KeithAug
Everything posted by KeithAug
  1. Hi Bob I keep thinking I would like to build an Edwardian steam launch - including building the engine - I have built a steam engine previously and enjoyed the process. I look forward to seeing your build - computer willing!!!!!!
  2. Thank you Michael and John. I think I'll try it once more taking a little more care on the soldering. Finishing the hinge process:- Having made the basic hinge pieces I decided to try drilling holes for attaching the hinges to the door posts. I didn't have a centre drill small enough so used a .025 inch twist drill, hoping it wouldn't drift off. Hope was in vain and this aspect of my plan was a failure. Finally I parted off using a slitting saw. The first hinge worked but was a bit messy. I decided to dispense with drilling the holes on the mill and will drill them by hand next time. The second attempt was posted earlier - a coupe more photos here.
  3. I made a start on my hinge experiment. The hinges need to be .240 inch long by .100 wide when closed. Having decided on an approach I made 4 jigs - 3 simple and one a bit more complex. Their uses will become clear further on. I started by soldering .040 inch OD brass tube to .012 sheet. Both the sheet and tube were "tinned" with soft solder prior to joining. The 1st jig was to assist soldering - simply a recess to hold the tube down while the sheet was pressed against it. A bit difficult to see but here the tube is attached and the soldering cleaned up with wire wool. The trickiest bit of making the hinge involved accurately cutting the tube before removing alternate tube segments with a needle file - the cutting / filing jig worked very well in enabling this operation. The photos are proving quite difficult because of the scale and the reflective materials. I hope they are good enough to illustrate the process. I need to go and make dinner but here is the 2nd attempt - I have made a "piano" hinge at this stage. It's about 1 inch long and the final hinges will be cut off from this. I will continue describing the process in the next post.
  4. I grabbed a couple of hours this weekend to make a bit of progress. I spent some time trying out options for making the hinges for the deckhouse doors. I abandoned this when I released I needed some brass sections which I ordered and I await delivery. I finished off the sides of the deck house by installing acetate windows (.020 thick) and then cladding the inside. I covered the acetate with masking tape to prevent poly contamination whilst painting. I needed to create 1/4 round dowels for the corners of the deck house. 2 different radii of dowels were required .120 and .140 inches. The larger diameter is required at deck level where the deck house wall is thicker. After a bit of head scratching I realised that I could make the 1/4 rounds on the drum sander by first making a square section equal to the desired radius and then passing it in and out of the sander always keeping one corner in contact with the bed. It worked a treat. The base dowels went on first followed by the remainder of the edge - glued with PVA I also made a start on the deck house front.
  5. Thanks Michael I was worrying about getting the fold neat (sheet metal work wasn't my best apprenticeship experience) so I came up with a slightly different plan which I will try when I am next home - Friday. If it does not work I will try your method.
  6. Thank you John. I am currently wondering how I am going to make working hinges for the deck house doors. They need to be about .160 inch long by .080 wide when closed. I have looked on the net but even the smallest hinges seem to be 3 times this size. The plans suggest using Sellotape for hinges which is neither elegant or durable. I will have to do better.
  7. I wanted to make a working roof hatch - avoiding the dilemma of whether to have it open or closed. It was therefore important to make the curve of the inner surface of the hatch match the outer curve of the deckhouse roof. Rather than make a jig I decided to use the deckhouse roof itself as the jig. To avoid the hatch becoming accidentally attached to the roof I covered the roof with a strip of masking tape. The hatch was then constructed on the roof using .040 inch x .160 inch mahogany planks overlaid by a second layer of .030 inch x .160 inch planks. The second layer was inset from the edge by .040 inch to produce the lip which will locate in the runner. The components of the deck house were balanced on one another (not yet ready to glue) to check what it is going to look like.
  8. Michael Your clamp seems to work well - think I may have to make one if I can find the time. Are you using soft solder? You seem to be quite mobile so I assume the leg is hopefully on the mend?
  9. Michael I sometimes get a bit obsessed about detail, even if you can't see it. I think you may suffer from the same problem!!!!!!!!!!!!!
  10. Thank you Michael. The roof beams are true vertical / horizontal while the roof slopes down towards the bow. This means that the beams have to be flared. I did this using a sanding stick using fine emery cloth and very little pressure to avoid breaking the beams from the edge strips. I was pleased to get to planking the roof as this started to add much needed rigidity. The planks were .040 inch thick by .160 inch wide mahogany. The first two planks were placed to form the edges of the sliding roof hatch. Elastic bands proved effective in holding the planks while the PVA dried. Once fully planked the roof was sanded and the additional longitudinal beams attached to the underside. The roof construction is very light but surprisingly rigid. The 3 beams which cross the hatch opening will be removed later.
  11. Hi Pawel Excellent work. How many years do you think its going to take to finish her?
  12. Progress continues to be slow as other distractions intervene. I continued to build the deck house, trying to reproduce the original in miniature. The roof is quite a delicate structure at model scale. I decided to laminate up the roof beams. The beams to the front of the deckhouse are thicker - laminated from 3 pieces of mahogany each .040 thick. The beams at the rear of the deckhouse are thinner - 2 x .040 planks. I made a simple jig (nails in a plank) to hold the beams while gluing (PVA glue). Another simple jig was shaped (on the mill) to produce and accurate cutting guide to consistently get the planks the correct length. Finally I made a 3rd jig in which to build the roof. 2 edge strips were laid in the jig and then the 6 curved beams were placed glued at each end with PVA ------ all very delicate.
  13. I decided to do a bit on the deckhouse - actually the sides. I am going for a sandwich construction, a .031" inch ply core with .040 of mahogany cladding on either side. I spent a happy couple of hours on the table saw cutting the mahogany cladding. I am finding with increasing practice that I am able to make cuts to an accuracy of a couple of thou - quite sufficient. I went to some trouble to get the right spacing for the window - as per calculation sheet below parts in photo. The "kit of parts" is shown below. Assembly was straightforward using PVA glue. The side is 3.5 inch wide. On the reverse side you can see the recess for the windows. One piece of clear acetate will be used, the frames creating the impression of 5 windows. The cladding of the inner surface will trap the acetate in place. This avoids trying to glue the acetate in place which I always seem to make a mess of. After a days work ( with many interruptions ) I had made a bit of progress.
  14. Sorry to hear about the incident Michael. In similar situations I tend to get a long lecture from my wife which I promptly ignore - and then regret. I agree with Mark "follow good advice" and get well soon.
  15. Bob Thank you. Your kind comments are much appreciated.
  16. Seats I thought a bit about how to make the seat cushions and backs. Altair has white seats without any features. I wanted to make the seats white but felt that some contouring would enhance the look. I did consider covering foam backed by ply with linen. I thought however that this would look clumsy at the scale of 1:32. Eventually I decided on creating a ribbed mould and "casting" the cushions in silicone. The ribs were cut in nylon sheet (actually an old chopping board) using a ball end milling cutter. The casting was a fairy simple operation. I produced 4 silicone castings over 3 days - allowing plenty of time for curing. The sheets were then shaped to fit on to the benches
  17. Thank you "E" ......... I could probably have made a full size one nearly as quickly!!!!
  18. Mark / John - thank you for your comments. Also thank you to all who have hit the like button. John - I have a dilemma about leaving the draw open as in its open position it makes the flag locker even harder to see. Maybe I will have to move it on an annual basis. I am toying with making a parallel rule, dividers and a hand bearing compass but this may be a step too far. First I think i will have a go at the seat coverings.
  19. The upper steps in the deckhouse are now complete and the first finishing coats of poly applied. As I think I previously said the chart table sits above the flag locker. I got a bit carried away with making it. The charts cover the Western Isles from the Butt of Lewis to the Mull of Kintyre. The books are old friends - "The Yachtsman's Pilot to the West Coast of Scotland" and "Reeds Nautical Almanac".
  20. Hello Michael It looks like a wonderful diversion to while away the cold dark Alberta winter months. Best wishes for a successful build.
  21. I thought the flag locker looked very bare...... So I got some flags from the net and filled the locker........ As you can see I also built up the sides of the seats. Cushions to follow. Very little of the flag locker will be visible once the chart table is fitted over it. But I know it is there!!!!!!!
  22. Thank you Bob and everyone else who has paid a visit.
