprit yoke on the stem To its final position Quite a task I have to admit. Still I think I need to adjust the height of the bitt as the bowsprit points litlle bit down!
- 315 replies
- master korabel
- avos
Looking forward to see the result. I'm going to be jelaous 😭
- 31 replies
- master korabel
- avos
@DPK Hi mate, I have noticed something what I would improve. I have described it to the colleague Who is building AVOS and is not too far for this. Perhaps it is something you might be interested in? Thanks
- 315 replies
- master korabel
- avos
Hi Jim. Seeing your progress I have one idea how to make an improvement. Unfortunately for me it was too late when I have noticed it It is regarding inner structure of the gun and oar ports. In the kit this is done from plywood which for an eye is distracting as it has different lighter colour This should be fairly easy to improve and make it from pear as well so all is in same kind of wood. Instead of those parts I would use some spare pear wood from the kit. There is enough for that. And you would also need to adjust the respective frames. I would cut of the thin top layer of plywood and replace it with pear veneer (again enough screp wood in the box). I think this is fairly easy to do and it will look great on the model! Perhaps you could consider it since you are still OK to do this. I have noticed too late when I have the bulwark planking glued in place PetaV
- 31 replies
- master korabel
- avos
Hi Katoom, You are very right I hate to say it but RC will wait for me And she is not going anywhere I love this build so much that I can't stop building...... Thanks a lot for your kind comment, much appreciated! PetaV
- 315 replies
- master korabel
- avos
Did I say last time something about tiny? Well this is tiny. Belfry assembly. Tafrel is after 2 layers of oil and I added the decoration. First I have blackend it and then gave it a send with 1500 grit Sand paper so the brass re-appear in the pronounced areas
- 315 replies
- master korabel
- avos
- 315 replies
- master korabel
- avos
Before instalation of the bulwark rails I had to clean and smooth the gunports and oar ports The rail is made from 2 layers and each layer has 3 pieces of black wood. Again everything fits perfect which I guess should not surprise me anymore
- 315 replies
- master korabel
- avos
Finalization of the taffrel and counter. After one layer of oil. The surface looks very nice and it is very smooth Iron works on the stem.
- 315 replies
- master korabel
- avos
Ohh man... Please protect her and show where you (and if possible others) can enjoy! It would be pitty to let such a impresive model "Die" 👏
- 242 replies
- syren
- model shipways
Today I finished the wales and started finishing the taffrel with counter. This is propably most dificult part of the ship. First you have to cut the correct shape to wales so the counter fits without gaps. Second you have to shape the counter so it meets flush with the wales. Third the edge of the tafrel and counter can be planked. It is not easy 🙄I glued all the parts of rail but it needs a lot of sending still.
- 315 replies
- master korabel
- avos
- 315 replies
- master korabel
- avos
Rocket start! You will catch me very soon with this pace👍 Very happy to see another AVOS build!
- 31 replies
- master korabel
- avos
Hi Etsinko, Interesting technique, Just this morning I was preparing the wales and thought it would be hard to glue and do not mess the surranding planks with glue residual. This might solve my problem. I will for sure try out. Thanks. So far I use only PVA glue for planking and sometimes superglue where the plank did not stick 100% (which would be not possible using for wales).
- 315 replies
- master korabel
- avos
- 315 replies
- master korabel
- avos
I can only recomend to do so! I can't even explain how I'm enjoying this kit.
- 315 replies
- master korabel
- avos
- 315 replies
- master korabel
- avos
- 315 replies
- master korabel
- avos
