ETNZ
Posts posted by ETNZ
I have a very dark sense of humour Henriksen. You are welcome to my paradise, it is no more than you deserve. She’s going to be a cracker. I have tried paying with the bowsprit as something a little different. It was difficult to get my fingers around the whipping but I have managed most of it. I am determined to get some additional photo’s onto my build log. I just never seem to have time to work it all out. Keep going and you and yours stay safe too.
- Henke, FrankWouts and Nirvana
- 3
Wow, great stuff. I like the way you have resolved the issues on the stern. I have not done as much there. I have been fed up with cannon so started on the bowsprit which is looking quite good I think. However, last Thursday, disaster struck. I was feeding the cows when the barn door blew shut. The corrugated iron on the door sliced neatly through my middle finger of my right hand (I am right handed). The cut almost removed the tip right through the nail. I have had it stitched and the nail removed on both sides. I guess I’ll only be looking at the model for a while now as I cannot do anything fiddly. You will have caught up to me by then!
- FrankWouts and Nirvana
- 2
Hi Henrik, I think that you will find they are referring to the gunports on the open portion of the upper gun deck beneath the ship’s boats. These are lined through to the internal bulkheads too. Those on the Poop will not of course be framed (I think). You are doing really well on her however. I have come to a slow patch with it being the end of summer, my wife wants firewood in and with the lockdown here in NZ I can’t wait to get out of the house where I have been working from home but there is so much to do! Roll on winter when I can get stuck in again and ruin my eyes in the dim light!
Take care and stay safe.
- Nirvana, Henke and FrankWouts
- 3
Henke,
you have made the same mistake as me. The etched doors on the aft panel should face inwards. That way when the balcony is finished, it all looks correct. I’m going to have to get my skates on. Your build is coming on well. Great job on the planking.
- 3
Nice model by the looks of it Christian. I’m looking forward to watching it develop. Really interested in your first planking method.
She looks great mate. The bottle being empty is no bad thing. It gives opportunity to invest in another and watch time pass. Your planking is way better than mine was Henrik, just a quick question. Did you too end up with a dip in the 4/5 rib area on the starb’d bow? I am starting to think that there is an issue with the kit in this respect as several other builders here have hit it too. It doesn’t appear to have anything that causes it to be out of line yet it happens. Anyway, good to see you enjoying her still. Are you intending on second planking with long planks or cutting down to scale planks at 120 mm thereabouts? I tried both on mine the longer ones below the waterline and under the copperwork to come. I found the shorter lengths made shaping and bending so much easier. Have a Scotch and think about it.
- Retired guy, Nirvana, Henke and 2 others
- 5
Good choice. Not my favourite Scotch by a long chalk but shows a certain taste in the man! Hope all’s well and you haven’t been driven to drink over her?
- FrankWouts and Henke
- 2
I used balsa on my build of HMS Agamemnon, it was as good as useless in my mind. In future I would use a soft wood but much firmer than balsa which would accept a pin and hold it without straining to push it in.
- Dan Vadas, thibaultron and mtaylor
- 3
My build too has been slow. I have had a period where my build stopped due to a medical issue causing numb hands. Now this is corrected, I hope to steam ahead. I hope you enjoy the summer. I found the second planking best with individually cut 124mm long planks. A, it gives a better finish under the paint, b, the shaping was much easier.
Regards
Eric
Thanks Henke, are you at this stage yet? It is really boring even worse than planking her!
Copper sheathed bottoms are not my favourite! Starb’d side finished to the waterline. Guys, I know you like photos but really, watching paint dry would be far more exciting! These were taken around the halfway stage. Nothing special, just repetition. I’m thinking of breaking and repainting the side before starting the Port side, then moving onto the keel.
- ccoyle, KARAVOKIRIS, GrandpaPhil and 4 others
- 7
Great job on the planking Henke. Remember that this is the first planking. I am building this as my first build, I became hung up on a problem around the bows area. Eventually, I simply accepted it was not the end of the world cut a portion out and rebuilt it. I then found having smothered the hull in filler and rubbed it down, there was actually very little filler left. I then covered it all anyway! My time on the vessel is restricted by my work too. So, many years of watching your build ahead will likely be finished around the same time. Good luck and enjoy the build.
Great small boats. My best news is that someone cancelled their surgery and I was given an early call. So, neck surgery done about ten days ago and it is so good to get the feeling back in my hands. I am not able to carry on with the main build but am making the incidentals like the anchors etc whilst convalescing. I hope that your polymyalgia stays at bay. Good luck as you press on.
Just found your build log Donn. She is my first build and I am at the same stage as your after about four years. I became a little disheartened with the first planking not laying exactly as I would like and then ploughing through others logs aw that it was just me being over sensitive to my need for perfection. Filler is a true friend now. I found the second planking easier and better. Subsequently, I have suffered a slight medical set back which now seems to be fixed so, whilst we shall certainly not be competing in the build speed stakes, I shall follow with pleasure knowing someone somewhere else in the world is having the same issues as me with this great kit. Yours is looking great and I look forward to more entries as you go. I also am still working which takes much of even my “spare” time!
Just seen this build. Wow, flights of fancy, pimp my boat and such words come to mind. Love it. You have so many original ideas this has quite blown me away. I too am building a vessel where I didn’t want the finished article to look like a pristine out of the box kit and have tried to weather it a little. Your treatment of the running tackle and rigging is the sort of thing I want to do so I hope you will not mind me pinching your ideas. Awesome well done and I shall keep an eye out for any future builds. Thank you for sharing this with us.
- Ekis and Old Collingwood
- 2
A beautiful build. It has encouraged me to look at this model next. I sailed on her sisters ship the Malcolm Miller. I do not recall the basket on the foremast though. Two most stunning moments of the cruise were my first time aloft was about 2am one morning in reasonably strong winds to bring in canvas. The second was being out on the bowsprit bringing down the jib. The bow plunged down and the water shot up my oilskin trousers, came out above the bib and was then forced down my arms and out of the neck. It made me look like a human fountain! Thank you for bringing back the memories. The only difference between the two that I am aware of are the tops of the doors on the Miller are square and she apparently slipped in dry dock at some stage and the Miller is slightly banana shaped. It is said this makes her slightly faster. Those who have sailed on the Churchill will say otherwise however.
Chris you mentioned staining your decks. I did mine with tea, vinegar and steel wool. It has come out quite nice on the decks if a little dark perhaps. The smell dissipates, so don’t worry about that. Lighting your first build is very adventurous. I like the idea. I hope it goes well for you and I look forward to following your build log further.
Hi Martin, well done on picking up the cudgels again. My build too has had a chequered history. I got he’d up on perfection as a first build and then pulled myself together. I picked around did small bits every now and then but didn’t make any great advances. I now have a neck problem which means no feeling in my fingers. Not great for modelling! My boats had the same issues. I would love to see photos of yours. Intrigued as to your table saw, what type is it?
Planking finished, first coat of paint on the body and fixing the brass rubbing strips. I have decided to work on the hull inside and out to get it squared away before I tackle the coppering. I hate the repetitive nature of the planking so I don’t know how coppering will go. Still persevere and overcome. I’m still trying to get photos to upload so bear with me ?
HMS Agamemnon by Henke - Caldercraft - 1:64
Sorry Henrik, auto corrected and I didn’t check.
