Posts posted by Remcohe
My hat is off to you Sir, splendid work.
Remco
Jan, the bottom of the rudder should be higher than the top of the false keel. Otherwise the false keel (if it comes of when hitting ground) would rip off the rudder in the process. The issue occurred when I marked the hight of the pintles using the pre cut slots on the sternpost. I should have noticed it then
Remco
Thanks all for helping me to sort this out.
Jan, 0,5 mm copper rod scored with a sharp blade made the screw head.
Sorry Grant, no way I can make working screws on this scale
So that said, the gudgeons are made, again from brass strip and bar silver soldered together and formed to follow the hull curvature. I'll probably use some castello shims to compensate for the missing hull planking. Some adjustments are still needed before I can bolt the gudgeons permanently to the hull. Somehow gudgeon #5 ended up under the transom planking
Remco
Michael,
Thank you very much for your elaborate answer, this is very helpful. I now understand I need to add a few very important steps in my drilling procedure. One being to start using a good center drill to mark the drill points.
Remco
- michael mott and mtaylor
2
Michael, your metal work is exquisite and a joy to watch.
Do you use some sort of sensitive drilling attachment when you use the PCB drills? Mine always break whenever I use them in the mill or drill press and whenever possible I revert to drill small holes by hand (a tedious task.....)
Remco
Looks really wonderful Gil, I love the different shades of colour and with the details added it really comes to live.
Remco
A long overdue update, be it small is more than one way
The tiller hole was repositioned and the hoops were added
The pintles are browned, bolted & screwed to the rudder, (okay I simulated the screws.....)
Next up the Gudgeons, any ideas how long they need to be? TFFM only shows one, are #2 to #5 all the same length?
Remco
Looking great Ben. I remember how tedious the framing was on my KF and I allowed myself the occasional break to make a sub assembly of some kind for use further down the road. Hang in there you are nearly there.
Remco
- Trussben and shiprookie
2
This is metalworking of a whole different league..... Splendid work Michael.
Remco
- michael mott and WackoWolf
2
Oh yes, the hooks look much better.
Which etching service did you use?
Remco
Good to see your updates again Sir, looking great.
Remco
HMS Atalanta 1775 by tlevine - FINISHED - 1:48 scale - from TFFM plans
The painting looks very convincing. I'm still in doubt wether to paint my friezes or not....
Druxey is right, I remember from my arts classes at the uni, soak the paper really well and use special tape to tape it down to a board. I used the same technique to prepare paper for airbrushing.
Remco
