russ
Everything posted by russ
  1. Don: Congratulations on a beautiful model. The details are very nice, but I also like the mixture of paint and natural finishes. Wonderful job. Russ
  2. Kenneth: The battle damage is hardly noticeable. Nice save. So far the head rails look good. Those are complex shapes and always a challenge. Russ
  3. David: If you look at the Model Shipways Dapper Tom rigging plan, it will probably be very similar to what you have. The AJ Fisher Lynx privateer rigging plan is also probably very similar. Russ
  4. This is an American topsail schooner, early 19th century. It is probably meant to be a War of 1812 privateer schooner or something similar. It is most likely a solid hull model. It might be an early solid wood hull kit, depending on the size and scale. Maybe Marine Models, AJ Fisher etc. Russ
  5. Greg: I have said this before, but I think it is worth repeating. Soft soldering is akin to gluing two pieces together while Brazing aka hard soldering aka silver soldering is like welding two pieces to become one piece. Regardless of the stresses involved, which sounds more permanent and less likely to fail over time? Also, a soft soldered joint is difficult to hide whereas the hard soldered joint can be blackened and will be invisible. Once you learn to do it and have a little practice at it, it will become second nature to hard solder. Once I learned the basics of it, I could not figure out how I went so long without it. Russ
  6. Sam: Thanks for the kind words. I had to experiment with the bead board to figure out what worked best. Not much time really and a lot of fun. Russ
  7. Pat: Nice work. The details are coming along very well. The metal plating really looks great. Russ
  8. A little sanding improved the appearance of the bead board. I think this looks a little more believable. Russ
  9. Here is the dashboard assembly with narrower bead board. I think this looks better than the wider material. Still needs some trimming and fitting. I also think I will go with a smaller wheel. Russ
  10. Carl: I will probably make another dashboard assembly with some smaller paneling and see what it looks like. Thanks. Russ
  11. John: Thanks. There may be another version of this, but we will see. The wheel could be a tad smaller and the bead board might want to be a shade more narrow. It will not take a lot of time to redo it if I decide to do it. Russ
  12. Here is a look at the bead board treatment for the bulkhead below the dashboard. The wheel is temporarily set to check for height which is good. The bead board will get painted white. The bead board is made up from 1/8" wide strips with both edges chamfered off. Russ
  13. Michael: Thanks. We had a few bumpy weather days, but it is all good. The cool weather is very fall like. Russ
  14. Pat: Thanks. I am hoping everything will fit the way it should. So far it is looking promising. Russ
  15. John: Thanks. This my third pass at this structure. I am hoping it will be the final one. Russ
  16. Just a little more progress. This was the perfect day to work on the model. Nice cool, dry weather. I am making some progress on the pilothouse. This pilot house differs from the trunk cabins I have built for schooners in that a lot of the interior is visible so I need to take some care to make sure that the interior details are presentable. This is all very rough right now, but it is coming along. The dashboard will have dials on it and the small bulkhead below it will have paneling and the wheel will be mounted just below the dashboard. There will be three windows in the openings across the front of the pilot house and the exterior will have vertical planking. Russ
  17. Thanks. I came up with this general style for my recent models and I will probably use this style on other local boats as long as it is appropriate etc. Russ
  18. Wonderful job. The details are really quite good. Good to see you back at the bench. Russ
