Gaetan Bordeleau
Everything posted by Gaetan Bordeleau
  1. Hi Vossiewulf, I agree at 100% about the blades that Vossiewulf uses. In the "exacto size blades", these are the best quality hard steel available. Heres is my favorite knife... from Vossiewulf:
  2. Cherry carves well. But it depends of the level of details. Cherry will not be able to take extra fine details.
  3. Actually there is a major restoration program going on and they will be display again. Photos up there came from a series of video about the restoration actually happening. This type of rope making machine is used to make ropes for models varying from 1/12 to 1/192 scale.
  4. After I built the last cabinet, all the small tools fitted 1 cabinet, so I gave all the other wood cabinets. Storage for these is incredible for metal tools. You can customize each drawer and each drawer they can support 300 pounds. I have another series of chest. they were used by a lens fabricator. They had cardoard little boxes that I also used int he small wood chest.The global idea is I guess when you have few tools, you need drawers.
  5. Antique wood dental chest are very nice. We could say it is like a Gerstner chest with more drawers. With the years, I did some tool chest in this style. The last one I did include over 1000 tool and accessories. The main difference and also the main reason it can have so many tools is because of the height and the depth of the drawers.
  6. This rope machine can be use for all size of models. There is not only the size of the ropes but also the number of ropes. By example, the biggest anchor rope I turned was made with 3 (64 X 3): 576 threads.
  7. Or by changing the weight. It is easier not use the pulley but to reduce the weight instead. Simple machine and as much effective as it can be: gear system to tun ropes, cone not to mix the ropes, swivel and weight to get the perfect rope in number of turns and tension.
  8. I have seen a lot of rope making machine over the years from the most simple to the most exotics. There are a lot of ways to turn ropes and the quality of the turned ropes can cover a wide area of quality. Here are 2 example of rope machine, similar in their principle: The rope machine from the Musée de la Marine The rope machine I use One of the greatest advantage of this type of rope machine is that it can control the rigidity or the flexibility of the rope. The more weight, the more rigid will be the rope and also the swivel is a regulator for the tension and the number of turns. There are a lot of tools on the market and some do the job the best way possible...
  9. This tool was done for this many years ago.
  10. Jewelry is a good source of inspiration for tools, Here is an example of the classical workbench 100 years apart. Electric height adjustable desk is probably the best tool we can use for many reasons. I have seen many declinations of armrest, the first one I remember was a felt donut recovered with leather for the elbow. In a way, all these resting tools offers the same thing: allowing to rest a part of the arm to have a better control of the hand.
  11. there is the same thing in art painting and it is called painter mahl stick
  12. I would say that the main difference working small vs larger is the concentration level is very much more demanding, especially in carving to control your hands moves which are much more smaller. The magnifier style you use is a personal choice. I like to work with Optivisor and for smaller scale I like to use a surgical loupe and occasionally for quality control a microscope.
  13. Why nobody in the books talk about this subject? I think, we highly underestimate the enemy: the aggressiveness of the salt. Why would a line be tarred and the next one untarred? Inevitably, by cross contamination, both lines would finish tarred. Jean Boudriot wrote a letter about which lines are tarred. One sentence is interesting: The rope for the ship rudder wheel is not expose to the salt, so tarring this line is unjustified. Does that mean that the idea is very simple: If a line is expose to the salt, tar the line.
  14. Every tool yo will choose will always be a personal choice. Here is what I would use especially to be comfortable while working: height adjustable table, omnidirectional vise, micro motor, magnifying lens and at least 2 LED light adjustable in intensity and position.
  15. I did a figurehead at 1/192 and used the microscope just for finishing touch of the head and the hands. I do not like to carve with chisels because you have to control the strength you are using. It is much easier to control with dentist burs, no strength required, you just let the tool work. Also for the vision it is easier to work with chirurgical magnifying glass or dental loupes with a working distance between 10 and 20 inches.
  16. As usual, I know nothing about English Construction. If it would be a French warship, the lower part touching the feet would be parallel to the upper one, simply because it would be much more pleasing to the eye, but as a counter effect, it would probably change a bit the angle of the figurehead.
  17. If it is only for model ship building, , this drill press is not required. Cameron drill press are made to reach high level of concentricity on metal, and it is not necessary for wood. At $300, you will surely need to replace some parts, chuck and especially bearings.
  18. Wood color is a very interesting subject. For years, I used different exotic wood colors and I did like it. The choice of the wood colors is primarily a personal choice and we must be careful not to use too much "contrasting effects". In the recent years, I changed that choice and I prefer to use only 1 kind of wood. For 1/24 scale I would classify cherry as a prime choice. The wood we use should be ideally similar to oak at 1/1 scale to oak at 1/24 scale. Cherry does a very good job at this level. You must be careful in the choice of the planks you will use. Cherry has few wood grain configurations. The best one is the one that runs parallel to the plank and the one to avoid is the one where the grain runs perpendicular to the plank.
  19. I was looking at the alignment of 3 ships... is that enough to call it: Ships of the line?
  20. probably, they all can send photos to this forum as long as it is .jpeg format I do not know Android phones but photos format are probably not .jpeg by example Iphone are .heic which needs to be converted to .jpeg before sending it
  21. The configuration I use: everything on wheels, this way I can set the tools as I need for every project. Workbenches are massive and are made to build furniture. Electric height adjustable table is better suited for a modeler, one of its main quality: working at the good height as much for the hull and the rigging.
  22. I tried a new way to take photos inside a ship with an endoscope from Amazon for $55 cdn. Wifi HD 5MP 3-8 cm. It is good for focal distance very close 3 to 8 cm only. There will be no good results for a complete deck. for this you will need a camera with auto focus capability like the Go Pro. The camera can take photos and videos.
