Posts posted by Tim Curtis
- JesseLee, cog and Steve 12345
- 3
Have been slowly plodding along on my Scottish Maid.
Here are a few things that have happened.
Firstly, here is my first attempt at a Cranse Iron, which I will use on the lower yard on the foremast. I don't know how to solder, so it is made with a few strips of brass, some brass wire and a brass pin and a bit of CA. The armof the iron rotates but not quite as much as it should!
- JesseLee, Steve 12345, knightyo and 1 other
- 4
I have adjusted the stern of the model. The kit and plans show simple square frames, which I have adjusted to something more authentic. Photos explain. I made an error in splaying them to follow the curvature of the stern, which is a shame. Will know for next time. This is a simple upgrade made using wood from the kit.
- JesseLee, hexnut, Pierretessier and 1 other
- 4
Have made a bit of progress on the standing rigging. Shrouds for foremast are in place.
Also forestays, served and spliced in order to loop around foremast trees.
Finally created the guys for the bowsprit. This was tricky. First had to create a collar with eyelets either side. Collar also needed the deadeye for the bobstay to be attached to it.
Then made the the bowsprit guys themselves, which are then lashed to the collar. Both collar and guys have eyelets and thimbles. First go at this, but managed to get the hang of making little thimbles, by pushing a dremel head into some small sections of silver coated brass beads (from a bead store). This gives them a bit of shape. Then created a false splice around them. Finally make the little lashing and there we go.
Its 2am, and I have a busy day with kids tomorrow. My wife is going to kill me... Bed time. Happy new year!
To date I have been painting hooks and eyes with oil based paint pens. However...it just scrapes off so easily. So resigned my self to purchasing proper brass blackener. Will be slower, but a much better result I hope.
Merci Jean Pierre. Could you explain what you mean a bit more? Also whats a #2 pencil? Is that a thickness or lead hardness? Tim
Thanks for the encouragement. I am currently trying to work out how to sort out my blocks. Have worked hard at stropping and am beginning to be satisfied after about 10 attempts. Also I am dropping a bit of brass into the loop or eye of the strop which is super fiddly with a 4mm block but does work, and gives authentic feel. See detail below.
- kier, Steve 12345, Pierretessier and 1 other
- 4
- Steve 12345, hexnut, JesseLee and 1 other
- 4
- Steve 12345, JesseLee, hof00 and 4 others
- 7
- hof00, Ryland Craze, Cabbie and 5 others
- 8
So here are a few pictures of where I am up to. Taken in very bad light....
As you can see, I am going with an unhistorical colour scheme, but I like it.
I am pleased with the patina on the copper plates...used drybrush.
I would welcome historical info about how to rig it more accurately than the AL instructions. I am using Petersson's book on Rigging Fore and Aft Period craft, but this uses an 1815 ship the Experiment as it's example. I am assuming the Maid would have used quite different rigging. Any ideas?
This is my second ever build so I am a learner. I am busy working hard and have three kids so build progress will also be slow. I chose the Maid because it seemed like a pretty simple cheap kit to cut my teeth on. I am going with a slightly unhistorical colour scheme, inspired by Clayton Osterling's Experiment
(See here: http://www.shipmodel.com/models/experiment-full-hull-nav).
I would welcome feedback, encouragement and advice. Thanks!
But despite being new to this, I am totally hooked.
- Ryland Craze, 0311, Cabbie and 3 others
- 6
Scottish Maid by Tim Curtis - FINISHED - Artesania Latina - Scale 1:50
Posted · Edited by Tim Curtis
Finally I have bought a little lifeboat kit online (don't worry - its not from one of the banned manufacturers - I checked) and I am in the midst of putting it together. Its probably a couple of decades too old in it's design. But I found it hard to find a good quality little kit of the right size. This was as close as I could find. About $18 AUD. I like it. Not finished yet, but making progress. Its about 80mm long, so the planking is quite tricky.
I have been using the steamer on my coffee machine and a bit of CA (no pins) and a few miniature clothes pegs to bend the planks - and it seems to go pretty well.
