Posts posted by Remcohe
I had the honour and the pleasure to see Piet's model in real life. All the pictures on MSW don't do her justice, she is stunning. The hull looks very realistic from all angles and the texture matches the steel plates the original was made from. All the details actually work, Piet had me try them out all. From hoisting the anker, the torpedo deck launcher is out of this world, the AA guns that can lower into the bins, the pulley's, even the break on the pulley works, etc etc. The colours are vivid and really do the model just.
Piet if you still wonder if your Dad is proud of the model you made of the ship he loved most? He should!
My wife also had the pleasure of meeting the builder and his charming wife, we enjoyed every single minute of it.
Remco
- Omega1234, GLakie, SawdustDave and 5 others
- 8
Piet, how wonderful she turned out, it was great to follow your build and read your stories accompanying it. Now O19 has a face of someone who sailed her and the stories that gives her a place in history. I'm pleased I'll see her first hand and her skilful builder too in two weeks .
Remco
Wow lots of space compared to your appartement!
Remco
Again you have build a true master piece. Congratulations Karl.
Remco
- Jeronimo and Mirabell61
- 2
Johann, it's a joy to watch your work. Outstanding craftsmanship
I'll try your method for the hooks, they look superb.
Remco
The detail and shape of the hook is impressive (as everything else.....)
Remco
- Rustyj, Mirabell61, mtaylor and 26 others
- 29
Thanks for the dimensions. I don't use a scale ruler but a conversion table to quickly get from feet/inch to mm
Work continued on the bowsprit step. To accurately determine the step (square hole) in the chock (the vertical plank between the bitts) I had to make the bowsprit itself too. I find it very satisfying to make a mast just with hand tools, it takes time but the result is very accurate.
While cutting the step the rabbet between the two planks very nicely
The bowsprit was cut from square to octagonal to round using a hand plane, well honed chisels and sandpaper.
The base going from round to square
And the tip
The step is also rebated into the upright bitts
Remco
- Elmer Cornish, mtaylor, Dubz and 33 others
- 36
Congratulations Dave, she turned out really great
Remco
Thanks all for your kind comments.
Next up is the bowsprit step. As I needed two of the forecastle deck beams to determine the size of this part. Not looking forward to this job I made an (warning off topic) 1/35 BMW R75 with side car, a nice little plastic kit from Lionroar. After that I found new energy to return to the KF and I went ahead and cut all forecastle and quarterdeck deck beams so they are ready for future use. Some parts still need to be made but I can not find the with of the crosspiece. Any ideas? I guess it's shorter than the main topsail sheet bitt crosspiece...
Remco
I 'like' the odour of turpentine better than mineral spirit.
I never buff the surface, I want a dead flat finish
Remco
Vaddoc, it's better to use turpentine instead of mineral spirits. Is smells a lot better and if you warm it up a little (not too much be careful as it is flammable) the wax will solve better. I tried it and the finish is nice but will not harden completely, you can indeed forget glueing or painting parts afterwards so plan ahead when you are going to apply the finish. In the end I switched to heavily dissolved tungoil, thin coats dry within a few hours.
Remco
Congratulations Ben, this is a big milestone. You probably thought there would be no end to adding frames
Remco
Nice top masts Bob. I have a mill but I certainly don't use it to make my masts, just square stock and hand tools, just like you do, give a much better result (and satisfaction )
Remco
Nick, with diluted tung oil (applied sparingly ) it has no sheen and thats what I meant with dead flat. I have the mixture in a small jar and it will keep for at least 2 years, that is how long I kept is. Glue won't stick to well if the wood has been treated with tungoil or any other oil or wax based finish. So you'd better think ahead before applying it.
The fore mast step, this is a nice little 3D jig saw puzzle. I realised I had to reposition the two deck beams that incorporate the mast step to properly align with the mast. No big deal but I felt pretty dumb when I noticed my mistake. Most straight forward cuts were made on the table saw that acted as router. The rest was cut with a chisel.
Remco
Frigate Essex by Rafine - FINISHED - Model Shipways - Kitbashed
Congratulations Bob she turend out fantastic. Your display room must be getting very cramped with all those models.
I really enjoyed following your build and look forward to the next one ;-)
Remco
