mtdoramike
Everything posted by mtdoramike
  1. Well, my wife would answer with THOUSANDS of dollars because she is always pointing out that it seems every time I go to the store, I buy various types of glue. But I look at it more like how much glue do I use per model and that is any where from $100.00 to $200.00 depending on the size, complexity of the model and how low my stash of glue is getting. I use primarily CA glue and have for the past 15 years on well over 20 or so models and have not had any issues with it. But you must understand the basic principles of using CA glues, like fumes, quick set and the ability to make what ever you are gluing at bit brittle at the joint as well as over bloom. I used to use water based glues on hull and deck planking, but I found that it was very messy and would stain the wood, or would not allow wood stains to penetrate the glue and made the finish very poor. I also have CA fingers most of the time, so I know that I'm in the middle of a build. Mike
  2. I used some of the HMS Victory wood from the real ship that I received from England to fashion the bitts and the anchor davits from. These will be left natural to show the beauty of the wood. I hope to use more of the wood from the real Victory ship on other parts of the model, but it is VERY brittle and dry.
  3. Yep, I can tell it's a thrill a minute, especially with Constructo. But they do finish off to be a beautiful model. It's looking great so far. Mike
  4. very nice work. It also doesn't look like you had to shim too many frames. Mike
  5. I happily await pictures. If your Ana was anything like my AL Victory, you will have to shim numerous frames in order to get the planking to lay properly.
  6. They about 95mm or 3 3/4 inches long. But 4 inch boats would work as well. I also have contemplated replacing these with wooden life boats as well and have thought about scratch building my own. But with a bum ticker and limited time left I figured my time would be better spent doing something else and since this model is being built as a donation, I want to make sure I finish it while I still can. I also have another model waiting in the wings that I hope to have time to build as another donation. Mike
  7. Here is an updated picture of my progress on the Vic. Please excuse the mess. I try and clean up the work area once every couple of weeks. But when I do, I can't find anything for days afterward. I like to call my work area structured chaos. Mike
  8. Yes, it comes with three metal boats that require planking. The kit also includes sails, which is a major advantage if you intend to build it with sails. Most kits back in the day didn't include pre made sails. I got pretty good at using my wife's sewing machine and also hand stitching :rolleyes:Here is a picture of the bare boats unfinished.
  9. Very nice planking job, I can't wait to see how the build goes. Mike
  10. commercial@artesanialatina.com addressed to Ana . No, Latina kits don't supply the copper sheeting. This is something you have to buy separately. I used 1/4 inch copper foil tape cut into 3/4 inch lengths. Mike
  11. Ron, I cut my Strips at 3/4 inch long and the tape is 1/4 inch wide. Laying the tape makes quick work of the coppering, I can usually copper a ship in a couple of evenings.
  12. Hi Ron, the scale is 1:84, which equates to about 49 inches in length when finished. The Copper tape is 1/4 inch in width. It cost about $7.00 a roll from Hobby Lobby and takes a tad over one roll to finish the model. This is the same tape that stain glass folks use, which is also called copper foil tape. I have used this tape a numerous models that I have built and find it the best alternative to purchasing actual copper plates from places like Cornwall Models and spending $75.00 and up. Mike
  13. Thanks for posting Pictures of the box and contents. I love Constructo kits because of the quality of the parts and woods used. The instructions leave a bit to be desired and sometimes the plans lack a bit of clarity, but their kits make into nice models. You just have to remember while building a Constructo kit that they only supply the basics and if all you are looking for is a nice wall hanger then you will not be disappointed. If you are looking for closer to a museum quality model, then you will have to put in extra time, materials, research and expense. Good luck with your build, I look forward to following it. Mike
  14. It looks very good. If you aren't happy with the final result, you can always paint the hull. If I were building it I would most likely paint it anyway. I was unaware that Constructo made a Robert E Lee paddle wheeler kit. I'm glad to see it. Thanks. Mike
  15. I've built over 20 ship models in the past 15 years and still own the original first model that I ever built (HMS Bounty) and used strictly CA and white wood glue and have never had an issue with failure that you speak of. Now once a model gets 30 years old and older, most any glue will fail. I have repaired models built back in the 40's and 50's for people and yes there were some issues with glue failure, but that was well before CA glues were invented or used. But I used CA glues on the repaired parts and well over 10 years and they are still in great condition without failure. All models that I have repaired or built and sold have a lifetime repair policy offered by me and as yet, I have never had an issue where I needed to honor that policy. But glue is like the use of tools, wood and anything else, it's a matter of preference. Mike
  16. I use the cheapest old crap I can find, both liquid and gel control. I usually use off name brands sold by Walmart. Now, my favorite is the Loctite Gel control that you have pictured. I really like the new packaging on this rather than the old tube style. You can run through better than $100.00 just in glue on a model. I have found that the name brands don't really out perform the no name brands. Mike
  17. Absolutely beautiful work. I built the original San Francisco from Latina, back when they supplied wood veneer strips for the hull, which was applied to a cheaper white wood planking as a second layer. If you don't mind a suggestion, In the future, sand the wood smooth first after you glue it down and once sanded, come back and nail in the nails. It will give a much nicer finish, especially since the Frisco uses the nail heads as adornment. Mike
  18. The ratlines look good, I use the heavy thread for the horizontal lines and a thinner thread for the steps going up the ratlines. It makes a cleaner knot. Floquil used to make and sell liquid tar that I would use to paint on the ratlines once completed, which took away the fuzziness of the thread and gave it a nice appearance. But you can't buy that stuff anymore.
  19. WOW, absolutely stunning work. I know you aren't really keen on The Constructo version of this ship, but you are surely making a silk purse out of a souse ear for sure. I always look at a ship model kit as a starting point and then go from there, realizing that there will need to be changes, modifications and corrections if historical accuracy is what you are after and not just a display piece. You are doing excellent work and the more I see you build taking shape, the more impressed I am. Mike
  20. What a real beauty she is too. I love this model, the natural wood look really shows her off nicely. WELL DONE!
  21. I use the riveting tool on the copper side of the tape and run it along each edge of the tape before installing. I will pull 10 feet or so of the copper tape from the spool as I mark it with the tool. Then I lay the tape strips in full length layers on the hull in one solid piece if possible. Then I come back with a pencil and mark the tape and then score it with a hobby knife to indicate individual plates. It saves a ton of time compared to cutting the tape into individual plates and then installing. Start at the waterline and work your way down towards the keel. The rudder itself is plated the same, but with much smaller copper tape strips and is done before mounting to the model. I try to line up the copper plates on the rudder to the copper strips on the hull as best I can to give it more of a pleasing appearance. I have it mounted to the board so this was about the best that I could do.
