Everything posted by RGL
Fore topmast stays. I've used the Clasic Models violin blocks. I cheated somewhat doing the mice by using a parrel bead served over to make the smaller bulge required. I really had to guess the belaying point as I can't find reference to one anywhere.
- 319 replies
Pat, I did the crows feet as the very last part of the lower mast assembly after stepping to keep the tension on them correct off the stays and to save snagging them on everything whilst doing the final rigging. I had to keep dry fitting the top masts to ensue alignment was correct.
- 319 replies
As the other Endeavour club members are getting on with it, i thought that i'd try and keep trundling on with the Topmasts. The backstays now completed, just on to the stays and their mice next. I'd just like to say I'm crap at photography of small stuff - but at least it hides the fluffy lines. iPhones are not the best if cameras but very easy.
- 319 replies
Looks good. I ordered my lantern from Chuck last week as well. I used rataan for my hoops.
Breast backstays. The backstay needs to be separated at the mast, thus the little jig so it allows me to ensure the blocks are even on each side, and allows them to be served on. Tye tackle next, then backstays and stays.
- 319 replies
Topmast ratlines and futtock staves and catharpins.It's getting to the really fiddly stage up high. I'm terrified I'm going to break something. I've done the ratlines (which will thankfully be the second last lot until the Topgallants) and the futtock staves and 15mm catharpins. It looks clumsy (it is) but I have to use a beige line then stain it as i just can't see the bloody lines to control it otherwise. the stave itself is just plastic rod which as you can see runs long for ease of control. There was some torsion from the fall of the stays which was corrected by the catharpins and will be lost when the Topgallant shrouds are attached. It will look very busy. This is a very painful process and I am looking forward to adding the breast backstay, Topsail yard tye tackle and backstays. I forgot to ask, does anyone else use toenail clippers as flush cutters for their rigging lines? works better than any other took I have found.
- 319 replies
Everything conflicts with the Endeavour! Mine looks nothing like the AL kit. I think I've replaced or scratch built everything apart from the wood on the deck (which I now regret I did'nt replace) and the bulkheads. As long as you are happy, we will be!
Yep, it all makes too much sense really. Imagine climbing ratlines at an angle? You'd just slip off!
- 319 replies
Question for Endeavour builders. The rat lines on the Mussen mast. As it runs at a different angle to the main and fore mast, do the topsail rat lines still run parallel to the deck? It makes sense that they do but the AOTS makes them look as if they don't. It's only a few degrees but it can't be right.
- 319 replies
Topmasts continued with shrouds attached. I never realized how much detail goes into them. I have yet to add ratlines, a daunting prospect again after going to a wedding last night so the couch is easier.
- 319 replies
Slowly fitting the topmasts. I just have to glue in the mast tops and align it properly before setting it for good. I had to include the tackle first as the shrouds will run over the top of them so they fall in a single line thus it has to be spliced. The double blocks are Chucks from Syren, drilled out a bit and filed along the sheeve lines to give a little more definition. shrouds next, then numerous backstays, then stays over the top, Then I'll have to worm the jeers up between them so they hang under it all.
- 319 replies
The fiddle block attached to the lower mast tops. These violin blocks are just beautiful, stropped and served with some 0.25mm black thread. I have to do the liners next. I originally had the kit supplied kit violin blocks which I filed down and opened them up to insert sheaves, but just cannot compete or could not reproduce these. Next: It took me two days of studying the AOTS to figure out how to figure out the order and method of the next lot of shrouds and backstays. I've finally got my head around it but it's going to be a major exercise in rigging far more challenging than the shrouds on the lower masts. I spent two days with my little model shipways ropewalk making up the shroud lines in the correct thickness.
- 319 replies
HMB Endeavour by mikec - Eaglemoss
RGL replied to mikec's topic in - Kit build logs for subjects built from 1751 - 1800
Nice pumps, I scratch built mine as well but I'm discovering that the handles grab onto every bit of rigging line now I'm up to it! -
The first one is a violin block which is a lift for the main yard not two blocks joined, the second is the sheeve which is used with a tackle to pull the upper mast up into position and then a fid (a small wooden chock) is placed through a hole in the bottom of the upper mast which sits across the cross trees to hold it in place and the tackle is removed.
I thought I had just about completed the lower masts. I completed the Futtock Shrouds and hooks with ratlines, made up my Euphroes and crows feet using some 2mm blocks, (the crowsfeet will need some wax as they're fuzzy0. I discovered that i forgot a Mizzen Stay which is painful as it will be fiddly serving it. After I fix this, what do you normally do next? Which mast in what order?
- 319 replies
