tkay11
Posts posted by tkay11
  1. 17 hours ago, JacquesCousteau said:
    Looking at the monograph, I found the following about frame dimensions on page 41:
    "La membrure est compossée d'allonges ayant 88 [mm] d'épaisseur sur le tour et 122 de largeur sur le droit."
    Which google translates as:
    "The frame is made up of extensions having a thickness of 88 [mm] on the circumference and a width of 122 on the right."
    So I think the 122 is referring to the dimension of the frames from fore face to aft face, the frames are supposed to be 88mm thick (from exterior to interior side), at full scale
    I love your build and learn from it.
    Just to add a slightly unnecessary or rather silly note, your interpretation is of course correct, but just to give the 'nautical' terms in translation this is "The frames are composed of futtocks having 88 moulded thickness and 122 sided". Moulded being the measure across the outer surface of a timber which is shaped to fit the overall hull shape, as determined by the moulds. Sided is the measure across the sides of timber at right angles to the outer or moulded surface.
    Tony
  2. Thanks @JacquesCousteau, for the clarification. I had read your original post too quickly and thought you were referring to the Ancre translation! I had been so shocked by the translation you found that clearly I couldn't believe it.
    The English version provided by ANCRE reads as follows: "The rectilinear sternpost is fitted by a tenon into a mortice cut on the upper rear face of the keel, a small knee acting as the angular link between them." I have both French and English versions of the monograph and to my mind the English translation is fine. (The capitals for sternpost, by the way, are in the English version).
    I could never use an online translator for such technical work about boats of the age of sail. I agree they are next to useless other than in modern narrative passages where even there they just provide a guide to literal meaning. If you can't read the French it's definitely worth forking out for the ANCRE translation for the background history which I find most interesting, although as you're a craftsman you would easily get by just by using the lovely plan set.
    Sorry again for my confusion.
    Tony
  3.
    On 3/2/2025 at 4:22 AM, JacquesCousteau said:
    "The rectilinear stunt is assembled by a tenon in a squirrel on the back of the upper face of the keel, a small curve angular bonding. The bow and stunt wear a scribble. The embers consist of varangues on which apply to partial recovery (empat) of the allones thus prolonging the varangues and some nails hand-hold the covering."
    Could you let me know where in the book you found these sentences? I have not found them in mine. Nor could I find "Let's move on to the description of the hull of the boat with various drawings". The photo you show at the start of the book cover is the ANCRE French original. The cover of the book I have has the words: "A Lanvéoc Boat, Small boats of the 17th - 18th Centuries, Surviving from the Middle Ages" followed by the author's names.
    Thanks
    Tony
  4. I am sure that the more knowledgeable in the forum will have lots to say about this, but I thought I'd throw in Boudriot's instructions for the shrouds on the Jacinthe schooner of 1825. It does seem to say that all the shrouds were served as far as the catharpins. The measurements are in mm for the scale of the model at 1:48.
    "After fitting the softwood bolsters to the trestletrees the shrouds are got overhead in the following order for the foremast. The first eye has two short legs forming the fore winding-tackle pendants . The second has two legs , and forms the aftermost shrouds to port and tarboard. The third forms the remaining two shroud on the port
    ide. and the fourth the last two to starboard.
    In the case of the mainmast the order is as follows: first pair, pendants of the main winding-tackles; second pair, starboard hroud ; third pair, shrouds on the port side.
    The Ø of the deadeye is 270 (10") , Ø of the laniards 22. Winding tackle: fall Ø22 , blocks (upper blocks treble, lower blocks* double) 217 long (8"). The eyes of the shrouds and tackle-pendants are served with spun-yarn down as far as the catharpins. Ratlings Ø 8."
    Tony
  5. I bought a refurbished Proxxon MF70 from Axminster at a great price and used it with aProxxon x-y table I had bought for a Proxxon MB140 drill stand. Although people have said that the mill is inefficient at drilling, I have found it so good at drilling that I now use it exclusively for drilling as well as milling. It is just a little slower, but that doesn't bother me. It is very accurate with the correct adjustments. My tungsten carbide drill bits have never broken with it when I use it as a drill.
    I had to adjust the MB140 to mill accurately with a finer height adjustment (see here on MSW) but could only use it as a mill with great care, which led me to the MF70. It's a great tool, much loved by European and other ship modellers with wonderful results. It is also much modded to include CNC, change of motor etc. I won't go that far as it is entirely satisfactory for my use. In fact I am such a poor modeller compared to the masters who use it that I will never use it to its full capabilities. I will never blame my tools for shoddy workmanship!
    It is certainly much less costly than the bigger mills and has lasted me several years so far.
    Anyway, everyone has their own requirements and I just thought to slip in my experience. Enjoy and master whatever your choice!
    Tony
  6. I alo thoroughly recommend the Sherbourne. There are several detailed builds on this forum, going back to 2012, some of which go into the modifications that might be made based on the original National Maritime Museum. It was my first model and one which, after a lot of interactions with other members of the forum (especially @Gregor and @Stockholm tar), I made a lot of alterations and ended up making many of the parts for myself. After that I quickly went to building directly from plans - something which opened up a whole new area of satisfaction.
    This forum is a wonderful place to provide help every step of the way, and a great many modelers of cutters with detailed advice. Cutters are a very good introduction to form, function and rigging. Just ask whenever you are stuck.
    Tony
  7. @GregorThanks, Gregor. Yes indeed, that whole experience was very pleasurable and productive. I often think back to it. So I really look forward to your new build log.
    I also look forward to your rigging plans for the Topaze whenever you get to it. There are some problems with the rigging diagrams in Boudriot's book on the Jacinthe, notably the rigging of the gaff throat and peak halyards, so it will be nice to see what you make of them. I have just started the rigging for my own Jacinthe and have been working out my own solutions using Marquardt's book on Rigs and Rigging.
    Tony
  8. Thanks, @Kevin. All I get from the link is:
    Was habe ich da im Februar nur geschrieben: Knie als Rohlinge ausgesägt... Immerhin, sie sind angepasst und eingesetzt:
    IMG_0545.jpeg - Bild entfernt (keine Rechte)
    IMG_0543.jpeg - Bild entfernt (keine Rechte)
    IMG_0542.jpeg - Bild entfernt (keine Rechte)
    Und noch etwas Abendstimmung:
    IMG_0547.jpeg - Bild entfernt (keine Rechte)
    Bis bald,
    LG Gregor
    It may be that I have to join the forum, or something other that blocks the images for me in the UK.
    Tony
  9. That’s really excellent, George. Thanks very much for the diligent and accurate work! Very helpful indeed.
    I’m just getting my head round stropping the 2mm (1.8mm) blocks; the grooves are a bit shallow to prevent slipping but they are correct and consistent in size, and as it is quite possible to strop them I prefer them to my own rather rough attempts.
    All the same I appreciate and agree with the comments about being thoughtful concerning what is pleasing for each modeller. I’m not a fanatic about accuracy in size, but having consistency is pleasing.
    Tony
  10. Just to give measurements of the 2mm blocks, as near as I can with these fiddly things:
    Height - 1.83mm
    Width - 1.4mm
    Thick - 0.8mm
    Sheave holes - 0.4mm Ø
    If I take block height as 12 x rope diameter, this would be suitable for 1.83/12 = 0.153mm Ø rope, which would be the equivalent of 15.3mm Ø rope when at a scale of 1:100.
    Similarly, a rope size of 0.4mm Ø would need a block 4.8mm high.
    It would be interesting to know if others agree with these calculations, and, if they have the measurements of other blocks from Seahorse, to know what those are.
    Cheers
    Tony
