Hubac's Historian
Everything posted by Hubac's Historian
  1. Shipwrights couldn’t make a better job of it, full-size!
  2. I wasn’t expecting to be in the city shop, these few days, but whenever the opportunity arises - I like to do whatever tedious pattern work that needs to get done. Access to a band saw, disc and spindle sanders, simplifies the making of the series of bulkheads that will form the counter/false balcony. Yesterday, in the shop, I made the first bulkhead that would ultimately serve as the pattern for the others. First, though, it had to be proof-tested on the model to ensure that it mirrored the already established camber and round-up. I used my quarter gallery drawing as the basis for my bulkhead profile. What I discovered, though, was that there are two important notches or step-backs that needed to be cut into the bulkhead; my pattern was based on the exterior, or extreme outline, but I needed to make an allowance for the thickness of the planking. My first bulkhead did not, initially have a notch along the bottom. Using a batten I found that it exaggerated the camber - which would then mess up the whole run of windows I just drew so carefully. And then, after I cut back the vertical portion that supports the windows, as well as trimming back the counter profile, everything lined up properly, as it should. Here is today’s workload: cut out my bulkheads, and cut out the basis for what will be a stacked moulding for the transom wale. The transom wale seems to be a hair on the heavy side, but I can fine-tune that, once I can offer it up to the model. Also, now that I have a useable pattern, I could better see how the counter ornaments were going to resolve themselves. It was really handy to have the bandsaw to waste out the middle (the head and crown) of my spare counter ornament. Now, certainly, there is too much space between the head and the acanthus scrolls. What I will do is a bit of visual trickery; I’m going to let the base of the scrolls into the last of the upper transom planking, so that it glues to the transverse bulkhead beneath. The front edge of the acanthus base will also be let into and come out flush with the facia plank (not yet installed) that covers the edge of the transverse bulkhead. Doing all of this will cut that gap in half. A little gap is okay for me. This letting into the planking is technically wrong, but if it all works out as well as I can see it in my imagination, then the wrongness won’t interfere with the perception of its rightness. As with a number of other aspects of this build - perception of reality is more important than strict reality of construction. You have to fudge things a little to make them work.
  3. I’ve been going back and forth over whether to modify the appearance of my rudder opening. When I framed the stern, I wasn’t thinking about the reality of how the stern post would end just above the framing of the ports, so that the tiller could pass over it, and into the hull. I was primarily concerned with strength and tying my transverse round-up bulkheads into the sternpost. It certainly isn’t worth the extra effort, to me, to cut down the stern post, so that I can model the entry of the tiller into the hull. While I agree with Marc and Dan about what the opening probably should look like, at least there is some scholarly thought to support what I chose to represent, at this later time in 1689. Here is what Lemineur shows for the entry of the St. Philippe’s (1693) rudder head and tiller: As I say, I will take this learning experience into the next model. Here is my finished lower window drawing: I think it is definitely an improvement over the Heller layout: The drawing of the thing is usually harder than the making of the thing. I’m finishing up with the last of the gun carriages. Following that, I’ll make up the transom wale and my motto banner. Then, I’ll get busy making this window tier.
  4. Hello, Marc! Thank you for the kind words. I am without doubt that you are correct in this detail. I keep a large cache of Berain drawings on my Pinterest page and they all show the rectangular opening, as do these very fine Puget drawings. Besides these drawings, though, I had no written reference to their shape, and so I ultimately modeled them after what I saw on Olivier Gatine’s model of La Belle, as well as Tusset’s model of the St. Philippe. In all likelihood, I will probably not feel sufficiently motivated to change this on this model. I will definitely, however, incorporate this into my conjectural model of SR, 1670. That is, by the way, the best and most clear reproduction I have seen of this port-quarter portrait of Le Dauphin Royal. Thank you for that! I’ll be adding it to my image files. There is a question I’d like to pose to you, Marc. As I am now figuring out my plan of attack for the stern lights, and the construction of the quarter galleries, I am wondering whether all of the lights in the quarter galleries, at this later time in the 17th C, would have been false lights, with lone exception, perhaps, being the Admiral’s quarters on the quarter deck level? If that is so, I would back-paint my false lights in a stylized way to represent glass.
  5. I hope that everyone enjoyed their Thanksgiving. We certainly did. My transom planking continues, and at this point, I am planking across the opening for the rudder head. Before completing the last few strakes, leading into the stern counter, I wanted to pause and see whether I could modify one of the kit’s stock ornaments, in an attempt to present a more faithful representation of Berain’s stern. What I am focused on, here, is the pendant ornament that drops from the lower false gallery and conceals the rudder head. For all practical purposes, I suppose that this ornament’s intended purpose was to limit the intake of water, through the rudder head opening, in a following sea. I’m not sure whether that is the truth, but it’s a theory, anyway. What is interesting about Berain’s drawing is the way in which the Palladian shell backdrop recesses, up into the lower false balcony. The stock Heller ornament is intended to mount beneath a walkable lower stern balcony, as seen here, on Tanneron’s model. Heller reproduces this detail quite faithfully. It’s nicely done, and would be difficult to carve from scratch, in a way that suits my purposes. I do have two of these ornaments, though. By separating the Louis head and its shell backdrop from the acanthus leaf cheeks, I should be able to set the head so that the counter planking of the false stern balcony abuts it, flush all around. I would then remove the head and shell from my spare ornament and mount the acanthus cheeks just behind the head, once I’ve completed the counter planking up behind the head. This is a difficult thing to describe, but hopefully the following few pics will make it clearer where I’m headed with this. The head isn’t glued in, just yet. I’m not sure whether the new angle that I’ve filed into the back of this piece, accurately follows the run of the counter planking. That will become clearer when I make the bulkheads. This new angle that I’ve ground into the back will tip the shell background and Louis’s cherubic face up into the visible portion of the counter. I’m still not entirely sure this will work, but it’s worth the experiment. This is where the stern window drawing is at. It was a lot of re-drawing to get these cartouche ornaments equally scaled, but overall I like the size and shape of the windows. No matter what, they are an improvement over the stock kit windows. As ever, thank you all for your interest, your likes and your comments.
  6. As always - great work Frank, and Happy Thanksgiving to all. I think that loading cannon balls from the front may be the key; there would be no need for haul-out tackles in that scenario. One would only need the haul-in tackles after firing. As I know really nothing about these Galley ships, I wonder whether they are equipped with a hatchway on this short beakhead deck, through which cannon balls and cartridges might be passed.
  7. Yes, I agree that that is an interesting problem. Presumably, the name would be in white, but there are a lot of relatively fine white lines in the frieze. I think the finer the lettering, the better, but I suppose it would really depend upon where the individual letters fall in the frieze. Also, maybe a light but complementary yellow ocher would give enough contrast without overpowering the frieze. I guess it comes down to something you have touched upon in this log; is it better to be wholly accurate, including every detail, or to leave some detail out, in the interest of cleaner aesthetics? That’s a tough one!
  8. On a separate note - I recently asked another noteworthy modeler on this site about the historic precedent for false windows in the quarter galleries, themselves. His particular specialty was also the 18th Century, and so, he wasn’t so sure about that tendency for the 17th century. I am wondering whether you have some insight into how far back the practice of faking quarter gallery windows goes.
  9. Hi Chuck - this is all fascinating to me. Your quarter gallery tutorial could not come at a better time! The frieze is really interesting. I’m assuming that it’s printed through some process or other. What I wonder at is that - even with laser-cut parts and a very incisive group build-log, which accounts very nicely for variable results - there are going to be variable results. So, I wonder at how one maps out something with a specific artistic framing - like a frieze - so that it can accommodate a multiplicity of outcomes. All I can say is - this is incredible! I’m not asking you to tell me your secrets, but I just wonder at the engineering of the thing. The results are superb!
  10. You’re as nimble on the computer as any GEN-Zer I’ve ever seen. That is dynomite, Dan, and pretty perfectly illustrates the way that I look at these images. Also of note is the fact that both of these stern and quarter drawings are labeled, above, in the same style - as is the bow drawing (admittedly sans forecastle). This does not explicitly, in and of itself, make them all a matched set, but it would seem to indicate that the images were catalogued at the same time, and therefore contemporaneous with each other. As ever, thank you!
  11. Yes, Dan, going by the shadows, that is also a strong argument for the middle balcony. I’m inclined to follow the wrapping open walk structure, with a shallow ornamental amortisement above, that is often in evidence for ships of this later Second Marine, though. The trouble is that Berain shows the figures of Autumn and Winter at the ship’s sides and just before the quarter galleries. Now, when you consider both the black and white quarter drawing, as well as the color quarter portrait by Vary, this figure of Winter is clearly supporting the middle balcony. At the very least, then (if you accept the premise, as I do, that these stern and quarter drawings belong together), the middle balcony extends at least to the ship’s sides. Perhaps the middle balcony ends at the ship sides and does not wrap to the quarters. The reason that I do not think this is so, however, is that the archway upon which the side figures of Africa and the Americas sit, is shown as an open archway, as opposed to a glazed opening. I believe that this open archway is a pass-through for the open walk to the quarters. Essentially, this is what Lemineur depicts with his model of the St. Pilippe. Also of interest on the St. Philippe, there is no upper balcony, but merely the ornamental fretwork of a balcony rail. So, that further lends credence to the idea of a vestigial Juliette balcony on the upper level, if at all. All that being said, these are just a few of the ambiguities that make modeling this ship so difficult.
  12. Wow, Dan - that really makes a difference. You know, I’m still on the fence as to whether I should represent the top stern balcony (quarter deck level) as a small “Juliette” balcony, spanning the center two windows, or a wider balcony that spans all six windows and ends at the ship sides. Both this drawing and the original strongly suggest that the Juliette balcony is the way to go. Tanneron did not believe so, though. As I’ve stated before, though, my personal belief is that Tanneron pulled from a variety of mid-17th century and late 17th century sources to create a composite of what SR may have looked like at the time of her launching in 1670. That would explain the open quarters, the open lower stern balcony and the very tall stern. It might also explain the presence of the sort of heraldic ornaments, in the quarter gallery openings, that we see between the middle deck guns in early portraits of the Monarque and the Dauphin Royal. As so much of Tanneron’s model is missing, or incomplete though, it is hard to know why he did not continue with the ornamental program of the ship sides, and why he did not complete the structure and ornamentation of the head. Although only a glimpse of them is visible behind the feature model (Frolich’s Ambiteaux), the bow structure of Tanneron’s L’Agreable and Brillant can be seen (not really, actually - sorry) Clearly, he knew that the head rails had to be supported from underneath. Although, the head rails you are seeing are actually of Capricieux, I know that the head structure of Le Brillant and L’Agreable is complete. (photos, courtesy of Marc Yeu, aka Neko). Anyway, I’m leaning towards the Juliette balcony both because there is a plausible argument to be made for it, and also because it would be a representational choice that has not been put out there yet. Maybe doing so will spur debate. Ultimately, I keep returning to the Monarque, where I believe the Juliette balcony is what is being depicted. It makes sense to me that this relationship between the middle and upper balconies may have carried over into the near Second Marine reconstruction of SR. Berain’s drawing is, after all, “l’Apres Puget,” or in the manner and style of Puget.
  13. The tops look fabulous, EJ. They convey the sense of scale that I’m after, myself.
  14. So, this is a work in process, and probably the most challenging reconciliation between Berain’s intent and the pre-established Heller kit architecture. I’m using a black and white reproduction of the original drawing as my guide because the detail reads more clearly; it somehow seems easier to gauge the relative proportions of elements and their true line. As I expected, my lower gallery windows are taller appearing, but the frames and openings more closely match the original drawing: I will continue onto the starboard side and fill in the ornamental cartouche that is placed at the top center of each frame. I just wanted to get a sense for the impression of the thing before I continued drawing. Along those lines, I realized it would also be a good idea to begin sussing out what the aft profile of the quarter galleries will be. What I have arrived at, so far, comes pretty close to Berain, but the less sloped tumblehome of the Heller kit makes it impossible to get much closer than this. Bear in mind that none of the projecting mouldings of the railings are drawn in, so that makes the following comparison a little difficult to imagine: What all of this does allow for is enough depth, outboard from the hull, to taper down the QG lower finishing. I will also have a reasonable perch for the figure of The Americas to sit upon. Of course, everything above the middle balcony rail (the small Xs) remains conjectural until after I have attached the upper bulwarks and can take exact measurements. One contemporary drawing that will be useful for gauging overall perspective is this unknown portrait of a three-decker at Rochefort: Some of the most useful information about the aft edge of the lower finishing, is completely obscured, but the sense of slope and projection from the hull are useful guides, as the structure of what I am trying to replicate is so very close to this design. To be continued...
  15. Well, whatever happens - I am looking forward to it. Bon travaille, mon ami!
  16. I agree - his speed is astonishing, but then he works full-time as a professional. That being said, I put anywhere from 2-4 hours a day, most days, and I am very sloooow! That Rex can work so quickly and to such a high standard is truly impressive. I will also be attempting paper sails from ModelSpan tissue. I am keenly awaiting Johnathan11’s efforts on his Alabama build to see how readily he adopts a particular method - which seemed relatively straight-forward, but I’m sure is not so easy. I really liked your silk sails on the bomb-ketch. They had a very natural appearance in such a small scale.
  17. The Heller Royal Louis is a terrific model, and much can be done to add missing detail. Will you be starting a build log for her? I’m gonna PM you on a separate matter.
  18. Ah, okay George! It has been a while, and so I forgot that I had subscribed to this thread, as well. So, now it seems, you will be resuming work on this fabulous build? Are you familiar with another pro modeler named Rex Stewart? He does small-scale scratch work, often in the mould of Donald McNary, but also very good and detailed dioramas. He has a Flikr page with some of his work. More recently, he finished an amazing Airfix Sovereign - I mean truly incredible - so that he could learn the nuances of that type of rigging before attempting a larger model from scratch. He’s a real talent, in his own right. Check it out:
  19. Happy Friday, MSW! Over this past weekend, I was browsing through builds I hadn’t seen before, when I found this: The log is brief and the model is complete, so it is not likely to receive much future traffic. It is so outstanding, though, that I figured fans of kit-bashing would really enjoy seeing this, if they haven’t already found it on their own. This guy George Kapas is a true pro!
  20. Hi Dan! Thank you for the kind words. This is another interesting approach. For stand-alone windows, I think this would work really well. In my opinion, part of what makes the Berain stern drawing so successful is that there is hardly a line out of place - even with respect to the mullions. Horizontally, they follow the camber, while running a consistent line from one pane to the next. Vertically, they run a widening taper that follows the tumblehome, and increasing width of the panes, from centerline to outboard. The beauty of the scribing approach is that I have already made a camber pattern that I can use to scribe horizontally, across the window panes. Last night, I revisited my original drawing, in order to map out the available space for the window layout. This was an interesting exercise, considering my initial approach to laying down the first drawing. I gained some useful insight into what I supposed the profile of the stern would be, as opposed to the reality of what I am building. What’s good is that my windows do increase slightly, in width, as the transom becomes wider. Mostly, I anticipated the correct height of the stern balconies, beneath each tier of windows. I did realize, though, after examining my QG cutout, against the hull, that I will need to increase the height of my QG windows at the lowest, middle deck level, by 1/16”, in order that my main deck QG rail will rise to the top of the upper main wale, where the amortisement begins. Doing so, will provide the dimensional consistency, in window height, that is crucial on this level because the windows wrap from stern to quarter. My other main observation, though, was that the space available between the plank ends of the ship sides tapers to an 1/8” less, at this middle balcony (main deck) rail, than I had originally accounted for in my drawing. This actually has a negligible affect on the space available for my window layout, but I do have to make some slight adjustments at this lower level. Anyway, I’ll draw a layout for the lowest tier of windows, for now, because I know exactly what the available space is there. Eventually, when I attach the upper bulwarks, I will draw layouts for the middle and upper gallery windows. No matter what, I will end up with a closer approximation of Berain’s intent than what the Heller kit provides for. My lower tier will appear taller than Berain’s, though, and that is simply one of the constraints of the kit architecture that I can not avoid. I’m still detailing the quarter and poop deck gun carriages. Once those are complete, I will focus on this lower tier window layout.
  21. Backer - thank you for the compliment and for the link to your fine build. You really achieved excellent and highly realistic results with your approach. Considering the sheer number of windows that I have to make, though, I am inclined to try the less labor-intensive approach first. Both methods require scribing the pattern, but wiping away excess acrylic should be fairly easy and provide just as good a result. Sometimes, as I did last night while continuing to plank my stern, I think to myself: “Damn! This sure is a whole lot of extra effort just to include the roundup detail and an extra tier of stern windows.” Then I remind myself that it is the completely modified stern that will become the focal point of the finished model, and what transforms it from the familiar Heller kit into something entirely different. If I can pull off the stern, that should minimize attention to those aspects of the kit that I can not modify and/or correct. The progress is slow, but the effort still feels well worthwhile to me. If nothing else, I have developed a much deeper appreciation for the guys that make everything from scratch. We are getting there - one little bit at a time.
  22. Oh, this is excellent! Thank you Jan. The more I consider it, it will forever annoy me if the stern windows don’t match the windows I make for the quarter galleries. Dan Pariser always describes this project as my attempt to make a silk purse from a sow’s ear. In some ways, I suppose he is right about that, although I happen to think a little more of the Heller kit. I would certainly be trending towards the latter, though, if my windows are obviously mis-matched. I apologize to those of you who have sent me extra stern plates for the sake of using the windows, but do not despair. I will still be extracting all of the really delicate bell-flower ornaments on the pilasters between windows. Also, the Zodiac symbols from the taffrail cornice.
