Everything posted by Gaetan Bordeleau
Hi Mike, to add to your LED update, as a comparison: -my bridgeport milling machine came with a fluorescent light close to the cutter -2 examples of working lights: on the working table and on the ceiling The best working light you can get are effectively LED lights. The best ones come from photography. You do not really need to adjust the color temperature, it is better to choose one with only daylight which will give a constant light as if you were working outside during the day, this way you will always see the real color of what you are working. It is preferable to have an adjustment for the intensity of the light. If you want to get rid of the shadows when you are working, you position one light on both sides The foot of the light is what you could call a universal position adjustment. Continue your good work.
- 969 replies
- hahn
- oliver cromwell
Hi Vossiewulf, I agree at 100% about the blades that Vossiewulf uses. In the "exacto size blades", these are the best quality hard steel available. Heres is my favorite knife... from Vossiewulf:
After I built the last cabinet, all the small tools fitted 1 cabinet, so I gave all the other wood cabinets. Storage for these is incredible for metal tools. You can customize each drawer and each drawer they can support 300 pounds. I have another series of chest. they were used by a lens fabricator. They had cardoard little boxes that I also used int he small wood chest.The global idea is I guess when you have few tools, you need drawers.
Antique wood dental chest are very nice. We could say it is like a Gerstner chest with more drawers. With the years, I did some tool chest in this style. The last one I did include over 1000 tool and accessories. The main difference and also the main reason it can have so many tools is because of the height and the depth of the drawers.
I have seen a lot of rope making machine over the years from the most simple to the most exotics. There are a lot of ways to turn ropes and the quality of the turned ropes can cover a wide area of quality. Here are 2 example of rope machine, similar in their principle: The rope machine from the Musée de la Marine The rope machine I use One of the greatest advantage of this type of rope machine is that it can control the rigidity or the flexibility of the rope. The more weight, the more rigid will be the rope and also the swivel is a regulator for the tension and the number of turns. There are a lot of tools on the market and some do the job the best way possible...
Chisel hone guide question
Gaetan Bordeleau replied to CPDDET's topic in Modeling tools and Workshop Equipment
Jewelry is a good source of inspiration for tools, Here is an example of the classical workbench 100 years apart. Electric height adjustable desk is probably the best tool we can use for many reasons. I have seen many declinations of armrest, the first one I remember was a felt donut recovered with leather for the elbow. In a way, all these resting tools offers the same thing: allowing to rest a part of the arm to have a better control of the hand.
I would say that the main difference working small vs larger is the concentration level is very much more demanding, especially in carving to control your hands moves which are much more smaller. The magnifier style you use is a personal choice. I like to work with Optivisor and for smaller scale I like to use a surgical loupe and occasionally for quality control a microscope.
Why nobody in the books talk about this subject? I think, we highly underestimate the enemy: the aggressiveness of the salt. Why would a line be tarred and the next one untarred? Inevitably, by cross contamination, both lines would finish tarred. Jean Boudriot wrote a letter about which lines are tarred. One sentence is interesting: The rope for the ship rudder wheel is not expose to the salt, so tarring this line is unjustified. Does that mean that the idea is very simple: If a line is expose to the salt, tar the line.
I did a figurehead at 1/192 and used the microscope just for finishing touch of the head and the hands. I do not like to carve with chisels because you have to control the strength you are using. It is much easier to control with dentist burs, no strength required, you just let the tool work. Also for the vision it is easier to work with chirurgical magnifying glass or dental loupes with a working distance between 10 and 20 inches.
Wood color is a very interesting subject. For years, I used different exotic wood colors and I did like it. The choice of the wood colors is primarily a personal choice and we must be careful not to use too much "contrasting effects". In the recent years, I changed that choice and I prefer to use only 1 kind of wood. For 1/24 scale I would classify cherry as a prime choice. The wood we use should be ideally similar to oak at 1/1 scale to oak at 1/24 scale. Cherry does a very good job at this level. You must be careful in the choice of the planks you will use. Cherry has few wood grain configurations. The best one is the one that runs parallel to the plank and the one to avoid is the one where the grain runs perpendicular to the plank.
probably, they all can send photos to this forum as long as it is .jpeg format I do not know Android phones but photos format are probably not .jpeg by example Iphone are .heic which needs to be converted to .jpeg before sending it
The configuration I use: everything on wheels, this way I can set the tools as I need for every project. Workbenches are massive and are made to build furniture. Electric height adjustable table is better suited for a modeler, one of its main quality: working at the good height as much for the hull and the rigging.
