KeithAug
Everything posted by KeithAug
  1. Thank you Pat, Richard and MCB for your comments, and thanks to everyone for the likes. Pat - I think i have not been as good at polishing of late however my general process is machine finish, polish with 600 grit wet and dry, then polish with 1200 grit, then 2400 grit and then finish with Brasso liquid polish. I generally tend to accept that brass ages however if I really want to prevent this I use Renaissance, Micro-Crystalline Wax Polish. A bit expensive but excellent for maintaining the shine for years. Update:- From an earlier post, Eberhard thank you - modified radar. You may also recall that I doubted the strength of the shackle attachment to the turnbuckles. That is the lower end in the next photograph. I proved they were not strong enough when rigging the bowsprit - Pinnnng!! Although not as accurate I modified all of them as follows - old version top - new version bottom. The mod involved using a vey small split pin made from .020" x .040" section brass strip. They are now much stronger and when not subject to close inspection they look fine. The bowsprit was rigged with .024" Beadalon clear coated multi strand steel wire. I bought wire guards to simulate thimbles and keep things neat. The end of the wire was stripped, threaded through a 1mm ID by 1.2mm OD tube then through the wire guard and then back through the tube. The loop was secured with a drop of CA and then heat shrink tube was used to simulate the leather protective sleeve. The "large" file in the photo is a standard needle file. I rigged the port side bowsprit shroud very tight to correct a slight bow in the bowsprit. This worked very well. Until --------- after about an hour ----- pinnnng. The attachment to the hull was too weak and parted company. The small bracket had been soldered to a 1/16" spigot and then inserted to a hole in the hull. The solder failed. The bracket was attached to a 3/32" spigot and reinserted. Thus far this has held despite the tension in the cable. The starboard bowsprit shroud didn't quite need as much tensioning and in consequence the hull bracket held (thus far). The bobstay was rigged next, again with a fair degree of tension.
  2. Quite a complicated bowsprit rig, very interesting. I'm not sure it is a boat for a squall? Thank you for the block size details. I need to make many in 3 sizes large 7mm, medium 6mm, small 5mm. Looks like being a lot of fun but i will need to think about simplicity of production.
  3. I'm still working on the main and foremast booms. The sheave for the reefing line was fitted. The boom was slotted on the mill, a small sheave was inserted and then the wooden closing piece was glued in place. The closing piece is a lighter coloured wood on the original and this was reproduced on the model. The end boss was turned and glued in place. The cleats at the fore ends of the booms were made. These were made from wood and brass as per the original. The vertical hinge pin was made with an upstand drilled for the attachment of the sail. The horizontal pin is obviously a temporary arrangement. The fore mast boom followed a similar process.
  4. Thank you Richard - I see your Bluenose log has been quiet for a while. I trust all is well with you?
  5. I must admit I hadn't realised how big the vessel is. Lots of opportunity for detail.
  6. One has to get the priorities right. Valeriy, Germania has a steel hull and rudder. the original Germania was built for the German steel and armaments magnate Krupp. Early on in my build log a lot of discussion took place on whether to paint the entire hull or leave the wood finish. In the end I couldn't live with painting over the mahogany and compromised on the wood finish.
  7. A bit of sorting out loose ends before getting back to the masts and spars. The screw and the rudder have been sat in my bits box for over 2 years and now seemed to be an appropriate time to fit them. The bore for the screw had been pre drilled and it was a simple case of insertion and gluing in place. Holes for the hinge mounting spigots had also been predrilled and these were inserted and glued in position. The rudder shaft was a piece of 1/16" brass rod. Fortunately, by either luck or judgement, it slid into place without interfering with the screw. As can be seen the shaft locates in the 4 hinges and a hole in the hull and keel. Satisfyingly the alignment was spot on. To mount the rudder the shaft needed to be in 2 pieces ( a gap being required at the screw cut out). The upper shaft had to be inserted through the lower part of the rudder. Some time back one of you pointed out that I had omitted the cross brace below the on deck dining table. Quite a serious omission as its main use is to brace the crew who are sitting and drinking gin while close hauled. I had looked at retrofitting it some time ago but getting it located and glued in place had proved somewhat fiddly, so I left it for later. Today was "later". After some head scratching i decided to fix the brace to the end of a piece of scrap wood with double sided tape. The correct height been set with a couple of shims. With this set up the brace was moved into position and glued with CA. Once the glue was dry the scrap wood was eased away breaking the double sided tape bond. The crew can now drink their gin in comfort in the knowledge that they are no longer rudderless.
  8. Jon - than you for documenting the sail making process, very educational.
  9. Yes Micheal. I am still working my ay through a 1930's mahogany dining table, picked up for a song at the local auctioneers. "Brown" furniture is really out of fashion here and much of it ends up in the skip. Cutting up a quality table seems a crime but at least I rescued it from oblivion. Old mahogany is vastly better than the modern stuff. Thank you to everyone for your continuing support and comments.
  10. Eberhard, beautiful job - the spacing on the bars looks excellent. I tried to look up what vintage LRZ 602 was but failed.
  11. Hi Pat, Is the shipyard experiencing an extended shutdown? Looking forward to the next instalment.
  12. I don't know how it is possible to make such quick progress. Do you ever sleep?
  13. Keith - I finished my machine training when I was 17 and although i worked in engineering roles throughout my career I was never required to cut metal again in anger throughout my working life. I only started machining again when I retired. It's amazing what you remember over the period of 43 years (between the age of 17 and 60).
  14. Thank you all for your kind comments. I'm not sure they were very interested in my boat building skills Keith. Today I did a bit of assembly - feels more like progress than many tasks. I thought I would start with a photo of the main mast taken several weeks ago - just to give some idea of scale. I think I am going to need to start a negotiation with my better half on Germania's final display location. The main mast cross trees started out little bare. But soon acquired a pair of deck flood lights. Then the various electronic appendages started to appear together with the ships horn. I needed 6 aerials - made from wire and bar - a simple bit of turning. A quick coat of paint and they were then glued into holes previously drilled in the cross trees. I also added the cables which support the top mast. I left the radar off for the time being. I then move to the foremast - which was somewhat simpler.
  15. Interesting process for making the blocks, they turned out very well. What are the dimensions for the 3 sizes please?
