Everything posted by Baker
Thanks for the comments and pressing the like button. Started building the pavilion (hopefully the right name) This is bigger than the original. And some windows have already been used elsewhere. So a new batch of windows is being made. The first ones in wood were disappointing. So they are now made in polystyrene. Pre-painted windows and wood. Assembled. And provided with a roof. I have also started applying the decoration. Not exactly as described but in line with the painting. Not all ladies fit perfectly in the new arrangement in the place where they will end up. To attach them more firmly, one lady needed a copper pin through her belly (ouch...) I have also started on a base plate. Afzelia wood, left over A few pieces of brass from a curtain holder. And 4 pieces of plastic (origin, forgotten...)
- 85 replies
- Corel
- Große Jacht
San Martin by MikkiC - Dusek - 1:72
Baker replied to MikkiC's topic in - Kit build logs for subjects built from 1501 - 1750
Correct As far as I know. These standards serve as a reinforcement of the hull. Especially also on rear and fore castles if you do them flush with the wales (in pieces) then they have no strength anymore, and consequently little use. And, very nice work. -
Nice models And
- 85 replies
- Corel
- Große Jacht
New member - modified La Grenouille from MOC YOUR BRICKs - LEGO
Baker replied to Friedie's topic in New member Introductions
Grooves have been milled into the winch, which provided more grip on the winch Reconstruction of a new scratch build winch with "new" supports from "leftovers" construction of the handle which can block the winch Winch ready, chimney in progress And some further detail
- 85 replies
- Corel
- Große Jacht
The general rule for metal is 5000 divided by the diameter of the drill in mm. Source: Mechanics lesson in the 2nd year of technical education... (in 1978) 😉 Wood may have a higher speed, but the 5000 rule is also quite ok in this case. Nostalgia
- 64 replies
I have also experienced this. Drilling by hand sometimes gives problems and small drill bits break more easily. I am really happy with the purchase of a Proxxon machine and the flexible drill head.
- 64 replies
A very nice paint job 👍 -
Dream of building full size to reality of building models
Baker replied to J Snyder's topic in New member Introductions
Started painting The red paint first got some gray drybrushing. Then the decoration around the cannon opening was painted yellow with a gold drybrushing on top. The parts of planking that are not white, black, or otherwise colored. Are provided with some "wooden" treenails (toothpicks) The wails of "bolts" (head pins) And the plank between the wails of "nails" (fishing wire) I also started painting on the decoration, the PE parts that were included with the kit for this were a to be painted.... Base color red, decoration yellow, and over the whole a drybrushing with gold color, I really can't do better. Also started on the winch Kit parts improved part
- 85 replies
- Corel
- Große Jacht
I also started a yacht. As a side project. It seems that the Dutch yachts have a different hull shape than this one (and mine). Correct? Or imagination 🤔. And you build faster than me 😉
- 77 replies
- Royal Yacht
- card
- 70 replies
- Scheldt River
- Dredger
