KeithAug
Everything posted by KeithAug
  1. Brain, looks interesting in a blunt sort of a way. I'm signing up .😀
  2. Good to see your sense of humour hasn't deserted you. The fact that they are contemplating letting you home tomorrow seems to be a good sign. Keep taking the morphine. Best wishes for a speedy recovery.
  3. Yes Andy. The hull surface at the point of contact is curved in 2 axes and of course I also had to allow for the tolerance between the fore and aft vertical supports and the tolerance on the abeam width. The 4mm of adjustment that the eccentric rings gave me was very necessary.
  4. Hakan - Belated best wishes re the surgery. It's now Tuesday evening and hopefully it will all be over and you will be on the mend. I hope the nurses are pretty and that you are chasing them round the ward by midday tomorrow.
  5. Ras - I quite often use a mixture of solder and CA on components. I start with soldering but when I think structures are too complicated or small to protect from the heat of further soldering I revert to CA. Take care not to heat up brass which has been joined using CA. The heating will break the bond. Great job on the gun.
  6. Eberhard - yes you are right - but the option of lowering the table might have ended in divorce and that is very expensive option at my time of life. Druxey - it doesn't look that bad in the flesh, I was clearly focusing on it in the photos which I think emphasised it. Brian - I'm not sure. I tried looking up compatibility but couldn't find rubber against poly. Fingers crossed. Eberhard, Druey, Rick, Keith, Tom, Steve, Brian, Mark - thank you all for your comments.
  7. Mark - Thank you for you kind comments. A pig stick (occasionally pigstick[1] or pig-stick[2]) is a staff that carries a flag or pennant, usually the burgee of the boat owner's yacht club or private signal, above a mast of a sailboat.[3] The pig stick is connected to a halyard so that when raised to the top of the mast, it extends above the mast, allowing the flag to be seen flying above the boat's sails.
  8. Keith - Interesting technique for the rat lines - must remember. I'm impressed - my head is rarely in the game for long periods these days!!!!!
  9. The deck structures somehow jar with the sleekness of the overall ship design. The designer must have gone into utilitarian mode when he drew them.😀
  10. Interesting looking little craft. It will be interesting to see how it turns out.
  11. Tom - as you rotate them they move closer to the hull - hence they clamp against the hull. If they were concentric they wouldn't do this. In effect they are acting like a cam.
  12. Lovely work on the deck beams. Like the jig. I hope you got the drum sander in your birthday present pile - if not perhaps next year! Like you I don't have a drum sander but I can't decide if I really need one. I have a sanding drum which I mount on the mill which sort of works. The issue I have with drum sanders is that I am sure that I would constantly want to change between coarse and fine grades of sand paper and most drum sanders don't seem to make this a quick and easy operation (unless someone knows better).
  13. Ras - well done but as per Eberhard it would be good to see something to show the size.
  14. Despite the continuing cold weather and many hours discretely studying my next build I did brave the worksop to finish the display cradle. I wanted the model to be lightly clamped by the cradle at deck level so I turned some eccentric rings to act as clamps. I also machined an "o"ring groove in the rings to provide a soft bearing surface. I also machined a spigot at the lower end of the supports to fit into a cross brace. The cross brace is necessary to prevent the supports splaying under the weight of the model. The cross braces were machined from 1" x 1/4" aluminium bar and polished to finish. The base was given 5 coats of wipe on poly and wire wooled between each coat. The supports were then attached to the base using 6mm screws. Then it was time for germania to say bye bye to the building frame that she had occupied for the best part of 3 years. The critical element of the move was the tolerance between the model and the keel slot. Fortunately I got the cradle dimensions right. The position of the clamping rings was also a bit tricky but this also turned out well. And finally the most critical check------------ That was a bit too close for comfort - about 3/8" Now just a few finishing touches required - a good clean, make the pig stick and burgee and the ships flag. Then it will be time for a major photography session. I must think about starting my next build log. P.S. Damn - I just remembered that I installed the for top fore mast back stay as a single fixed back stay when it should have been a pair of running back stays. Im sure no one will notice but that's not the point!!!!!!!!! 5 more blocks required and some rigging rework.
