Clark
Everything posted by Clark
  1. Lily ornaments were glued on the hull. When finished, there were only 3 lilies left. Thus, the further ornaments must be made in another way. I am quite sure that I did not drop any of the ornaments. But I had to sort out about 10 of them since they were not fully casted.
  2. Thanks a lot Gimo, it really helps me. Thus, most of the force is transferred via the oarloops. If will probably simulate an additional leather protection between pin and loop. However, this will surely be some times later. At present I was wondering where to place the oar supports. Again thanks a lot Clark
  3. Hi Frank, just a short question. Hope you can help me. I am proceeding and started to place the oarlocks. But I was wondering about the Corel plan. It is shown that the oarlocks are on the stern side of the respective oar. I am quite convinced that they should be positioned on the bow side. Otherwise it would be impossible to transfer the force of the oarstroke onto the boat. I took a foto of the corel plan and simulated the correct (?) position of the oar in relation to the oarlock with a wood strip. I hope I could explain the problem. If yes, do you agree with me? Clark
  4. I was also wondering about the hatches and followed the Corel plan. I will probly copy your hinge idea. Have a nice time with your family! Clark
  5. Planking of the bow area follows a certain pattern. After tracing the plank outline onto wood strips, planks were cut and glued onto paper. To simulate caulking, I used small strips of paper glued between the planks. Paper strips were cut when planks were glued. Planks were then sanded and glued on deck as a whole block. Knees, edges and rails were glued after sanding and smoothing the contour. Cathead material provided by Corel was slovenly prepared. Size differs (I noticed that after cutting the slots for the achor rope). At this point I was wondering if Corel really put enough effort to provide the wood material, since it is not the first time I noticed such an inaccuracy. Catheads were made new form walnut boards. Cathead and metal enforcement were added. Unicorn ram at the head was “stabilized” by a conical support.
  6. Figurine looks excellent. Glad you managed the reattachment. Are you really sure you are able not to look at the ship for one week? Clark
  7. Thanks a lot. Maybe such a long narrow ship is easier to steer than a short one. Like an eight-man sculls. Clark
  8. Hi Frank, Most of the glue types will probably ve visible under the Mica. Do you have ever tried acrylic glue to be hardended by UV light which is very transparent at least to my experince. I do not know if it works with Mica and wood. Clark
  9. I was also wondering about the handling of the rudder tiller. Not only because it stretches into the kings area but also because it is very short. I would assume that there is a huge horizontal energy with the waves wich would it make very difficult to handle such a short tiller. Maybe there were additional blocks and ropes used to enhance the leverage. Is there anything outlined in the plans of Fleur de Lis about the rudder? Clark
  10. Thanks, Frank, for accompanying me. Maybe I made the mistake that I left the brass pieces too long in the blackening solution. They broke immediately when I tried to adapt them finally to the rudder. They were preadapted before putting them in the blackening solution. Although the upper hinge seemed to resist the blackening solution, I replaced it also by card strips to get a uniform appearance (photo below). It may be better to paint the hinges with email paint and not to use blackening solution.
  11. The brass pieces provided for the rudder hinges did not resist bending and blackening at least the way I did. Thus I replaced them by card strips. Stern part is now ready and I will proceed with the bow area.
  12. It really took some efforts to get the bending. Your way may be better. Luck and patience. Clark
  13. For adapting the arches covering the kings platform, I used and sanded the template provided by Corel before proceeding the way Corel manual suggests. This because the arches had to be put in line with the arches already glued at the stern platform. It took some time but it was the best way to fit the strips. Railings were fixed before putting the arch construction on. According to Corel there should be a window line between the railings: So far none of the Reale builders (fmodajr, bender, gimo) liked it. Me neither. I replaced it by some pillars.
  14. Hi Frank, I am almost at the same point you are now. When building the Xebec, I had the same problem but used the flexible wood and it worked, althought it took a lot of efforts to bend the ends. Nevertheless, stressing of wood was no problem. Thus I will probably rely on the the flexible ones. For that purpose, I checked the templates of Reale Corel provides (#233 and others). They are not completely in line when placed in order and have to be sanded. Did you have the same problem? I am a bit disappointed of the Corel material. Your solution seems much better than the flexible wood. Clark
  15. Frank, I was also wondering how to manage the problem of windows since they are visible from the outside only. Moreover, the false windows provided by Corel do not look very realistic. I do not like them. I will probable leave the space between the rails completely free. At present we all are watching the battle in your Country which will surely have a strong impact on Europe. Clark
  16. The floor will be covered by arches but I know that is there. Thanks for stopping by. Clark
  17. The king’s platform at the stern is ready. Compass symbol is surrounded by diagonal planking using mahogany and lime strips.
  18. For planking the decorative platforms at the stern, I used the material provided by corel. Since these platforms were the beginning of the officer’s part of the ship, I marked the “border” to the oarsmen part by a half round strip on the top and a concave one at the bow side. Clark
  19. Thanks for the excellent description and the ideas you are putting in your model. I will probably copy some of them if you dont mind. Regarding the length of the ship, I had already a discussion with my my wife were to place it. Discussion is not ready. Again thanks for the detailed description. Clark
  20. Thanks, I will probably proceed with the mahogany planking. Clark
  21. Forecastle with upper platform is ready. I used mahogany planks to get a contrast to the gangway of the oarsman und the lilies ornament. Unfortunately, it also makes the sander dust more visible.
  22. Thanks also for the inspiration. Is the Coureur you are building, the one of CAF/Tom? I am thinking about the next project. Clark
  23. I read the build log of Gimo who built the Reale back in 2013. He showed a nice suggestion to pep up the stern (kings?) platform. I also thought about planking the stern platform and decided to put a compass symbol on it, remaining planking has to be done in a diagonal shape. Template was drawn using Power Point.
  24. The outer platform is now glued. I had a discussion with Frank some time ago about the holes in the platform. He drew my attention to the fact that the shroud chains are led through the holes. Shroud chains contacting wood are probably not doing well on the long run. Thus, I simulated an enforcement of the holes. The outmost fixation of the outer platform is covered by a small brown/white strip 1mm thick and a walnut strip on the top. I put small “pyramids” on the stern and bow ends to cover the different types of wood. In the corel plans there is a suggestion to fix the blocks for slackening the fore lateen yard in the middle near the main cannon. This would not work since it would hinder managing the main cannon. Thus, I fixed it behind the main cannon.
  25. When do you start with Coureur? I have noticed that you are currently working on other projects. Clark
