Everything posted by Ondras71
Roter Löwe 1597 by Ondras71
Ondras71 replied to Ondras71's topic in - Build logs for subjects built 1501 - 1750
Thank you very much Peter Cane!! These cannon barrels will be stored under the deck, the rear will not be visible.. Gun barrels ready .. O. -
The resulting cannon barrel dimensions failed, so repetition of work .. Old cannon barrels will be converted to small guns aboard .. I wish everyone success in 2020!! Ondras -
Thank you very much stuglo!! I was stopped by the warranty repair of the lathe proxxon, a little woodwork. Gun Port covers .. Side test.. -
Thank you very much zappto!! Construction of carriages, rather pedestals that will not be seen.. Shape and dimensions taken from the Dutch carriages Zeven provincien.. Test.. My pattern, the deck of Batavia.. O. -
Very important information about Dutch ships !! I also draw information from the book Prins Willem (1651). O.
Hopefully, our current ship designs will remain accurate and there will be no room for debate.. Thank you for your support Backer!! Ondras -
Thank you for the likes.. O. Hull on the stand reinforced .. Installation of the internal boards continues.. Railing edges aligned.. -
Greetings from the Czech Republic. Your first model is simpler, you start well. I keep my fingers crossed for the construction!! Ondras
Continuation.. Adjusted cannons according to historical background.. In combination with the Dutch Lafette .. -
Thank you for the compliment Ab Hoving! We got into a fight, we have to fight.. Continuation. Main deck base.. The sides of the hull inside..
