Directional change of the plates...from oblate oblong to more of a straight line curve....if that makes sense? Rob
- 602 replies
- Flying Fish
- Model Shipways
Fantastic work Vlad.....just wonderful. What was your final measurements for the fore, main, mizzen channels? Love your poop rail stanchions....super job. Did you pin them? I plan on making the rail itself first then adding the stanchions under it. but first the channels. I am working currently on the chain plates. Your progress is just amazing and I like that you filled in the topgallant rail. So many small details to keep track of. Many eyes are helpful for sure. Impressive....impressive indeed. Rob
HMCSS Victoria 1855 by BANYAN - 1:72
rwiederrich replied to BANYAN's topic in - Build logs for subjects built 1851 - 1900
Sall good Pat....its was just a test part...hense the word *TEST*. your soldering job was very nice for sure. Say...how you doing with all the lockdowns there in your neck of the woods........? Makes getting modeling supplies a bit tough. Rob- 993 replies
- gun dispatch vessel
- victoria
Welcome........ And great progress on your Flying Fish. I look forward to your continuation on her rigging and masting.......... Great job Rob
- 417 replies
- Flying Fish
- Model Shipways
It would actually be interesting if Mike could get it applied as an *Update* to his new transcript...since it is not gone to press yet(from what I gather). Rob
- 3,560 replies
- clipper
- hull model
My opinion exactly. My job is hard enough, and I can mask just about any after market item to not give itself away. I kit bash lots of kits as well……using anything I can modify for my purposes. I can look into an item and envision what it must be. Rob
- 3,560 replies
- clipper
- hull model
Yeah....I agree. Just because I'm some sorta rabid energizer twitchy squirrel who only knows how to work at *Ludicrous Speed*, no need to feel compelled to try and keep pace. No body deserves that kinda pressure. Real or imagined. Heading into winter, means more time inside. You're exactly where you need to be. Painting (In the fashion you described) and coppering will fill your days. Rob
Nah....I let somebody else do that tedious work. Not sure who I got these from...I had them on hand. I use several shops when buying....brass work or chain. I'm sure Donald McKay had a sub-contractor for small stuff like belay pins and...oh...masts/spars and canvas an stuff.... Typically, I make my own stuff...but it is my way to re-engineer other folks stuff for my purposes. Thanks for the fine comments and encouragement
- 3,560 replies
- clipper
- hull model
Thanks Tony. Making the pin rails took a bit of math and some drafting skills. They are not bent into place, they were cut to fit the curve of the hull. I had to determine the curve by using my drafting protractors and draw out the curve on a piece of wood taped to the deck. Then cut along the line and then calculate the under and overhang of the rail, draw that out on the piece of wood and then cut that out as well. Boom , perfect fit and to scale. All I had left to do is mount it and the drill out the hundred or so holes for the belay pins. Both sides in about 3 hours. Rob
- 3,560 replies
- clipper
- hull model
Rich, I did set her next to the CS and boy is it a comparison. That is one reason I didn’t like my CS mod for Glory…….because it changed the scale to more like 1/128 instead of 1/96. Now I have a 1/96 of both ships…..so folks can see the real size difference. Rob
- 3,560 replies
- clipper
- hull model
George, two notes I would like to point out on my first copper job on the Great Republic I used adhesive to glue the tiles of tape down with their backing in tact but with the Glory of the Seas I remove the foil from the backing and stuck it directly to the hall. Great start, Rob
- 602 replies
- Flying Fish
- Model Shipways
- 3,560 replies
- clipper
- hull model
I have a few more updates to the build. I am adding the main pin rails. Just finished the port side. Rob
- 3,560 replies
- clipper
- hull model
- 3,560 replies
- clipper
- hull model
- 3,560 replies
- clipper
- hull model
I think you’ll have more success personally when you tackle projects as small individual projects once you finish each small project the larger project starts to come into view. Plus if nothing else, you feel as if you’re accomplishing these small goals which motivates you to continue to the larger goal. Thanks for the wonderful compliments. Rob
- 3,560 replies
- clipper
- hull model
Actually Rich, I’ve done some further analysis and if you look at the very clear image that Mike gave us, if you follow the third band around to it’s termination at the bottom of the bowsprit you can see that that band is almost between the tip of the hood and the back of the figureheads head take another look you’ll see. If you look at the third band just on its side it appears to be exactly at the tip of the hood but follow it to its termination on the bottom and that is the actual point where it’s at coming down behind Athena’s head. We don’t have an exact angle from the side like a Profile , But I think it’s clear. Rob
Vlad, you have to do what you have to do. Make what you need to make not what other people think you have to make or what they want you to make. The top Gallant rail looks really good there at the forecastle, I was wondering are you going to continue on down the full length of the hull? So many details it’s almost mindnumbing. Apart from the laser cut bulkhead you provided me I will not be doing any other laser work , all handwork on my model. I can’t wait to see the laser cut scroll work. Great job, love your model. Rob
- 3,560 replies
- clipper
- hull model
Thanks bro. Your doing great, can’t wait. Rob- 993 replies
- victoria
