KeithAug
Everything posted by KeithAug
  1. Roger, Your explanation of mahogany types makes a lot of sense. I have used "modern" mahogany with mixed results. What I have found recently is that dark wood antique furniture is out of fashion and that auctions are selling it for a song. A great source of quality wood if you are prepared to put a bit of work into cleaning it up and ripping it to size. Nils, Thank you for your comments And thank you to all of you who have hit the like button.
  2. Hello Roger. My mahogany comes from a hundred year old table. The down side is it is very dry and a little brittle. The up side is it cuts beautifully with a very smooth surface. The real payback is when the poly goes on - the wonderful almost ruby red tones are mesmerising. I sometimes just sit and admire the depth of colour and the natural beauty of the wood. I'm not sure why model building advice warns against mahogany (it is claimed to be too coarse) but I prefer it to some more commonly used timber.
  3. I airbrush quite infrequently with long breaks, typically of a year. I therefore need to relearn the technique each time. This time the relearning was complicated by a different model of airbrush - gravity feed as opposed to suction feed. The new brush delivered a lot more flow which was a bit of a surprise and I ended up with a couple of runs - which fortunately I blew out with air. The paint was matt white Humbrol enamel. The pictures are of the 2nd coat ( I am now on coat 5). I was pleased with the definition on the sculptured hull. The matt white seems to emphasise this and create really good definition. A couple more coats should do it and the masking tape should come off Friday morning. I a hoping that I won't get any bleed but at the same time I am a realist and therefore expecting a little. Brush painting of the deck structures continues - now on 6th coat (with poly thinned - half and half). 2 more coats should do it.
  4. Hi Michael I wouldn't dare airbrush in the kitchen. Only masking in the hot part of the house. Airbrushing reserved for workshop. 6 deg is plenty cold enough when wearing t shirt and shorts!!!!!!!!! Number 1 airbrush failed, today - o rings seem to be shot. Now using reserve airbrush but I now need a reserve for the reserve. Reccomendations from shipwrights would be most welcome.
  5. I have to confess that I started the deck structures to put off the task of masking and painting the bulwarks and waterline on the hull. Masking is such a pain and airbrushing seems to be 10 minutes of painting followed by and hour of cleaning for every coat. Anyway the time came when it could be avoided no longer. But first I had to glue the previously made scupper covers in place. I reattached the strong back to give me a marking out datum. I needed a flat surface for the datum and fortunately my wife was out so I used the expensive stone worktop in the kitchen. I think I got away with it! I find it easier not to mark the hull but instead use the pointer to position the masking tape directly on the hull. I completed masking in the dining room. The workshop temperature is below 6 deg centigrade and thats a bit too cold for my liking. I must get round to installing some form of heating! In the mean time the deck structures got another coat of poly.
  6. Thanks Michael. I spent a bit of time fitting the sliding roof hatch. It worked out pretty well. I then made a start on painting the various deck structures.
  7. John Thank you for your positive comments. The finish is a trick of the camera. For the most part the deckhouses are still in their raw state - just sanded. They look a lot better when photographed in natural light without flash. Interestingly with no flash they are much closer to what the eye sees. The camera flash tends to accentuate the dust / grain in a way that looks quite odd. I am planning to finish the all deckhouses in silk finish PVA. The mahogany on Altair is polished to a high shine and I wanted to give a polished impression on my build.
  8. Phil Thats great, being born in Warrington my son is a lifelong supporter of United.
  9. Hello Dharma. Is it City or United? Guitar building seems to be a popular route into ship modelling, you should check out Julie Mo's J Class Endeavour Build. If you try a kit I think its well worth finding a relatively simple one, preferably plank on frame. The reward of rapid progress will spur you on to attempting something more demanding later on. Good luck,
  10. Good point Bedford. I have made a bit more progress on the deckhouse. Firstly I built and attached the skylight pods to either side of the deckhouse. Of course this meant more skylight windows. The time had then come to glue the deckhouse roof in place. Not altogether straightforward as a protruding rim exists just below the junction of the roof and wall. I decided to shape the roof to be an exact fit and then remove it and add the protruding rim to the underside of the roof before refitting and gluing. With the rim attached all round and sanded back to a .040" protrusion the roof was then glued in place with PVA. The roof has edge rails down both sides as well as running rails for the roof hatch. The former were made from .040" x .100" strip while the runners were .100" x .080" with a .040" x .040" slot to take the hatch. I a bit of care was required as I wanted the hatch to slide.
  11. Hello Pawel Have you ever considered making a porcupine???????????
  12. Hello Julie My record break from working on a model is 18 years. It collected dust in a spare room and every time I came across it It reprimanded me for my neglect. The symptoms of my dereliction grew slowly. A day off here and there became the odd week and then month. House maintenance, career, children all consumed my time and my ship became unloved. Occasionally I would blow the dust away and marvel at some item of detail, wondering how I had managed to create it and fearful that my skill would no longer suffice. In the end It became the itch than needed scratching and I resolved to finish it. !8 months later and it was done and everyone that saw it voiced their admiration. While pleased by the comments in the end they didn't really matter, as I had done it for my own pleasure and satisfaction. So I come to the point of my ramblings................................ do things you like doing the most and if they change go with the flow. What goes round comes around and you generally get a second chance.
  13. Nice work Bob. I too need to get back to building now the festivities are over.
  14. Hello Julie, A friend of mine commented that for a 1931 boat the admiralty charts should be in black and white. I replied that I was building Altair as she is now and the yellow, blue, green and black charts were more correct. As for being up to date - not quite - they are from the first decade of the century. Have a happy new year.
  15. Thanks Bob. I knew I borrowed it from somewhere.
  16. John, Im assuming its stowage for the cooking gas. Cant see what else it might be. I thought my grating technique was fairly standard - I have borrowed it from somewhere but can't remember quite where. The slicing off of a number of identical gratings seemed fairly obvious but of course is only applicable to long narrow shapes if using a slitting saw. Have a Merry Christmas.
  17. Thank you John and Merry Christmas to you and all visitors to this build.
  18. Thank you John. Immediately in front of the deckhouse is a square box which on the plans is referred to as the "gas box". On top of the gas box are stowed 3 demountable gratings. The use of the gratings isn't immediately apparent but I wonder if they form part of the companionway. I find that small boxlike features are most easily formed on the mill and this is the approach I took with the gas box. By slotting out and inserting the frame features i can get a reasonable representation of the panelling. The grating construction followed the fairly standard approach taken on other MSW builds. In this instance the gratings are small and I decided that hole sizes of .040" square were as small as I could go and still maintain definition. This scales somewhat larger than on the original. Planks were thickness sanded to .080" before being slotted .040" deep by .040" wide. They were then glued in a sandwich using PVA. Finally .060 wide gratings were sliced from the sandwich - 3 in total.
  19. Just catching up Mark. The hull looks beautiful. You should be very proud. Merry Christmas and on behalf of many members, thank you for your dedication to MSW and the encouragement and advice you provide.
  20. Hello Bob Several years ago i switched to optician prescribed vari-focal lens glasses. These are made with the focal length is graduated from top to bottom of the lens. The bottom of the lens allowing for close up work and the top of the lens allowing for distance viewing. They work well once you get used to moving your head (rather than your eyes) to view near and far objects. Some people find this more difficult than others and some abandon vari-focals because of it.The ones you are looking at appear to be vary-focal glasses. That said eyes are complex things and its unlikely that you will get an off the shelf product that is a great match for your particular eye.
  21. A couple more deck features have been developed Just aft of the deckhouse is a rather complicated little structure referred to on plans as the engine hatch. The hatch is composed of 5 separate elements. On the port side is a sliding hatch leading to a set of ladders. On the starboard side front is a deck hatch and immediately behind this is a skylight (not yet made). To the rear of this is another low hatch. On the deck to the rear of the sliding hatch is a panel for the sailing instruments. The sailing instruments are obviously a retrofit since Altair was originally constructed. The whole of the hatch has the feel of being designed by committee. Towards the stern is a small structure called the steering hatch. Quite a nice little box.
  22. John / Michael Thanks for the comments and thanks to others for viewing and liking. It does fell like she is starting to come together.
  23. I find that time flies by and many jobs get in the way of boat building. Never the less I have made a bit more progress. Many of the skylights are now in place (but not yet glued). The mushroom vent for the galley skylight is made and as per the original it opens vertically by means of a screw. Most of the skylights are part finished with the window frames painted with poly, the bodies however are only sanded as yet. I also assembled and glued the side walls of the deckhouse and fitted the roof (not yet glued). I was pleased with the accuracy with which it came together.
