CDW
Everything posted by CDW
  1. Almost done now. Needs anchors and chains, outer railings, and a little weathering.
  2. I have a few different ideas, but haven't settled in on one yet. It begs for some type of heavy maintenance scene or similar display.
  3. If you sand the outside of the cockpit tub as well as the inside of the fuselage halves in the cockpit area, could that possibly give you more space for the cockpit to fit? From the photos, it looks like you're very close to a fit now.
  4. I usually wait until the end to add the propellers. Keeps me from knocking them off and losing them. Thanks Alan
  5. Most of what you're describing has a vague similarity to the differences in CAD drawings and mapping software. What works just fine in CAD won't cut it in mapping software, even though they are similar in many ways.
  6. Your hull looks beautiful! Nice job you did with it. I have done many fiberglass coverings on large models I've built. Something important to consider is using the very lightest cloth possible for your particular application. Heavy cloth is generally not needed, particularly for static scale models and most ship models. Heavy cloth is hard to work with and often leaves air pockets underneath. Here is an example of a large balsa cowling I built for a 1:4 scale biplane R/C model. As you can see from the photos, even complex curves can be completely and smoothly covered with one piece of cloth by working it from top to bottom, pulling out the wrinkles as you apply the resin to the cloth/cowl.
  7. There are quite a lot of details that remain to be completed before it's finished. I will also apply the rigging and flags to this one before finished. Anchors, chains, boats, aircraft, davits, railings, etc. More AA guns, too.
  8. It goes without saying, this guy has his 3D printer dialed in. It's also important to know this is probably a CAD rendering and not the actual part, but from other of the actual pieces I've seen, they are very very good. RGL's example of 1:350 pom pom's are extraordinary.
  9. Before applying decals and weathering, everything is given a glossy coat of clear lacquer
  10. Yes, it's full indeed. The weight of the box caught my interest right away at the hobby shop as it seemed to indicate a well detailed model inside, as most Ryefield kits are well appointed. I'll need to be thinking of ways I can display the fighting compartment and all the other inner components, not cover it all up. Battle damaged maybe?
  11. Your cockpit is looking great Edward. Photo etch seat belts?
  12. I tried the game when it first came out, but never gained a solid interest in it. I'll never forget how my oldest grandson taught me a lesson or two playing Call of Duty. He would find and shoot me quicker than I could say, jack rabbit.
  13. No apology needed. Thanks for pointing it out. It might have taken me a while to figure out the error unless you had mentioned it. At first, I thought you were suggesting a longer title or impressing me with your language skills. 😄
