Everything posted by mtbediz
mtbediz replied to mtbediz's topic in - Build logs for subjects built 1751 - 1800
No problem, Jon. -
It is the camera of my cell phone Peter. This camera is doing a really good job. -
Thank you so much Peter. -
Thank you so much Greg. -
I had to think for a long time about how I could put the pieces together. This was a real challenge,for me especially on this scale. -
Quad pump completed.This has been the equipment I have had the most difficulty in manufacturing and assembling so far. -
Thank you Greg. Normally, I do not paint the brass material, I just blacken it with chemicals, but since I use solder here, I have to paint it because the solder does not blacken with the chemical. I don't blacken the brass before painting, I just paint it with acrylic paint and apply matte spray varnish after the paint dries. -
Thank you so much my friend. -
I have assembled the gun deck bilge pump parts in place for testing. The brass parts will be painted black. -
Half of the spar deck beams are completed. I can only complete one beam and its connected knees per day. -
I glued the ropes with CA to the frame, where I marked with a red circle in the picture. While gluing, I stretch the rope with a pair of tweezers that I extend below. So it looks like it's tied somewhere below. The end of the rope is not tied to anything, I found such a solution. -
Great job on the metal, Greg. Looks like brass material, have you ever thought of blackening it? It looks more realistic.
- 184 replies
- Bluenose
- Model Shipways
Thank you Greg. My table saw is a Proxxon KS230. It's Proxxon's simplest saw and does a good job within its capabilities. I've been using it for six years. -
I would like to show how I made the main beams for those who are wondering how I did it. Since I have difficulty obtaining smooth beams by cutting and sanding wood, I use another method. I cut 3 pieces of the same size strip from 1,5x5 mm stock, apply glue between them, clamp them to the mold I prepared before, wait for it to dry, and remove it from the mold. Thus, I obtain standard curved beams. -
Thanks for the info John. As far as I understand what I made is a Grog Tub -
Thank you Greg. I really don't know what was in the barrel. There was probably a liquid inside, such as water or alcohol. I added it because it was on the deck of today's ship. Jon is really knowledgeable on Conny. Maybe he can make a contribution. -
I don't know when this ship was launched, but my guess is that she is at least 200 years old and is still alive and well. She deserves her name. She's an ''Iron Lady'' -
Greg, I know it's too early to ask because you're concentrating on your Bluenose right now, but while it's mentioned, let me ask anyway. Are you considering adding a gun deck to your Constitution? As far as I know the kit does not have this.
