Everything posted by RGL
Now, asaw a 1/00 model of this class of ship and the mysterious blobs spread around the deck are skylights, which are, of course available in incredibly complex and tiny PE, so it's far tidier to place the grilles and hatch covers on 3x2mm strip. I need to have all these features sorted before I lay the 1mm brass bracing stips. All the kit supplied hatches, vents and equipment will be replaced with PE either from the Flyhawk set or other bits and resin pieces.
Because I need a solid 12 hour stint to paint then use the weathering products, and paying the mortgage precludes that at the moment it's back to piecework. The linoleum decks are meant to be a flat brown, so with some preshading and highlights where the brass strips are required, i e done that but, they still need a coat of flat varnish
Seriously there was crap all through the airbrush, but I've got some of the flow improver, don't have this problem with any other brand
The black red added, note to self, I will never use Vajello in my airbrush again, completely gunked up. Matt varnish next.
They're water based, so you can safely airbrush them
- 151 replies
- duke of york
- tamiya
Pre shading V1. My plan is to do up the lower hull firs, using a black red between the ribs at the bow and amidships then overspray a Matt varnish, then paint it over those sections with the chipping and wearing products, then paint it properly like I did on my Yamato, then run away in sections to reveal the damaged sections. Hope it works! The decks will will have the brown Lino sections that will be modulated before the brass bracing is added. Looks a mess now now but hopefully there is method to my madness.
You'd probably find anything from Ebay coming from China won't matter as they generally don't care about rules.
- 151 replies
- duke of york
- tamiya
Your email spoilt for choice in your part of the world, SE Asia seems to produce a lot of the aftermarket tho and shipping is quick here.
- 151 replies
- duke of york
- tamiya
Testing out some new stuff on an old hull, chipping and wearing. I'm thinking if I can do a decent sets of ribs on the hull in black and dark rust, a coat of varnish then some of these fluids, I can beat the hull up pretty well. I just have to figure if i complete the hull painting completely then wear it back. This is is a bit severe but I like the effect I also want to try and add barnacles over the top. Let's see.
Maybe you could follow me after wood and go to plastic Dave? the rigging work is so much easier
Prop shafts done and the final coat of primer. I cut off the plastic shafts and replaced them with brass rod. The sea sea steps were filed off and replaced, I've always tried to use North Star steps and it's just hard work to trim and place them, but the idea came to me to use railings from PE, bent over my metal ruler which are easier to handle and look better. Now I actually have some panel lines to work with preshading etc will be a lot more 3D than making it up. Before i I get there tho I have to practice some new weathering techniques on a spare hull.
If you zoom in on the second photo, you can see strange rectangular panels on the hull, which have been suggested as strengthening strikes but I'm not convinced. There are also what appear to be longitudinal scuppers beneath them and little bulbous scuppers just above the waterline. I used offcut PE for the 'strokes' as it is easier to work with and very thin, evergreen strips for scupper pipes and half sanded vents in resin for the waterline scuppers. There is is another layer of primer to go yet before pre shading so it won't be so stark. The hull panel lines were easily cut into the multiple layers of primer. The hull ladder rungs to go.
After much masking and multiple coats of rattle can primer, I have replicated the hull plates, which I'm actually quite happy with. They are about .1mm higher than each other which should be correct for scale. Most kits have scribed or raised seams which is just not accurate. Now I can scribe the individual plates and add the scuppers and the mysterious bits on the side of the hull before another overall coat of primer. With pre shading to delineate them all I'm hoping it will come up ok in the end before it gets messed up with heavy weathering.
There are three gun mounts for the high altitude AA guns, the forward mount is the trickiest as the PE is out by about .5mm. The rear mounts are fairly simple and get sandbags. Did they have them? Who knows, I reckon they'd have wanted as much protection as they could by 1945.
Whilst awaiting the next layer of primer on the hull to finish, I think this is the radio room and the 60cm spotlight on top with sisal protection
This piece is now pretty much complete, having added the sisal ropes. There are a heap of ammo boxes to go on top with the guns which will hide the gaps.
I have started the primer coats on the hull, I'll try and use masking tape to delineate between the hull armour, so there will be multiple coats. In in the interim I have started up the PE deck assemblies. This Flyhawk set is very nice, but a bit of work to do yet to fill gaps and smother with sisal splinter shields. This is a central ventilation room which will seat 2 triple type 96 25mm AA guns (same pain as the Yamato to build).
That's a nice piece of work, I know your pain!
- 151 replies
- duke of york
- tamiya
Pretty much destroyed most of the detail popeye, slowly removing and sanding everything back, a couple of indentations to fill where the pumps and cable reels are supposed to go as they are utterly inaccurate. The rear deck area; I replaced the doors (hatches), added proper cable reels, and some support gussets. The Flyhawk set adds an extension to the top deck to make it like the kit is supposed to be. I won't glue this down yet as I will have to paint it beforehand. I picked up some rattle can primers yesterday so I can start building up the hull plates, once I can do that up I can add the multitude of side panels that are displayed on the box art and original photo (if anyone knows what they are I'd love to know, open and zoom in on the b/w photo), plus a LOT of scuppers at the waterline.
It's good to see a few other plastic modellers here now! Moving on, I have finally stripped the decks, the top deck comes in three sections which will have substantial gaps between them which will need a fair bit of work. The quad torpedo launchers are supposed to be put in beforehand but it will make painting a continuous deck problematic so I cut the bottom off the so they can be slid in later as the interior will not be visible. I have also also added the ringols to the portholes and added the manual aiming Port (right hand side near the large opening), which is visible on the photo and in other references for the IJN but not made up in the kit. My quandry now is, do I add the deck? The hull is going to need plating added and numerous other details and the deck will be linoleum (brownish), requiring a lot of masking to separate the two colours.
