mrjimmy
Posts posted by mrjimmy
  1. I have read that any citrus tree will produce good timber, as with just about any fruit or nut tree.  The drawback is the size of the lumber it produces, but that is not a concern for what we use it for.  The fresh cut wood should be left to dry for one year per inch of thickness.  A good idea would be for you to slice the wood into one inch thick slices and stack the lumber with one inch "sticks" separating the boards. Let us know how the wood works out. See you next January..........
    Jim
  2. If anyone needs some inspiration to do some practice in order to improve their carvings, by all means check out the website below.  Alexander is a world class shipbuilder and a very accomplished carver.  Most of the work shown is in the round, but worth a look.........enjoy.
    http://modelshipworld.com/index.php/topic/5412-carving-from-belgorod/page-1
    Jim
  3. This is very nice looking Alaskan Cedar wood.  Must be a cousin of Port Orford cedar that grows from the Oregon coast to Central Oregon; it also has a fine grain and very easy to work with. I am working with a piece right now for a Robin (bird) carving that looks almost like basswood. I would have included a photo, but it does not pertain to ship building. Really nice stuff.
    Jim
    p.s. Michael Mott used Port Orford Cedar to plank one of his model ships and it looked fantastic.
  4. Hi, Jaager.......
    Indian Hawthorne is very plentiful here in the States; it is commonly seen as "hedges".  The problem is finding a hedge that needs to be cut down and that it has large enough diameter branches to be useful.  It would be easier to locate some dogwood trees that either need pruning, or that had died for one reason or another. Again, finding usable sizes becomes a problem. Another very good carving wood to consider is crab apple; very similar to boxwood (have not tried any, but have been told this).
    Jim
  5. Hi, Chuck.....
    The carvings are much better than you whine about, but with practice they will get much smoother during the carving stage.  In the meantime, in order to get them closer to your standards of quality (and we all know how high that is), try this:
    Take a sheet of 320, maybe even 220 if you want to live on the wild side, and cut some strips about 1/8" (3 mm) wide along the length or width of a full sheet.  Lay the strip down across the area you would like to improve, place your left thumb over the sand paper strip with just enough pressure that will allow you to pull the strip through. Move to the next spot that is causing you to lay awake at night and repeat the process.  Let us know how it works out.
    Jim
