Everything posted by Beckmann
Hi Chuck, one question: Did you make the Winchelsea display-stand parallel to the waterline or parallel to the keel? The Amazon display is obviously made parallel to the waterline, the bow column is longer than the one at the stern. Thanks Matthias
- 1,784 replies
- winchelsea
- Syren Ship Model Company
Thank you all for the comments and likes. at the moment I am working on the dispay case. As I showed above, I want to make a case for three models. My Queen Anne-barge 1"/2' scale and my bone model of the azorean whaleboat wich I showed in my other build log on MSW, also 1"/2' scale. They will be together in the "ground floor" and above them the Winchelsea. Last year I cut a pear tree and so I have some nice pearwood for the case. by now it is dry enough and I started on the table of the case. I started with the legs for the table, dimension 40/40/400 mm Then the table was put together... some parts to stiffen the construction in the corners... Some strips to cover up the top... Here ist one of the models for the ground floor, the mirror-basement will come into the display case as well. Matthias
Thanks druxey, here my inspiration for the crew: nowaday they still build these boats for touristic and sport events. They sail regattas and row them. There are lovely photos on the internet I am married and we have 5 daughters, so guess, what I am dreaming of... Matthias That
- 7 replies
- whaleboat
- restoration
Hello Everybody, my little whaleboat-project continues. First of all I had to repair a broken thole. I repaired it by replacing the pin with a new one I made from bone. Here we go... After this litte work, the boat is ready for being rowed by a crew of 6 oarsmen and led by the master on the rudder or the steeringoar. I asked my daughter to help me out with a crew, so I can get an imagination of the whole thing in action. That was fun for the both of us. The model is actually very sturdy. No fragile parts. It has much of a toy, perhaps it once was made to play with? I don't know. I proceeded with the rigging. It is a very simple rig. Once the mast stands upright in his bracket, you only have to fix one shroud to each side and thats it. I renewed the mast-rings, becaus they were from plastic and looked very cheap. I made new ones from ivory. After having washed and ironed the sails, the whol rig came together. A very elegant model, I must say. Matthias
- 7 replies
- whaleboat
- restoration
Hi Chuck, in my opinion, the costs of a single chapter are more important than the total cost of the whole model. I never counted together, what I payed for all the chapters of the Winchelsea, because it does not matter. But I always had a look on the price of the next chapter + tax + delivery. So for most of the people it is probably best to not make a chapter more expensive than 250 to 300 $. You probably need 750 to 850 $ for the framing, so you better make 3 chapters for the framing and there will be many folk able to afford it. I am shure, everybody wants to build this model. Matthias
After being busy with other projects, I now want to continue with the restoration of the bone model I already showed you back in 2021. I found a couple of similar models in auctions around the world, several of them made by the same builder Albertino Sousa Luz. In fact, almost all of the models seem to be signed by A.S.Luz. So it is propably a retired (and very talented) whaler who made them rather then a local tradition. I dismantled my model, becaus it was a dirty mess and started to clean it first with a dry brush and then with a wet ear stick. I am happy to say, that no parts are missing. All of the long oars, the steering oar, the paddles, the rudder, the rowing oarlocks and the hunting tools are still there. Some of them were fixed to the model with rope. I removed these ropes, because they were very dirty and partly unraveled, I will replace them. Here you can see the harpune rope-drum. I also cleaned the sails. The mast-rings are made from plastic and don't look very nice. I will propably replace them by rings made from bone. Matthias
- 7 replies
- whaleboat
- restoration
Thank you! This weekend I made the stern lantern, as I said from ivory agein, like some of the other features. I did not use laser cut, like I did for the galery-windows, but cut the parts with a jigsaw. I must say, this is better than laser cut, because the heat of the laser somehow affects the material and makes it a bit yellow and more fragile. After cutting out all the parts I made the bottom and the roof, wich are assemblied from several parts. The windows needed a careful sanding, to not look too crooked. Then I glued the parts together... ...added the candle and the glazing... and here we go, everything finished for being mounted on the model. I will add the lantern to the model, once the display case is completed. Otherwise I will break it of for shure, while carrying the model around. Matthias
Thank you all for the kind words and the likes. What's next? Well, the stern lantern and display case of course. And then I circle around a special project of a danish ship. Designed by a french shipbuilder in 1742 and decorated by a german master-carver. It is a bit early to show something here. A contemporary model survived in Copenhagen and a few quite detailed plans. Matthias
Hello everybody and thank you for the kind words and the likes. At the moment I am working on finishing the last parts of equipment. Guns, swivel-guns and the stern lantern. The model is a bit dusty, but here are some photos. The stern lantern will be the last step. I will make it from ivory again. Matthias
Hi Greg, I actually don't know. I used all the laser cut parts and did not alter anything. But when I put the figurehead on the model, it somehow did not fit properly. The position was too far forward. So the only posibility was to cut the scrollwork or to cut away a part of the arm of the figurehead. I took the scrollwork. Matthias
Thank you, I continued with the gratings between the rails. The triangular gratings in the corners of the bow-area, I made separately with a template. I glued the parts on the template, assembled everything, cleaned it, painted it again an glued it to the model. Then the facilities and false rails were added, and finally the figure-head. I have been waiting long for this point. What a lovely figure. I actually like it, that it is not a warrior or something like that, but a musician. Remembering, that securing the peace should alway be the goal for every army or navy. Matthias
Thank you, I continued with the head-rails of the gallion. I must say, this is by far the most challenging part of the whole model. I messed up the first pair of headrails and had to ask for a new set, wich Chuck immediately sent to me. Thanks for that!! I started all over again. Every part here is important for the whole appearance of the construction. Ther are plenty of graceful curves and angles. If any of them are out of place, the whole construction looks weird. Here are the new headrails, I tried to remove most of the laser-char. First parts are in position now. Matthias
This is a lovely project. I like it very much. And these little working boats should not be forgotten. So many folk earned their daily bread on them.
- 16 replies
- Sophia Rose
- Block Island cowhorn
So well executed!! You can be very proud of this beautiful model. I look forward to your display case. I still have no idea about a suitable stand and display case for my Winnie-model, wich is about to be finished very soon as well. Matthias
- 642 replies
- winchelsea
Hello Everybody, thank you very much for your nice comments! I continued chapter 11 with the deadeyes and chainplates. It is all so well explained in Chucks instructions, there is not much to say about it. It all worked very well. The only bigger problem was to not stretch the acrylic chains too much, so they remain close. I tried the position in advance and made a hole with a needle, where the brass-nail is supposed to be. That worked quite well, I hope you know, what I mean. So here are some photos of the result. I also installed all the guns on the lower gundeck. I followed stuntflyers method and pinned them onto the deck with brass-nails, so they cannot get lost. I will now proceed to the next chapter and think about, if I will add the swifel guns or not. They are a nice feature, but somehow interrupt the lovely flow of the quarterdeck-rail. Matthias
