Everything posted by Jack12477
Build is on temporary hold while I recover from recent surgery.
- 51 replies
- artesania latina
- titanic
I would say Mission Accomplished ! That is a very accurate replica, Chuck. As always magnificent craftsmanship.
- 1,784 replies
- winchelsea
- Syren Ship Model Company
Ah but Lou, Ezekiel is coming to torment you !
Now that I have completed the basic hull structure and repaired a few ooops the instruction call for painting the hull white and the walnut cap rail and side with a mixture of "asphalt mixed with solvent ??????" Asphalt is what we pave roads with not paint boats with . So I guess what they mean is a Mars Black. For the white I will use Winsor & Newton Titanium Oxide acrylic. To prep the wood I use artist's Gesso. Four coats of Winsor & Newton white applied. Also received my newest addition to the growing collection of miniature tools. The Lee Valley Veritas miniature honing guide. Works really well. Next up is paint the gunwales and cap rails black.
- 51 replies
- artesania latina
- titanic
Moving right along at Glacial speed, I finally completed the basic structure of the lifeboat. Next step is sanding and painting. To cut all the 2 mm x 2 mm stanchions that fit along the gunwales to the same length I used my miniature miter gauge and razor blade saw. I added a bench hook to the jig to allow me to keep it in place while I cut Stanchions installed (all 49 million of them ) Next came the cap rails. 4 of the pieces are laser cut to be installed at the bow and stern. The center piece is 2 mm x 3mm piece which has to be pieced into the center, to edge bend it I cut a curved piece on the band saw to match the curvature of the hull, soaked the piece in water for a few minutes, then clamped it to the jig to dry. I also plugged up the gaping hole in the bow and stern
- 51 replies
- artesania latina
- titanic
I am familiar with the canal path, just never had time to walk/ride along it. I still have family in Rochester and Pittsford. We had a family reunion a few years back and chartered one of the canal boats (filled the boat) to take us from Fairport to the river and back thru the locks. Our cousins from Canada, England, and Ireland were impressed with the canal and its history. We turned around just shy of the river. My brother traced our Grandfather's family back to Ireland in the 1600s and along the way discovered cousins we didn't know existed both here and across the pond.
- 599 replies
- sidewheeler
- arabia
(and 4 more)
Eric, I see we hail from the same area of NY. I grew up in the Town of Brighton, just over the Rochester City line. As a toddler our house abutted one of the original Erie Canal locks (I490 and I590 merge there now) before we moved into Brighton. Locks 32 and 33 on the Barge Canal were an easy bike ride from home. Love your model. It is coming along nicely.
- 599 replies
- sidewheeler
- arabia
(and 4 more)
That is a very nice kit. I built in several years ago.
- 103 replies
- new bedford whaleboat
- model shipways
Roger, thanks ! No, the instructions don't mention that at all. In fact they don't even mention a rabbet in the stem/stern posts either.
- 51 replies
- artesania latina
- titanic
Yes, the catch is a refill set of 5 bands will cost about $32 USD for all 4 grits . But then I am still working with the set of bands that came with set, the refills are sitting in the drawer.
- 51 replies
- artesania latina
- titanic
Thanks, Lou I assume you mean sanding the completed hull. For that I am using the sanding sticks shown in the photos below; Each is color coded and the belts come in 120, 240, 320 and 400 grits. They are just right width to do each plank individually. To change belts you just push the two ends toward the center to release the tension and the belts comes right off. I think I got them from MicroMark but not sure since I have had them for a long time. I bought a bunch of extra belts at the time. If one part of the belt starts to wear out, I just push the ends together, release the tension, slide the belt along, release and continue with a new area of the belt.
- 51 replies
- artesania latina
- titanic
Moving right along with the build and repair: I used some wood putty to fill in the gaps at the bow and stern. Installed the side drawers - these are 3 ply plywood, laser cut, and a bear to bend without breaking, even with a hot iron they did not bend easily Then I installed the cross slates over the first floor decking before installing the final floor decking. I used a 5 mm shim to get the spacing even for the cross slates and then a 1 mm shim for the final floor planking spacing. Then installed the seats and some miscellaneous trim pieces that don't show up very well in the photos.
- 51 replies
- artesania latina
- titanic
I think I fixed part of the debacle. With the help of a lot of clamps and the pursuader I managed to brute force the sides into taking the shape of the center decking and close the huge gap. First, "the pursuader" Then we went from this To this While I was waiting I also added the first flooring planks and painted them flat black (there is another floor planking that covers this one. (why ??????) Got part of the bow/stern gap closed - now to fill in the remaining gap So this is the present side view & top view
- 51 replies
- artesania latina
- titanic
