Posts posted by heksanol
Thanks Cathead!
Started working on the display base for the model. The hole in the big base is for air breathing. The small base will cover the hole, and be raised with wood strips. The big base will be raised with normal risers.
The base is going to be stained dark mahogany.
I have ordered router bits in order to put in the glass case that will cover the model.
Regards
- WackoWolf, Ryland Craze, Cathead and 2 others
- 5
Thanks Cathead.
Busy at the moment with the back stays, making all the components before starting the rigging.
Good job so far!
From the pictures the frames looks good to me. Your overthinking this too much - go for it!- Nirvana and Wschoenfeld
- 2
I started to add the shrouds. However, I first made some pins to have equil distance between the deadeyes.
One thing to take note off, is that they only supply you with enough rope to complete the shrouds, whereas most of the other components they supply quite enough extra in case you make a mistake,
Will try to complete the other shrouds this week.
- Robin Lous, GuntherMT, WackoWolf and 3 others
- 6
- Ryland Craze, Cathead, GuntherMT and 2 others
- 5
Greetings, another small update.
Finished painting the pins, decided to go for black colour scheme for aesthetic purposes.
Next up was to make the windlass and its handles. The handles is going to be pinned into the windlass. I made the square holes on the sides that can be seen, to give the illusion that the square ends of the handles can be used on these holes.
The picture of the handles doesn't show the tapering/transition of the handles that well, will post another one when they are stained.
I am still not sure if I will paint the windlass black, or maybe the handles black. Will see as I go along.
- Cathead, cristikc, Ryland Craze and 2 others
- 5
Looks very nice. I definitely like your choice of color scheme.
Thanks Cathead.
Going to work some more on it this week, really want to take some fotos in daylight conditions.
- GuntherMT, Ryland Craze, WackoWolf and 1 other
- 4
Update time!
Added the thwarts to the boat.
Next was to make the locker. The plans says the side boards are pre made, but they are way too short!
Therefore, I just made my own boards from the sheet. After the boards, I added the bolts for the locker.
The locker was painted black. To distinguish the locker hinges, I will ad some grey highlights later.
Finally, added the knees to the model. The front and thwart ones were painted black for contrast.
I will continue with the mast thwart this week.
Regards
- 4
Another day, a little bit done
Cut out a template for the rear and front boards and glued on the planks that I assembled before hand. I added a black line to one edge of the planks via a permanent ink marker to simulate caulking:
After the template dried I cut off the excess wood:
I tried a dry fit of the rear board and front board, but discovered that the scale of the diagrams to the actual model was off. Uh oh. Will have to modify the board to fit on my own.
So, after some modifying, got the boards to fit. Not the same as the plans, but still adequate.
Greetings
Had some time again to work on the model.
I finished with the rail, and made the middle joining piece.
I added the planks at the bottom, as well as staining the planks and the rail with oak colour. I am pleased with the colour results.
Finally, I added the lower rails, as well as staining them oak. Hopefully later I can take some pictures with sunlight.
Greetings.
Had some time to make some progress.
Painted the rest of the hull in white, as well as fit the stern post:
I applied a coat of gloss varnish for protection while working further on the ship. Will make it matt again later.
I started with the cap rail:
After some sanding down:
I am still going to fine tune the cap rail, as well as add the joining piece.
The cap rail am going to stain with an "oak" colour.
Until next time!
- GuntherMT, CaptainSteve, WackoWolf and 2 others
- 5
Thanks for the comments!
I maid a stain mixture for the inside of the longboat to get a more darker appearance.
I felt like some painting, and started painting the model. Finished with the black rim, will try to get some white acrylic paint for the bottom.
I like how the black paint came out. Might not be clear from the pictures, but the wood texture still comes out, depending on the angle and light conditions.
- Cathead, NJQUACK, Ryland Craze and 2 others
- 5
Some updates, I'm just about ready to begin the rigging, and I'm so happy to do so. First up was the bowsprit. I shaped the dowel and varnished with Tung oil. Then began seizing the two blocks that go on it. I found a YouTube video that showed me exactly how to do that, with original credit going to Bender
Could you please link the youtube video?
I am busy with the San Fransisco's "younger cousin", San Juan.
Thanks
- Cathead, WackoWolf, CaptainSteve and 3 others
- 6
San Juan Spanish Galleon by Gif_Hasie - FINISHED - Artesania Latina
Haven't update in quite a while, but here goes.
Finished with the three masts, so it is ready for rigging.
Already finished the spar for the back mast.
Also finished the bowsprit and added it to the hull with other decoration - will post some photos later.
Busy preparing the other masts.
