Everything posted by hornet
STAINLESS STEEL SCREWS FOR EYGLASSES HINGES Available on ebay for around $5.00 per box - enough to last a lifetime. I sometimes have trouble getting nails holding gudgeons and pintles to stay in the rudder (even with glue) I have experimented with using these micro screws instead Screws have CA glue applied to thread. Once in place I file back the heads. Then paint!! I'm sure there are other ways to use these micro screws in a build.
- 396 replies
- Idea
- Bright Idea
I have the proxxon DS 230/E which appears to be the same as the 115. It performs very well.
CONNECTOR SLEEVES These are used to loop nylon fishing line. They are crushed to hold the line in place but are made of brass and come in different lengths and diameters. Once the protective covering is removed (inside and out) they can be used with brass wire and copper sheeting to make gudgeons and pintles. They are available at most fishing tackle stores I cut one in half to produce the `hinge' part of the pintle and gudgeon. After a bit of silver soldering and blackening, they come out quite well!!
- 396 replies
- Idea
- Bright Idea
Hi Graham You picked a tough one to start on!! I have the Caldercraft Endeavour on the shelf but won't start her till I have finished the Supply & the Bounty. I was recently aboard the Endeavour Replica when it visited Newcastle Harbour. While others were taking `selfies,' I was taking about 150 snaps of bolts, ropes, window frames and the like!! I think people thought me mad!! I've included a pic of the replica's bow. It may help your build. If you need any other pics along the way (I photographed pretty much everything) PM me.
- 396 replies
- Idea
- Bright Idea
Casting epoxies from Smooth-on
hornet replied to src's topic in Modeling tools and Workshop Equipment
After considering this observation, I attempted to make the two part epoxy more cloudy. Firstly I mixed a small amount of acrylic paint to a 1 1/2 centimetre puddle of epoxy. On the first picture I used about twice the amount as on the hobby knife below. It came out quite opaque. The second picture I used about the same as on the hobby knife. The acrylic mixed OK but I think it was a little grainy (visible on the second picture only.) Only a small amount of paint was used I then tried mixing enamel paint with the epoxy. I used about the same amount as with the acrylic. It mixed in much easier. The pic below sort of shows the result but it was difficult to get a clear shot. The epoxy is still transparent but slightly milky/cloudy. -
Thanks for the tip twintrow. I suppose tulle could be stretched between the cling wrap and the window frame then the epoxy could be poured thinly over the top. I'll have to give it a go!! -
Hi Banyan. There were minute bubbles when I first mixed the epoxy. I have had a lot of experience with the stuff having built many, many custom fishing rods. Often letting the mix settle for a minute or two allows the bubbles to dissipate. You can also blow on the mix which helps, or use a blow drier on a warm setting to get rid of them. I have found that if you 'fold' the part A & B mix together gently rather than stirring furiously, you get less bubbles. As to creating a more cloudy appearance in the glass, you could experiment with food colouring as I did - maybe a very small amount of black. I had a puddle of leftover epoxy about as big as a 5 cent piece (about 1cm or 1/2 inch for Non-Aussies) I used only enough food colouring to fit on the end of a couple of pins to get the yellow colouring that you can see on the epoxy blob on the bottom right corner (almost under the hobby knife) of the 4th picture in the post. The erskine epoxy is about $16 for the two 30ml bottles so you have plenty to experiment with. -
In a previous post on this thread I suggested that the two part epoxy that is used to provide a flexible, crystal clear coat to the whipping/bindings on fishing rod guides/runners might be used to create `glass' for ship windows. I decided to experiment with the idea. The epoxy I used was Erskine Epoxy. I think it is an Australian product but I am sure similar products are available overseas. The epoxy can be purchased from most fishing tackle stores (my second home!!) I use syringes so as to get a precise (50/50) mix of Part A & B of the epoxy. I made a `window frame' out of scrap material for the experiment. It was mounted onto a board that had been covered with cling wrap. I hoped that the cling wrap would not stick to the hardened epoxy and that the window frame with its `windows' would come away easily. The window frame was clamped to the board covered with cling wrap to prevent epoxy seeping under the sides. I applied the epoxy mix to the window frame using my `squadron' CA glue applicator. After leaving overnight to harden, I removed the window from the cling wrap. Happily it came away very easily. The result of the experiment is shown below. Having succeeded with the experiment, I decided to apply the epoxy to windows and stern lights that are soon to be fitted to my current build, HMS Supply. I had already used clear plastic backed by black card on the stern lights of the supply so I applied the epoxy directly over the plastic. It worked well, giving a more 3D look to the windows. Because this epoxy is used on fishing rods, it is flexible and will bend and twist without cracking. Another advantage of using it. The first picture (above) shows the job half done and the second one is complete. I think that the epoxy finish looks far better than the `flat' finish visible in the windows not epoxied in the first picture. I had not as yet put clear plastic behind the ship's other windows but did so after seeing the results above. The epoxy was again applied directly over the clear plastic and also produced a more 3D effect for the windows. I had an amount of left over `mixed' epoxy. rather than letting it go to waste, I raided the Admiral's kitchen cupboards and found some food colouring. I added a very, very small amount to the epoxy and was surprised to see that it actually mixed smoothly and evenly with the epoxy. It also dried hard and flexible. I have no need for `stained glass' in this build but will keep this in mind for the future. I hope the results of my experiment are helpful to others. I would also like to thank `Neek" the ship's cat for her valuable input in this experiment!! -
I use a two part epoxy to give a crystal clear protective coat to the whippings (bindings) on fishing rod guides (runners) that I custom build. I see no reason why it would not also work for this application. Sometimes it gets tiny bubbles in it after application, but these are easily removed by blowing with a hair dryer on a warm setting. It is available in a variety of brands at most fishing tackle shops. -
Belaying pins vs. shroud cleats - moved by moderator
hornet replied to timboat's topic in Masting, rigging and sails
Christmas tool and equipment list
hornet replied to schnu's topic in Modeling tools and Workshop Equipment
I wish that Jim Byrnes would be made an honorary Santa's Elf and would open a workshop in Australia! -
Help! Jokita HMS Supply
hornet replied to mick868's topic in Building, Framing, Planking and plating a ships hull and deck
In reality you may be correct Mick. I am no expert on the history or the plating of ships in the 'real world.' This is only the second ship I have coppered and I have looked at a lot of models on this site for guidance and watched the 'Modellers Shipyard' DVD guide to coppering a hull. They all seem to be coppered in a similar fashion. Thanks for the information though, I will do some research. It wouldn't be hard to remove the plates and replace them with something else if necessary. I haven't built the rudder yet either. If anyone else out there could shed some light on this issue in relation to modelling, I'd appreciate the input!! -
Hi Mick As to coppering of the hull. I original tossed up between buying the Caldercraft Supply and the Modeller's Shipyard version (see link below) The modellers Shipyard version is coppered but was a lot more expensive. While in communication with modellers Shipyard, I was told that Supply was indeed coppered. If you check out the history of coppering hulls of Royal Navy you will see that the process begun in 1779. Wikipedia states " all ships up to and including 44 gun ships were ordered to be coppered when next in dry dock" By 1786 the entire fleet was apparently sheathed. The Supply remained in service to the Royal Navy until 1791 and was the used as a coal carrier until 1806. One would have to assume therefore that she was coppered at some stage in her long career. I presume that Caldercraft did not include copper plates to keep costs of the kit down. I actually pinched the copper plates from my Caldercraft HMS Bounty kit (next in line to be built) and in the same scale. I ordered some more for her from Cornwall Model Boats. They supplied and are delivering the plates for less than half the price that I can get them in Australia - Go Figure??? http://www.modelshipyard.com.au/ship-models/modellers-shipyard/hms-supply-first-fleet-1788/ -
Hi again Mick868 Further good pics of the Supply can be found at the address below. It is in a slightly different configuration but the pics are fairly high resolution and are worth a look. Picture Number 6 is a stern view of the model and may also help you with your build. Hope this helps http://www.powerhousemuseum.com/collection/database/?irn=238338&img=182799 -
I am a little ahead of you on the Caldercraft Supply. Just installing copper plating. Hope these pics of the stern section are of help. I did not use the stern counter pattern supplied (part 73) I used the supplied one as a template and then cut one out of thinner basswood and planked it. Cheers -
Treenails
hornet replied to wallyh's topic in Planking Techniques's Click Here for Topics dedicated to planking!!!!
I don't sand the deck beforehand. After fitting a treenail, I use a pair of small cutters that I keep very sharp with a diamond sharpening stone ( so as not to crush the bamboo treenails). I can cut the treenails practically flush to the deck with this cutter. I then sand the deck and treenails with very fine grit sandpaper - try not to over sand as deck planks are often very thin. I have recently bought a proxxon pen sander which I will use to get into tight corners of the deck of my current build - the 'Supply' - when I reach the deck planking/ tree nailing stage of the build. -
LEAD SPLIT SHOT - used in fishing and available, in very convenient dial packs, from tackle stores in a range of sizes - can be gently squeezed closed, filed back and painted black. They make good cannon balls. EXTRA LONG MATCHSTICKS - can be turned up on a wood lathe to make oars - I did this on my 18th century longboat ALUMINIUM FLASHING - for windows and guttering - Available cheaply by the roll in hardware stores (one roll would last a lifetime!) It is thicker and easier to work with than aluminium cans and can be used in a variety of ways when bashing!
- 396 replies
- Idea
- Bright Idea
Today marks 100 years since the first convoy of 30 000 Australian Troops left from Albany, Western Australia, for the Middle East and on to Gallipoli in World War One. My stepson is a crew member on board the Collins Class Submarine H.M.A.S Rankin - Which is taking part in the Australian Navy Sail Past as part of the commemorations in Albany this morning. A very exciting day for Albany!!!! Lest We Forget https://au.news.yahoo.com/thewest/wa/a/25396510/anzac-flotilla-arrives-in-albany/ HMAS Rankin leads the fleet into King George Sound - Albany W.A PICTURE BY NIC ELLIS 31 OCTOBER 2014 THE WEST AUSTRALIAN FAIRFAX AND AUSTRALIAN FINANCIAL REVIEW .
Treenails
Hi Wallyh No 75 may be a bit too tight. I've done a few conversions to metric (which we use in Australia) No 75 drill equates to a little over 0.5mm. No 25 on the Byrnes drawplate equated to a little over 0.6 mm. I think you may need about a size 71 drill bit which is about 0.66mm. You don't want the treenail too tight. It should slip into place fairly smoothly when dry. A small dob of glue on the end will then slide up the sides between the treenail and the plank/ deck when you glue it down. As to depth, just don't drill right through the deck. Deep enough so it is firmly in place. My suggestion is to do a few on a piece of scrap wood until you are confident about the drill bit diameter and depth. On your model is no place to experiment!! -
Try here. Proxxon have a good range. Good quality too. www.proxxonworld.com.au
Treenails
Hi again JPett Just tried your warp drive method on a short (3cm long) piece of bamboo. It worked a treat. Thanks for the great tip!!! -
I usually raid under the Christmas Tree at about 2am on Christmas morning. Not able to resist playing with any new toys that come my way Kevin. In the case of a new saw, I would probably test it by cutting the handle off the Admiral's broom or something equally inappropriate. Your restraint is admirable.
