Everything posted by hof00
Thanks Dave, I am currently drilling the Decking, Butts and no Butts. There are Tree Nails, I am using Bristles off a Hearth Brush. glued into the afore mentioned holes. (The Bristles have to be "Graded and are Black in color.) Have used this method before and it's come out o.k. Once all Tree Nails are in place, I'll carefully sand the Decking to get rid of the Sanding Sealer/excess Aliphatic Resin. Lots of holes, lots of Bristles. Cheers....HOF.
Nice work Chap!! (Nice Camera angles!!)
- 92 replies
- Cutty Sark
- Billing Boats
Hi Chap, Where did you get your Kauri from? I think that your build will be EXTREMELY interesting using Native New Zealand timber!! (I guess you will "Re-Saw" your material? Hull or Deck?) I am picking Deck? (Close Grained, light color and very Hard!!) Have been thinking about Native timber selection in the past, but, how to mill it without waste? I have some planks of Kauri but are in my ceiling space to facilitate "Crawl Way" for light maintenance, Etc in between Roof Trusses. Am now thinking that I should recover and mill. Most of my timber is Rimu/Matai, good for cabinet work and I also have a few planks of Teak, given to me a few years ago. I am thinking that the Kauri that you are in possession of is not the 6,000 - 10,000 year old variety, (Swamp Kauri), but more of the 200 year old timber. (Kauri takes a very long time to grow.) Logging of Kauri is now prohibited, as is most NZ timber, you are very lucky to have this in your possession, as am I!! ) (I think that Cook had a bit of a "Chop" regarding NZ Trees with Endeavor repairs, so, appropriate that you choose NZ Native timber.) I am very interested in how you will mill you Timber without undue waste. Cheers....HOF.
Hi Peter, Looking good chap!! Great Shrouds and Ratlines look superb also. (Watch your fingers!! ) Nice "Cats Cradle" of Braces coming along. Cheers....HOF.
- 92 replies
- Cutty Sark
- Billing Boats
Hi Peter, In my opinion, Rig "Aft and Up" Standing/Running rigging but leave the Braces to very last. I found that the Braces were easiest "Aft to Stem" and top down. I started with all shrouds in place, Fore/Backstays installed, (Inc. Forestays on the Jib Boom), Halyards, Gaff topping Lifts, Vangs. Braces and Pendants very last. You will also probably discover that Billings have omitted Cap Stays for the Fore and Main and a few others as well. I can try and assist you further if you wish, happy to send you a little more "Hi Def" Photos, PM with your E-Mail. Are you still having an issue with the Halyards? Tell you what, your Fife Rails are pretty good!! (Mine only had eight holes, so had to double up on some Brace Belaying stuff.) I'll be having a look at your continued progress with interest. Cheers....HOF.
- 92 replies
- Cutty Sark
- Billing Boats
Hi Peter, The Mizzen Royal and Top Gallant Braces reeve through a Double Block, (Port and Starboard), just below the Mainmast Cross Tree Spreader. The Royal Brace is on the inboard side of the Double Block and The Top Gallant Brace is on the Outboard side of the Double Block. They both drop down from here and Belay to the Aft Mainmast Fife Rail. (There may have been a Fair Lead involved rut I personally didn't find it.) There is no Pendant on the Mizzen Royal Yard but the Top Gallant has a Pendant for the Brace, the Standing part for this terminates on two Eye bolts in the center of the Mainmast Cross Tree Spreader. Well, that was the information that I gleaned from the Cutty Sark Society's Plans. With my build, I omitted Blocks that would have been used for Sails as mine does not have them and I believe that these Blocks were "UInshipped" when in port for any length of time. Braces/Pendants are a real "Cats Cradle" if you know wot I mean.... I guess you already know, Top down and Aft to Bow. Goes against the "Aft and Up" rule of thumb. More than happy to assist if I can, I've had a couple of sleeps since my Cutty build but something that's still very close to the Heart. :Looking good Chap!! Any help?
- 92 replies
- Cutty Sark
- Billing Boats
Thanks Boyd, Early days.... I am thinking that I'll drill the ends/Butts of the planks and use my Hearth Brush Bristles to represent the Nails then sand the deck down. The alternative that I am "Toying" with is to prick the ends/Butts with a pair of dividers and use my Tech Drawing Pens, (Yup, these are old but good.), to place a dot of Black Ink into the depressions left by the dividers, then sand the Deck.... Thoughts? Anyway, while I'm thinking of my options, it gives me more time to research and study wot has been left out of the Kit, or, I should perhaps be more positive and say what I can add in terms of fittings, etc. Cheers....HOF.
Oky Dokie, A little progress to date... There are some simply awesome examples of this subject on this site!! To Date, have sorted out the Deck Camber, Thanks Paul. Glued all Bulkheads in position using the False Deck to line them up, but of a mission, and have almost completed planking the Decks. AOTS shows a reasonably complex Deck with Scarf Joints, Etc. I guess I may have been more "Pragmatic" in my approach, 4 Butt Shift, no Scarf.... I also did the "Shift" on the Fore Deck, Oops, never mind, I'm not going to take the Planks off now!! (It is what it is.) Unsure if i'll give heaps of extra detail in the build, but, I think I may have started already. Anyway, some Pic's from today. Have an awesome weekend!!
Hi Chap, Yup, Rig "Aft and Up!!" (Unsure where I got that quote from....) Inboard to Outboard worked for me also. I approached things a little differently, I placed the Main Masts in place first and approached the Top and Top Gallant Masts as separate assemblies complete with Yards and associated Rigging. (I adopted this approach as the height of the Model on my Work Bench meant that I was at the limit that my little arms could comfortably reach. ) Masts and Yards were not glued, everything is held together by Standing/Running Rigging. This made things a little more interesting as the Yards were "Live." The upside of this was that I could fiddle and get the Yards in more or less the correct positions for a "Harbour" Rig. Yours will be more interesting still with your Sails Bent to the Yards before your Yards are installed. By all means, PM me on the subject when you get closer or just use this Forum as others may have a different approach to me and I am certainly no expert.... BTW, Nice touch with your "Hermaphrodite" Masts/Spars on the Deck!! Cheers....HOF. (Harry)
- 525 replies
- cutty sark
- mantua
Hi Chap, Some very nice progress indeed!! Regarding your Deck Structures/Rigging, my experience here, get these attached first.... I would have had an awful time trying to mount/attach these after the fact. My experience, put your various Blocks/Eye bolts in place on the Deck/Pin Rails, Mount Deck fittings, then Rig. Dead Eyes "In Board" are a Bi--h!! But Lanyards are for these are relatively easy if you make a "Bodkin" with your rigging thread with a bit of CA and some tweezers to pull the thread through. (My Stern Bulwark Railings were also in place when I rigged mine, I sure wasn't going to remove them so had to Visualize the sequence/method.) Last stuff that I put on the Decks/Skids, Boats. (Post the majority of Standing/Running Rigging.) Don't rush!! Cheers....HOF.
- 525 replies
- cutty sark
- mantua
O.k. a problem, False Quarterdeck hangs over, (Proud), of all Quarterdeck Bulkheads by about 1.00 - 1.25 mm. Is this something that others have discovered? Everything is as straight and level as I can get it. All other Bulkheads, Fore and Poop stand proud of the Decks, a good thing. Also notice that the "Sheer" of the Pop Deck is much more pronounced than the others. Pack out the Quarterdeck Bulkheads? Cheers....HOF.
Hi Marc, Those are just awesome!! Looking forward to see the results. Cheers....HOF.
- 525 replies
- cutty sark
- mantua
Hi All, Thank you all so much with your guidance/advice thus far.... I have more questions, what length are the individual Deck Planks, (Not very clear from AOTS as the Drawings are quite smallish.... Supposedly 1/48 but thinking 1/100) If someone could advise what the "Real" Scale of AOTS Endeavor, in the publication, I would be most grateful. Any input appreciated. O.K. have started to cut some stuff, Mast Holes Drilled and a couple of Lower Decks planked. Hopefully tomorrow, I'll be attaching Decks to Bulkhesd, Etc. Cheers....HOF.
For a "Scratch" Build, something that I would be very maybe afraid of, your work is awesome chap!!
- 4,152 replies
- cutty sark
- tehnodidakta
Nice one!! Thanks Chap. I guess once I have got the foundation, (False Keel, Bulkheads and Deck fitted, this weekend hopefully), I can really get stuck in. I have some spare Lime, so I intend to experiment a little with the Bending thing. Think I'm actually looking forward to it. Question for you, what colors have you used and what flavor? (Manufacturer) Any advice appreciated. Cheers....HOF.
Hi Paul, I am going to give the Amati thingy a go.... Are you talking about the Aluminium "Bulb" at the business end of a Soldering Iron or the "Squeeze" thing with a blade in it's Jaws? I'll be trying the former of the above. Have had success with this before and does nice tight curves but have to soak first of course. Am also thinking that tapering the Planking Strakes at Bow and stern prior to the bend "Heat" treatment at Bow and Stern I'll do on the Stationary Disc Sander. If the Plank bender doesn't work well with the "Heat" treatment, I'll be making the Jig.... Anyway, just planning and visualizing my potential next few steps. I have a whole weekend coming up so looking forward to being "Constructive!!" Your example is looking rather good!! Cheers....HOF.
Thanks Rowan, Not much happening last weekend, bit of a "Write Off" with Data Centre Maintenance to the fore, however, I did get the False Decks "Bisected" for locations of False Keel and Bulkheads ready for me to Drill and Nail. I get the feeling that it may be a lengthy build and it's my first "Bluff" bow that I will be attempting. Cheers and Regards....HOF. (Harry.)
Unsure if the memories are fantastic.... Good to see something started that was so close to me for so long. I'll get you that E-Mail address when I get in the office tomorrow. No Worries Sir!! Cheers....HOF.
- 71 replies
- cutty sark
- mantua
