Everything posted by RGL
From memory mine were 4mm wide, I'd dry fit the entire length but I drew on the frames in pencil FO I knew how to put the 6 butt shift. That way the tree nails line up correctly. It also resulted in not using stealers at the stern or the bow
- 319 replies
- 319 replies
As such, each lower mast has it's own tackle block set up, with the rings already placed on the channel years ago. You really do have to plan ahead. The Fore tackle was obviously used to fish out the end of the anchors to get them out of the sea. I shall endeavour to replicate this when i do the anchors.
- 319 replies
I've finally shipped the fish hook tackle. I did a bit of research on this (I think to meet Marquardt's rigging plan) and found the two following diagrams.
- 319 replies
I've kept this pillar off the ship to date as it would only get in the road. The bow swivel cannons were a slightly modified version of a Caldercraft cannon copied off the AOTS.
- 319 replies
Or; as an alternative, there is one plank called thick stuff just above the Wales, and you can do three anchor stock below. I still regret not doing that one plank.
Jason, sorry to stick my nose into Rowland's log, I'm also doing the AL Endeavour. I'd strongly recommend you swap out all the planking wood supplied. The decking planks are very waxy and break very easily. The lighter but thicker ones are for the first layer, with the darker thin ones for the second layer. Greg.
Thanks gents, things will slow down now, I want to get the mast tackles done next, and time to bite the bullet and make up some blocks with metal hooks. Then the fish hook davits (which are constructed but unshipped) to run off the foremast tackle, then the 4 anchors, the stunsail booms, do up chucks lantern, then wrap it all in glad wrap and start on the yards. So, same time next year then....
- 319 replies
OK, pointy end of the ship done finally. I've pretty much replicated the AOTS for all the stays and running rigging.
- 319 replies
I really have no idea why they are set up that way but I don't think if worry about it too much, it won't get in road of any of the other rigging at all.
- 319 replies
Oh yes, 5-0 and Thankyou skull. I'll take some more photos if you wish with a ruler for dimensions if you wish, I imagine the angles will vary with each kit. I'll finished the rigging on the boom which I'll attach tomorrow.
- 319 replies
The bowspit cap was cut from an off-cut of walnut that sits just outside the bees (about 2mm) - see photo. It sits at 90 degrees to the waterline but the angle at the top and bottom and the two holes run parallel to the angle of the bowspit. Done with a simple lead pencil and a sanding block to get the dimensions and angles correct. I drilled 2 holes and widened them, the lower one square and the upper one round at the angle of the bowspit. I then cut a small groove for the flagstaff and used a microfile to widen it to fit to seat 1/2 the circumference of the flagstaff. You then need 6 rings for blocks and rigging.
- 319 replies
Ok, the whole mast tapers for the cheeks, with the green bit being full circumference. I did it on the lathe. I filed the sides above the green for the cheeks so they are fairly flush. The woulding was filed into the cheeks and used ratan for the hoops. The metal bands were just cut to appear as if they go under.
The "leather" liner is copper tape painter brown and the netting is commercial from Cornwall. I was going to try and hand sew it but it would have looked like crap at this scale. I did about 3 versions to get it right whilst I was watching the 5th test.
- 319 replies
