Posts posted by Ferit
Hi,
Thank you for the nice comment.
For the frame, I used the strips that I cut from a credit or similar card. I don't know from which material the credit card is made, I just used it because it was easily accessible. The thickness is ideal and uniform. It takes shape very easily in hot air with hair dryer and keeps its shape when cooled. I provided the semicircular form by wrapping it around a pencil and giving it hot air then waiting for it to cool. I made decorations by glued some small pieces. Very strong when glued with CA...
Then I painted the whole frame in gold with spray and aged it with some touches with black watercolor paint. I finished with glossy polish...
For the windows glass, the glossy black thin plastic material inside a CD case was used. It was as if it was dark inside and it wasn't visible from the outside, I just wanted the effect that there was a glare in the glass.
Then I glued the CD case plastic to the frame and sanded the outer parts... And some touches with gold to the sides because of the plastic was visible in black...
I used those materials because I had not any idea how to find the appropriate material, they were under my hand...
The inside part of the CD case is mat at the attached photo, I had used the glossy one
Thank you very much for your concern and the information...
- Louie da fly and mtaylor
2
Thank you Allan and popeye2sea,
I am referring to the Frigate Berlin 1674.
I thought that to fix a yard to a mast that holds a sail inflated by a strong wind to drive a heavy ship at sea is case important.
Is its halyard enough to do this?
Will I make a mistake if I add parrels to topsails yards? Or have I to follow the kit plan...
That's exactly what I'm looking for ...
Keep on following you... Keep on learning...
Thank you...
- EJ_L and popeye the sailor
2
Hi Michael,
It had been written as size, 10 mm and 6 mm.
Do those sizes belong to parrel beads or spacers? I need this info because I am looking for them of 2 mm of diameter. And are they wooden spacers?
Thank you...
- popeye the sailor, EJ_L and md1400cs
3
Please let us know what their diameter is...
- md1400cs, EJ_L and popeye the sailor
3
In fact, I do not believe in the historical accuracy of many kits. Except for scratch builds, it's a separate category.
Even in a popular ship like Wasa, where the original exists today, where there are examples in the museum, different companies produce different Wasa kits.
So if you decided to go with the kit, in my opinion it is enough to get close to the historical accuracy without waiting for it to match entirely...
Hi JP,If you do not log in frequently, and if you look to the photos instead of reading all the comments, unfortunately it is inevitable to use false expression as I did...Sorry...It should be:" I'm sorry to hear that you had given up on this production when I am thinking about it; flashy ship, a good choice both as a ship model and as a manufacturer and outstanding work as expected... "
Flashy ship, a good choice both as a ship model and as a manufacturer and outstanding work as expected...
Superb... Rigging work... Excellent...
- mtaylor, Beef Wellington, md1400cs and 4 others
7
Wonderful, clean and sharp as always...
- Beef Wellington and cog
2
On 7/16/2019 at 4:17 AM, john_weiman said:
Hi John,
My opinion is that the direction of the wood block may not be correct. Should rotate 180 degrees...
Unfortunately I've just come to realize the great work you've done.
Now I have to examine thoroughly from the beginning...
Fabulous...
Agilis by popeye the sailor - Steingraeber - 1:60 - brig
Hi Popeye,
Incredible... I take a break, then I see a new and beautiful ship when I re-enter the site ... Your productivity is unbelievable...
Fine work as always...
