CDW
Everything posted by CDW
  1. When you buy a model aircraft with a detailed canopy frame like this one, do yourself a huge favor and buy a pre cut canopy mask if one is available. If your time is worth more than a dollar or two per hour, it will be money well spent. In this case, none was available to be found stateside, so I had to wing it.
  2. So glad to know you made it through surgery okay, but sad to learn recovery will be a longer process. I once had a Toyota Land Cruiser fall on top of me and it broke my shoulder. I was so sore after the third day it was unbelievable. Took quite a while to get past the soreness. Get plenty of rest and follow instructions. They know how to help you best get through the process without undue difficulty.
  3. Will definitely stay tuned for that one when you build it. Who publishes it?
  4. I have enjoyed your videos many times in the past and never realized you were a member here. Hiya Paul! Great videos, kudos to you.
  5. Continuing with the box stock build, used the kit decal for the seatbelt. The only thing added was a photo copied paper seatbelt to give the decal a more 3d appearance. Once the decal was in place and totally dry, gave the cockpit a dull clear coat to blend the colors together. Cemented the fuselage halves together , inserted the cockpit and cemented it in place, then cemented the wings to the fuselage. Will allow this to thoroughly dry over night.
  6. With decals and a wash, the office is dry fitted into the fuselage. Nice fit, no problems at all. Need to add the seat belts before buttoning it up.
  7. After some detail painting of the cockpit parts everything was given a coat of gloss varnish in preparation for decals and a wash.
  8. It’s pretty good right out of the box which is how I intend to finish this one. What I really want to do is try a different approach to the airframe painting using a mottle (sp?) technique. Saw someone else do it and want to try it for myself. Who knows, this could potentially make a 1:72 scale modeler out of me which would be something I have never done. 1:72 has gotten a whole lot better since I last checked one out. Molds are very nice. Very tiny, too.
  9. Kit box and contents Fuselage halves and cockpit pieces After a black base coat, a light coat of Japanese interior green. Typical Tamiya engineered fit is fantastic. I drilled out the lightening holes in the seat.
  10. Very nice looking parts you're printing there! I wonder if that "gold" label CA glue gives off toxic fumes like the other CA does? I know for sure it doesn't frost clear plastic like the other stuff does.
  11. Hoping the best for you in surgery tomorrow, HOF. I bet you will be back stronger than ever.
  12. You know the deal...SWMBO (she who must be obeyed) decrees, wishes are granted. Happy wife, happy life.
  13. Got a little more done between other more important chores.
  14. Thanks for the kind words Roger. Much appreciated.
  15. Nice job sealing inside that hull. Looks like you've done this before. 🙂
  16. Thanks OC. For some reason, the other side currently under construction doesn't fit quite as well as the one pictured. It only takes just a tiny fraction off to cause a lot of extra work, but nothing some patience and a good diamond file can't fix. Taking my time, enjoying the journey.
  17. Spent a little more time to finish up this particular detail, which will be repeated in kind on the other side of the ship.
  18. Thanks Mike. I know it's probably unorthodox, but I prefer to stand to do my modeling.
